This thread is privately moderated by IBCrazy, who may elect to delete unwanted replies.
Old Oct 28, 2012, 02:13 PM
FPV_Habu_Flyer is offline
Find More Posts by FPV_Habu_Flyer
United States, MN, Orono
Joined May 2011
Hi guys,
I'm having a bit of a problem with my system and could use some help. Recently, I have taken my plane out to fly but my camera (RMRC-540) can't see anything. It completely blacks out the ground and the sky can only be seen slightly. It is completely unusable. I have been using this camera for a long time and only recently has this been a problem.
Here's the thing: I just switched out the transmitter cable and it always comes loose. I think that could be the problem- it's loose so it's not delivering the full picture. I can't get the cable plug to stay in the transmitter: it just falls out because it is too loose. I like ReadymadeRC a lot and they have awesome products, so I know this is a bit of an aberration for them.
Any help would be appreciated,
Jim
FPV_Habu_Flyer is offline Find More Posts by FPV_Habu_Flyer
Old Oct 28, 2012, 06:05 PM
TonicMan is offline
Find More Posts by TonicMan
United States, IA, Johnston
Joined Sep 2009
Originally Posted by onefastxp View Post
did you lose sing at .4 miles? i wuz hopeing at least 11/2 miles.
Yes.
TonicMan is offline Find More Posts by TonicMan
Old Oct 28, 2012, 07:12 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by FPV_Habu_Flyer View Post
Hi guys,
Jim
It sounds like it is one of two things:
1. Your new wires and connectors are too long or are running past some high current devices. This causes video level distortions.
2. The settings on the camera have changed.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Oct 28, 2012, 08:57 PM
Joined May 2011
-Alex
Thanks for the help,
I tried it again, after adding tape to keep the connector in, and it worked a little better. Still a bit dark, but granted it was in the evening on an overcast day. I know the wires are the same length as they were when it was still working, so that can't be it. I also never touched the camera settings.
"...running past some high current devices,"- That could be it. The Stryker has little fuselage room, so the cable runs right next to the ESC and battery. Could that be the problem? Would spacing the wire out help?
Jim
Old Oct 28, 2012, 09:30 PM
mikenc is offline
Find More Posts by mikenc
Joined Jan 2012
monitor
Hello everyone. I need some help in finding a monitor to use at ground station. I have a 10" pyle i bought from RMRC several months back but it is so small and the picture is not clear at all to me. I have made sun shield but still have a hard time seeing.
I am looking for something in the 16" wide flat screen range that dosen't go blue screen, and can be powered with 12 volts. You can find lots of small tv,s that work with 12 volt but knowing if they blue screen is the biggest problem.
Googles are pretty much out for me since i wear glasses.
If anyone has a link to one i would appreciate the info.
Michael
mikenc is offline Find More Posts by mikenc
Old Oct 29, 2012, 12:58 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Jim
I would use a coaxial cable grounded a one end to protect from high current devices. You can find it pretty cheap.
Of course, shielded wire (CAT6 cable) works well too. Just be sure to ground ONLY 1 end.
-Alex
Old Oct 29, 2012, 12:59 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Michael
How bad is your vision? Goggles seem to be ok for most people with glasses so long as their vision isn't too bad. 20:100 would still be safe for goggles.
-Alex
Old Oct 29, 2012, 01:33 PM
mikenc is offline
Joined Jan 2012
-Alex
not good at all, to many years under a welding hood!!
I think i will need a good clear screen to look at. The one i have is border line as long as i am in my basement, but outside is a different story.
Michael
Old Oct 29, 2012, 01:56 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Ever consider an 8X11 magnifying lens? They make them for reading documents and such and you can often find them with the spacers already installed for just a few $$.
-Alex
Old Oct 29, 2012, 03:51 PM
Pyrofan is offline
Find More Posts by Pyrofan
Pyrofan's Avatar
United States, GA, Perry
Joined Jul 2011
So after reading. Will a 1.2mhz Fpv work with 2.4 control if i put filter on it. Also, I cant seem to find what is better for each situation. Im in a pretty open area. Trees are about 250-350 yards away. I have a metal shed behind me. And have trees and a neighborhood about 100yards behind me. So does that mean that 1.2 or 900 is the best for me? Iv read 5.8 would work but will have about 1mile range. also whats a good starter OSD. are their any with voltage ,artificial horizon, alt, direction, and timer only. seems the more features, the more money. dont wanna drop $120 on a OSD as a beginner. maybe down the road. Can yall recommend a FPV system for me that is under $100 (Would pay $120). I want something that works but doesnt have to be that amazing of quality. Just want about a mile or 2 of range. that way as i get better i can fly farther.
Pyrofan is offline Find More Posts by Pyrofan
Old Oct 29, 2012, 04:10 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
1.2Ghz video works fine with 2.4GHz control if you use a low pass filter on the VTX. You can make a notch filter like I have outlined in my blog as well. Mind you, 2.4GHz control will not reach 2 miles reliably. You need to get a UHF radio for that. You can get everything you need from ReadyMadeRC or HobbyWireless. All you need is a video transmitter, video receiver, and a camera. You can check my blog for all sorts of DIY antennas.
As for OSD, forget it for now and add later like you said. I personally like the Remzibi, but Skylark is also a good option if going for the cheap. There are other options as well.
-Alex
Old Oct 29, 2012, 06:31 PM
Pyrofan is offline
Pyrofan's Avatar
Joined Jul 2011
-Alex
So, 1.2Ghz system with low pass filter and A Skew Planar Wheel Antenna on the TX and RX. is this good for a beginner. Can a 1.3ghz antenna work on a 1.2. what do you recommend for 1.2 system. the ones that i was looking at on hobbywireless said illegal in US. whats legal? i thought 1.2 and 1.3 where legal.
Old Oct 29, 2012, 07:10 PM
Blueshy is offline
Find More Posts by Blueshy
OSUFPV - KF7VFT
Corvallis, OR
Joined Apr 2010
It's pretty simple: get a HAM radio license otherwise you are operating illegally.
Your related questions will guaranteed to be answered by the time you pass
the test.
-Blues
Blueshy is offline Find More Posts by Blueshy
Old Oct 29, 2012, 07:43 PM
Pyrofan is offline
Pyrofan's Avatar
Joined Jul 2011
the test.
-Blues
How do u get a HAM license
Old Oct 29, 2012, 07:56 PM
Pyrofan is offline
Pyrofan's Avatar
Joined Jul 2011
heres my cart right now. does it seem good.
http://www.readymaderc.com/store/ind...d1455a5a7b2c8e
http://www.readymaderc.com/store/ind...oducts_id=1017
http://www.readymaderc.com/store/ind...roducts_id=503
and low pass filter
http://www.readymaderc.com/store/ind...roducts_id=484
Discussion Can this cam be used for FPV ? SpookiePower FPV Talk 11 Aug 16, 2016 11:08 PM
Discussion How to calculate flight time - guide ikorman Multirotor Talk 16 Jun 26, 2016 07:34 AM
Cool How cool would this be for FPV Kai_Shiden FPV Talk 4 Feb 18, 2016 08:02 PM
Discussion How many FPV pilots in the world? rbmaze FPV Talk 10 Aug 03, 2011 06:16 AM
Poll Would you be interested in buying Ready to Fly FPV airplanes from a new FPV store? FPVNOW FPV Aircraft 36 Oct 06, 2010 08:56 PM
