This thread is privately moderated by IBCrazy, who may elect to delete unwanted replies.
Old Oct 15, 2012, 06:42 PM
TheNiceGuy is offline
Find More Posts by TheNiceGuy
Expat
Japan
Joined Apr 2010
Well I thought I'd ask you guys as I asked a couple of times elsewhere and got no definative reply.
Basicaly I'm looking to replace my lost tricopter. I want something smooth and reliable to carry a gopro1 for scenic shots, probably max 2km away. Less hassle the better. I was useing LM 2.4 500mw, which worked well, and futaba FF8/corona synth 72mhz, full length antenna OK. It rolled unexpectedly at close range, I think it was a corona glitch. Never tried the tri with a proper matching PCM1024 rx.
Anyway, the cheapest option is to try a PCM1024 rx. Or, buy a RL UHF system. Or frsky, and a new FPV system. I thik these last 2 will work out almost the same price, although replacements for former will be more expensive.
Am I correct in assuming the RL is the best way to go despite the cost and limited range I seek because its the most stable?
TheNiceGuy is offline Find More Posts by TheNiceGuy
Old Oct 15, 2012, 06:56 PM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
Yes pictures say a 1000 words and video with music says a zillion words
I fly lots of different planes and each plane is new experimant basically.
If you click on to my blog there is link to about 1/2 of videos that are not private. Private ones are private for personal reasons.
However I did recently post videos to show things I been experimenting with such as 6mm lense for camera, 2.4 for clearer crisper color and video over 1.2, etc. but recent plane is a 60 inch wing from true rc from east Canada.
will go to store and return sd card reader that does fit and post pictures on show us your plane with videos of it flying
I just made up a rc car as well with lawmate 1 watt for video and seems to go far in city blocks
my goals and experiments in the last year or so however have been to get best video possable as rc control is no problem
btw fox 1.5 1.2 video txs are not all created equal, some are more powerfull than others
i think lawmate are accurate in production and out put
http://vimeo.com/user500576/videos/sort:newest
Originally Posted by geminiryan View Post
I agree, a list is important. But SHOWING how that list is implemented into a working, functioning and RELIABLE FPV machine is what is key. There were 3 things that were important to me in getting started in FPV. 1) Air frame selection. 2) Component selection. and 3) How to integrate both air frame and components together. If it weren't for the expertise that I found on RCG I would probably still be struggling with my research (which in itself took nearly a year.) And an important aspect of this learning process was the visual aspect. I speak for myself, but it was extremely important to see how components were distributed and wired, especially in the air frame that I chose. So, however trivial it may seem to some, even the most simplistic visual aid can sometime replace a thousand words.
Anyways, on a side note. I had a successful maiden flight with full Eagle Tree with stabilization today. Good times!
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Oct 16, 2012, 06:49 PM
Troy is offline
Find More Posts by Troy
Caution:Makes sharp left turns
Troy's Avatar
United States, CA, Lake Forest
Joined Feb 1999
Noob alert: I just flew a Fat Shark 250mW Predator combo today with a friend on the goggles. The reception was less than thrilling; it was broken up most of the flight. I'm going to trouble shoot through the channels first but wonder if I should also save myself the trouble and get IB's antennae combo on Ready Made? I've been studying up on the threads but oh man do I need a mentor in this.
Troy is offline Find More Posts by Troy
Latest blog entry: Flying Ghost
Old Oct 16, 2012, 08:09 PM
polyfractal is offline
Find More Posts by polyfractal
polyfractal's Avatar
United States, SC, Charleston
Joined Jun 2012
I'm assuming you are using 5.8Ghz?
Was the video interference predominantly when you were rolling, banking or turning? This is almost certainly a polarization issue. The IB cloverleaf/skewplanar wheel antennas will definitely help. You should probably get a pair anyway...they are great.
If the interference was constant, it's probably your VTx or camera. Try adding a ferrite ring to your VTx and/or camera cables. Sometimes the VTx or the camera is particularly noisey. The ferrite rings act as passive filters and remove high-frequency noise before it is passed onto another device.
If the interference changed depending on throttle, it's the ESC/battery. If you are driving your VTx/camera from the same battery as your motor, the ESC can cause a lot of interference. Try putting a ferrite ring on the ESC => radio receiver servo cable. That usually gets rid of the interference, but if it doesn't, you'll need to build an LC filter.
polyfractal is offline Find More Posts by polyfractal
Site Sponsor
Last edited by polyfractal; Oct 16, 2012 at 08:23 PM. Reason: Correcting a few technical details
Old Oct 16, 2012, 09:27 PM
JLT_GTI is offline
Find More Posts by JLT_GTI
JLT_GTI's Avatar
Spain, Principado de Asturias, Oviedo
Joined Jun 2010
Anyone is using a PPM encoder?
Im using one from FPV Japan and im getting some trouble in the control chanel of the OSD.. now im shielding wires but so far i have properly shielded the wire from PPM encoder to OSD and no effect whatsoever..
I will shorten the wires going from the RX to PPM encoder (they are twisted and 15-20cm long..i will cut down them down to 3cm) .... but im anoyed at what causes the OSD to get "unwated" commnands while other chanels dont seem to be affected
JLT_GTI is offline Find More Posts by JLT_GTI
Old Oct 16, 2012, 10:01 PM
stgdz is offline
Find More Posts by stgdz
One blade in the water is wet
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
best spot in the us to get Male to male servo wires?
Need some for my tricopter
stgdz is offline Find More Posts by stgdz
Old Oct 16, 2012, 10:11 PM
Troy is offline
Troy's Avatar
Joined Feb 1999
It is the 5.8Ghz system on channel 1 (5740). From what I could gather from live feedback, the interference was occurring mostly during banking and turning and cleared up slightly during level flight (small field surrounded by trees). I feel I might also be blanking out the antenna as it sits above the motor and ecs. It's a small airframe and hard to get the tx and antenna outboard without messing up lateral cg and aerodynamics. That's where I think one of the clover antennas with flex cable might let me move it away from objects that block the signal (just not sure what items to buy yet since the combo set has rigid coax). I'll also see if I have a ferrite ring for the esc as well. I'm going to try again tomorrow. Thanks very much for the feedback!
Old Oct 16, 2012, 11:51 PM
MTHead4u is offline
Find More Posts by MTHead4u
Having fun again!!
MTHead4u's Avatar
United States, AZ, Queen Creek
Joined Aug 2012
Noob FPV'er here..
Needing a little help selecting a Vrx antenna setup for a quadcopter. Mostly straight and level in an open valley towards the mountains. Distance is less them 1/2 mile and I don't plan on flying that far for quite awhile.
This will be my main view, based at the parking area.
As of now I have the following,
Vtx: 5.8g IRC5.8-600MW
Vtx Antenna: 5.8 GHz Cloverleaf Whip Antenna (RHCP) (Single, Right Angle)
Vrx: Duo5800 Receiver.
I was planning on a
5.8 GHz Skew Planar Wheel Whip Antenna (RHCP) (Single, Straight) mounted on a 5' tripod for one input on the Duo Vrx to cover me for flying around base, but what would be best for the other?
5.8 GHz 10dBic Crosshair Antenna?
or
5.8 GHZ 5 Turn Helical (9.5 dBic)?
or
5.8 GHz 11 dBi Flat Patch Antenna?
The crosshair has the widest beam, followed closely by the Helical, then the patch, of course all you guys now this already.
Probably need to go back and watch the videos again huh? lol but i'm open to any pointer.
MTHead4u is offline Find More Posts by MTHead4u
Old Oct 17, 2012, 03:58 AM
Martin7182 is offline
Find More Posts by Martin7182
Wallop!
Martin7182's Avatar
Bussum, Netherlands
Joined Oct 2009
Hi MTHead4u,
If you don't plan to fly beyond 1/5 mile then the SPW should do fine with your amount of vtx power.
Your listed directional antennas have about equal gain so I don't know if there's any noticeable difference at all. Regarding a patch, be sure that it is also CP instead of linear polarized.
But why don't start with the CL/SPW combo, it should give crystal clear reception over the entire 1/2 mile.
Martin
Martin7182 is offline Find More Posts by Martin7182
Old Oct 17, 2012, 04:22 AM
efx is offline
efx
Find More Posts by efx
efx
Rookie in training, heads up
efx's Avatar
Los Angeles
Joined Mar 2010
I sure hope someone has an answer on how to prevent this...
RC Glider Attack By Crow Crashed 2 (1 min 38 sec)
efx is offline Find More Posts by efx
Old Oct 17, 2012, 04:34 AM
kokopropelli is offline
Find More Posts by kokopropelli
Crash....Fix......repeat.
kokopropelli's Avatar
United States, UT, Eagle Mountain
Joined Jan 2012
Originally Posted by Martin. View Post
Hi MTHead4u,
Martin
+1
I have the same Vtx but just the single receiver with CL/SPW antenna and I easily have 1/2 mile range. Your video range will be limited by your control range.
kokopropelli is offline Find More Posts by kokopropelli
Old Oct 17, 2012, 04:36 AM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Howly smokes! I never saw something like this before. You must have p***ed of those birds big time! Wow...
Markus
markus123456 is offline Find More Posts by markus123456
Old Oct 17, 2012, 05:05 AM
PinDuke is offline
Find More Posts by PinDuke
I can fly this plane
Kingdom of Sweden, Gävleborg County, Sandviken
Joined Jan 2012
Maybe by not flying over the nest
PinDuke is offline Find More Posts by PinDuke
Old Oct 17, 2012, 05:34 AM
efx is offline
efx
efx
efx's Avatar
Los Angeles
Joined Mar 2010
Yeah there are a few others you can check out on youtube and those suckers are mean. Markus, that's not my video, I just saw that myself. I guess a faster motor will do for the birsds. LOL. Now I got another cool video here and now I need to find me a good all around all terrain vehicle for fpv. I also still have to read all about the antennas and stuff, but have been too busy trying to fly the helis first. I thought you guys will enjoy it since it's fpv, but on land. I need to try this now. The man has skills! There are 3 videos, check out all three, good story. I also found out he's a member of rcgroups too. So if you got questions, just look for him here.
Geek Gets Girl part 1 "Tonka Summit too" (5 min 58 sec)
Old Oct 17, 2012, 12:55 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I was planning on a
or
or
Two 3 turn helicals for your diversity aimed ~90 degrees apart is more than what you need for 1/2 mile. I wouldn't look into higher gain unless you plan on distances exceeding 1.5 miles. In fact, a simple skew wheel or Fan antenna would be plenty for what iy intend to do. You don't need a diversity receiver for this.
IBCrazy is offline Find More Posts by IBCrazy
Discussion How to calculate flight time - guide ikorman Multirotor Talk 15 Feb 01, 2015 11:12 PM
Discussion How many FPV pilots in the world? rbmaze FPV Talk 10 Aug 03, 2011 07:16 AM
Poll Would you be interested in buying Ready to Fly FPV airplanes from a new FPV store? FPVNOW FPV Aircraft 36 Oct 06, 2010 09:56 PM
Discussion Can this cam be used for FPV ? SpookiePower FPV Talk 8 Sep 12, 2010 08:12 AM
Cool How cool would this be for FPV Kai_Shiden FPV Talk 2 May 11, 2009 08:41 PM
