This thread is privately moderated by IBCrazy, who may elect to delete unwanted replies.
Old Oct 11, 2012, 02:26 PM
"FPV"er not a "LOS"er
Wettfeat's Avatar
United States, NC, Charlotte
Joined Feb 2012
Originally Posted by David22 View Post
Yes some people have derailed this thread unfortunately, and even post things nothing to do with fpv, they just are waste of post space.
Case in point...
Houston we have a troll...
Wettfeat is offline Find More Posts by Wettfeat
Old Oct 11, 2012, 04:06 PM
Martin7182
Martin.'s Avatar
Bussum, Netherlands
Joined Oct 2009
Originally Posted by MASHTON View Post
Seriously David? You know good and well what other gear gets swamped by those +1W vtxs in close proximity. UHF control (maybe not your TSLRS that is what 2W and 8W boosted or something but the rest do), 2.4GHz control and GPS all get swamped.
Stand across from your friend and have a conversation, start walking away until you can't hear him anymore and mark the spot. Now put a radio in the mix and repeat set the radio on different volumes and repeat this test several times. As the radio volume gets louder the distance you can hear your friend decreases. This is an approximation of what we are doing to our gear every time we fly. A 1+ watt vtx is like putting a radio on full blast and walking away. The further away you get from the source the harder it gets to receive (hear) it. The receiver is essentially the plane's ears, you don't want someone screaming in it.
Nice explanation, but not necessarily true imho. It only counts for equal frequency bands. If I have a conversation it doesn't matter whether a bat is screaming in my ears. The other way around may be a problem for the bat; my voice probably contains harmonics a bat could hear. So harmonics could be bad. And magnetic coupling could be a problem in close proximity. Anyway high power doesn't add much to your range; you'll need 4 times more power to double your range. Often easier is to use a +6dB rx-antenna. It is lighter, prevents over-heating and saves battery power as well.
Originally Posted by IBCrazy View Post
Of course if you don't believe me, then explain how a Yagi antenna works without any coupling effect.
-Alex
+1!
Martin
Martin. is offline Find More Posts by Martin.
Old Oct 11, 2012, 04:42 PM
doz
D.O.
Oklahoma
Joined Jan 2004
RE: topic toppling. David22 et all... seems like those who talk the most about arcane stuff provide the least useable information to new-comers. When there is to much arguing, NOBODY wants to listen or take advice. Maybe you guys should step back for a bit and let the intended nature of this forum re-establish itself?
Just sayin........
doz is offline Find More Posts by doz
Old Oct 11, 2012, 04:48 PM
Wettfeat's Avatar
Joined Feb 2012
Alex,
I made one of your vee antenna's and it works well. I have it mounted on the wing of my Skysurfer and it works great going and coming but when its "sideways" oriented so I can see the fuselage lengthways the signal is gone. I assume this is normal since I'm using the stock antenna for the receiver. I just wanted your opinion on antenna's for the receiver.
I looked at your ground plane antenna but it won't fit inside my fpv box. Can I turn it into 1/8 wavelengths for the elements and if so how much range would I lose. I have 1.5W 900mhz vtx so I don't know. I'm going for 3 miles.
Old Oct 11, 2012, 06:12 PM
North vancouver, B.C. Canada
Joined Apr 2008
Yes it is important to stay on topic and not let personal feelings effect advice.
It is sad that some make personal,attacks and actually break rc group rules
What is most important is that we keep to the thread.
I will post some pictures on a different thread as this is not show us your plane, as newbies and others are confused about some things.
There seems to be confusion about how to set up a plane and not need to separate or go through unneeded learning curves
As the whole idea is to help people,out so they don't waste time and money experimenting but rather learn from others who have experimented already
IbI crazy is great man for staring this thread to help others out, very great thread
It's best to read rather than make wasteful comments and not waste others time
So please refrain from stupid wasteful posts that are nothing to help,others out please
Let me take some pictures and just post link to show us your plane
As many email me recently asking how I position my setup nice and close and not need separation even with high powered video Txs
Argueing is really a waste of time, it's best to say why is that, or how do you do this, or very interesting I never thought that was possible , or wow that actually has never been done before and all,other guys do it differently
New ideas to,fpv is very important because this hobby of fpv changes so fast
It's only been a few years since long range fpv became popular
If you can do long range short range is a joke in the sence iit is easy as pie
Just sayin........
David22 is offline Find More Posts by David22
Old Oct 12, 2012, 12:04 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by Wettfeat View Post
Alex,
I'm not sure what you mean here, but shortening the antenna is generally a bad thing. There is a way to bend it, but this changes the radiation pattern. You could try a 4:1 balun on the ground plane antenna and that would allow you to make it smaller. You would still have considerable loss, but the balun gives you 400% more signal than just cutting it down alone.
If I were you, I'd build a patch antenna. Check my blog for the "fast patch". it takes about 20 minutes to build.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Oct 12, 2012, 01:09 PM
UAS Engineer
United States, WA, Battle Ground
Joined May 2012
Range estimate?
2.3ghz
- 700mw
- one of your recievers
- Cloverleaf on plane and Skew planar on ground station
- Lots of evergreen trees 100ft high, open airspace though.
- around 400ft and slow, boring. or slow, boring and above 400ft
CarbonFlite is offline Find More Posts by CarbonFlite
Old Oct 12, 2012, 01:39 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
^ If keeping it at 400 feet, you range is going to be hindered by those tall pines. Your range will be approximately 8 times the distance from the nearest row of pine trees.
Above 400 feet, you should do 3 or 4 miles.
-Alex
Old Oct 12, 2012, 02:26 PM
UAS Engineer
Joined May 2012
Thanks!
Old Oct 12, 2012, 06:34 PM
United States, MN, Orono
Joined May 2011
Do ground tests to find out if it effects range
Thanks, finally someone actually responded!
I know a ground test is a good idea, but if the Dragonlink really does have 40km of range, I won't be able to do a range test without getting in my car.
FPV_Habu_Flyer is offline Find More Posts by FPV_Habu_Flyer
Old Oct 12, 2012, 06:54 PM
OSUFPV - KF7VFT
Corvallis, OR
Joined Apr 2010
You should have a female 50ohm load balance connector that came with your
dragonlink system. Replace the antenna with that then rangetest your system.
They have on their website an expected meters to km conversion. It's a lot
easier than driving 40km.
-Blues
Blueshy is offline Find More Posts by Blueshy
Old Oct 12, 2012, 06:57 PM
God is my pilot
JimTMich's Avatar
United States, MI, Kalamazoo Township
Joined Aug 2006
OK, I got all the equipment for my first FPV.
250mW 5.8Ghz fatshark transmitter
bluebeam whips
1'extension cable for antenna if needed and a right angle adaptor if needed
RMRC 600 camera.
Everything works well on th bench.
I'm looking for the pilot feel, not the long distance pretty scenery feel, so I was thinking of mounting the camera on top of the wing above the cabin (hobbyzone supercub). I could mount it below the landing gear..... could I mount the camera out on the wing out of the prop view, or will that feel funny when the plane rolls because it's not centered.
Should I keep the Vtransmitter away from the control receiver, or just keep the vtx antenna away from the control receiver?
I have a 72mghz radio I'm going to be using for contro. (have 2.4ghz spektrum control at the moment)
i'm open for suggestions before I start cutting foam.... With your input,'I'll mock it up with blue tap and snap a picture for your final comments....
thanks
JIm
JimTMich is offline Find More Posts by JimTMich
Old Oct 12, 2012, 07:22 PM
UAS Engineer
Joined May 2012
One more question;
Where should I put my LC filter? Between battery and current sensor or ESC and current sensor? EZosd BTW
Old Oct 12, 2012, 07:43 PM
Joined Apr 2008
Pretty sure the dragon link has new switch or button or something now to act as dumbly load. This is great way to ground test at home and not need car. Older versions they said to take off rx antenna then gave out free dumbly load antenna. I am sure mike would send you free dumbly load antenna if yours is older version.
Range test is probably the most important part of fpv
Extensive range testing allowed me to put all fpv stuff in the plane within inches of each other.
Camera, esc, UHF rx, 1. Watt video tx, how ever a 1.5 watt would still pass ground test, it's all nice and close because nothing gives out noise that effects other components on the plane.
Without ground test you can have serious problems.
Old Oct 13, 2012, 12:51 AM
FPV in Hawaii
iskess's Avatar
United States, HI, Kailua
Joined Feb 2012
Ok David, we have been hearing that you know how to position the components closely together, even while using a 1.5W Tx. I understand this requires careful range testing, and the careful selection of the right components. You've said you have been PM'd and have helped others to recreate your success.
So please share with us what it is you do that makes this work so well. I don't really want to hear anymore about the fact that you can do this successfully, we would be better served hearing your specific techniques. Otherwise it isn't about education, but merely bragging and proving your point at Alex's expense. Let's make this constructive and educational.
Learn me something!
iskess is offline Find More Posts by iskess
Discussion How to calculate flight time - guide ikorman Multirotor Talk 11 Dec 30, 2011 07:22 PM
Discussion How many FPV pilots in the world? rbmaze Video Piloting (FPV/RPV) 10 Aug 03, 2011 06:16 AM
Poll Would you be interested in buying Ready to Fly FPV airplanes from a new FPV store? FPVNOW Video Piloting (FPV/RPV) 36 Oct 06, 2010 08:56 PM
Discussion Can this cam be used for FPV ? SpookiePower Video Piloting (FPV/RPV) 8 Sep 12, 2010 07:12 AM
Cool How cool would this be for FPV Kai_Shiden Video Piloting (FPV/RPV) 2 May 11, 2009 07:41 PM
