This thread is privately moderated by IBCrazy, who may elect to delete unwanted replies.
Old Oct 09, 2012, 09:08 AM
ror1 is offline
Find More Posts by ror1
FPV'r
ror1's Avatar
Canada, ON, Carleton Place
Joined May 2011
rangelink thread
http://www.rcgroups.com/forums/showthread.php?t=1518968
ror1 is offline Find More Posts by ror1
Old Oct 09, 2012, 09:16 AM
MASHTON is offline
Find More Posts by MASHTON
United States, VA, Madison Heights
Joined Aug 2011
Originally Posted by stgdz View Post
But why do people get the module based systems? Is it personal preference.
I run a module based Futaba 9C because it gives the option of having one radio and 2.4GHz Spektrum or Futaba, 72MHz and UHF, its just the flexibility of a module based radio is great. I guess you could say personal preference plays a huge part.
MASHTON is offline Find More Posts by MASHTON
Old Oct 09, 2012, 10:08 AM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
Yeah I figured that's what it was. I was out of the loop for a long time in RC and got back in last year. When I started doing my due diligence on fpv and UHF I noticed a lot were using 9c's and modules. I'm on spent rum and realize some issues it has with fpv so I looked around.
Again thanks guys for pointing out the range link. Is there any reason to get a UHF for a tricopter? I'm going to use it as my training device but I just don't see myself doing that far with it.
stgdz is offline Find More Posts by stgdz
Old Oct 09, 2012, 11:08 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
There are many reasons for UHF on a multirotor. 72MHz antennas are really long and there might not be a place to put it. 2.4 GHz is ok, but if you want to fly behind objects or use any frequency other than 5.8GHz for video, you can't use 2.4GHz for control. That leaves UHF as the only option.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Oct 09, 2012, 11:11 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by gundamnitpete View Post
His problem was a 1.5W TX (I cannot describe to you the utter amount of fail a 1.5w TX causes). Ditch the 1.5W TX, get a 200MW version.
The other problem is 2.4 radio. They just aren't great for FPV, although Futaba is probably the best to use if you want to stick to 2.4 control.
72Mhz with a good RX is easily capable of well over a mile. In many cases, 2 miles or more.
Please, do not let him get UHF yet. Get him a 200MW TX.
Pete hit the nail on the head. You know you are talking to a newbie when they mention TX power exceeding 1 Watt. I have seen Futaba go a mile repeatedly without issue with a 500mW 900MHz VTX onboard. Granted, this unit was from DPCAV and not HobbyKing which probably had something to do with it. He had plenty of video to go out even further with only an 8dbi patch on the ground. No tracker, no booster, nothing fancy.
-Alex
Old Oct 09, 2012, 11:14 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by iskess View Post
Bump. Alex, what do you think? Do I need to cut off my sma so I can attach the adapter, or can I use two adapters, or will that shift the freq too far.
Thank you
I think your only solution is to fly it out of tune. It shouldn't hurt you too much.
Old Oct 09, 2012, 11:31 AM
iskess is offline
Find More Posts by iskess
FPV in Hawaii
iskess's Avatar
United States, HI, Kailua
Joined Feb 2012
Would you care to venture a guess as to what my loss would be in db?
iskess is offline Find More Posts by iskess
Old Oct 09, 2012, 01:31 PM
FPV_Habu_Flyer is offline
Find More Posts by FPV_Habu_Flyer
United States, MN, Orono
Joined May 2011
Hi guys,
I had to balance out my plane by putting some weight in one wing. It is a very small metal nut, but I am concerned that it is only about a centimeter away from the end of my Dragonlink antenna. Is that going to be a problem or does metal not have any effect on antennas?
Jim
FPV_Habu_Flyer is offline Find More Posts by FPV_Habu_Flyer
Old Oct 09, 2012, 05:05 PM
Wettfeat is offline
Find More Posts by Wettfeat
"FPV"er not a "LOS"er
Wettfeat's Avatar
United States, NC, Charlotte
Joined Feb 2012
Lol you guys discriminate the 1.5W transmitter but I've had a lot of success with it!
I'm going to push it to the limits this weekend out in the country.
Wettfeat is offline Find More Posts by Wettfeat
Old Oct 09, 2012, 09:58 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I could only guess. Probably 2db or so. Nothing you are likely to notice.
-Alex
Old Oct 09, 2012, 10:14 PM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
United States, TX, Houston
I fly 1280 with 900mhz antennas all the time, and 900mhz with 1280 antennas on the time.
although that's only on the RX side, TX's always have an appropriate antenna.
gundamnitpete is offline Find More Posts by gundamnitpete
Old Oct 09, 2012, 10:46 PM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
This is because they do not know how to set up a plane properly.
A well set up plane can use 1.5 watt video tx no problem and do things lower watt video tx cannot.
Lower video tx like 200 mw works no problem but higher ones work better
If you fly small planes then smaller video tx is way to go to save weight as well as other factors
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Oct 09, 2012, 10:49 PM
David22 is offline
Joined Apr 2008
Try higher video tx for long range 3d
You will also be able to fly lower and longer with high video tx
-Alex
Old Oct 09, 2012, 10:50 PM
David22 is offline
Joined Apr 2008
With very small video tx antenna for speed and aerodynamic for plane go with high power video tx which is 2.4
I put video tx antenna inside plane or very very little exposed outside plane, about size of a servo cover, so actually no drag at all
Ground station antennas can be large but plane video tx antenna has to be smallest possible
Old Oct 09, 2012, 10:56 PM
David22 is offline
Joined Apr 2008
UHF antennas can be folded or shortened to 1/4 length so made very small and still go very far away
Been there done that
It's all about aerodynamics or in case of copter short antenna :
-Alex
Discussion Can this cam be used for FPV ? SpookiePower FPV Talk 11 Aug 16, 2016 11:08 PM
Discussion How to calculate flight time - guide ikorman Multirotor Talk 16 Jun 26, 2016 07:34 AM
Cool How cool would this be for FPV Kai_Shiden FPV Talk 4 Feb 18, 2016 08:02 PM
Discussion How many FPV pilots in the world? rbmaze FPV Talk 10 Aug 03, 2011 06:16 AM
Poll Would you be interested in buying Ready to Fly FPV airplanes from a new FPV store? FPVNOW FPV Aircraft 36 Oct 06, 2010 08:56 PM
