This thread is privately moderated by IBCrazy, who may elect to delete unwanted replies.
Old Oct 08, 2012, 02:31 AM
iskess is offline
Find More Posts by iskess
FPV in Hawaii
iskess's Avatar
United States, HI, Kailua
Joined Feb 2012
Originally Posted by stgdz View Post
So the other question I have regarding the UHF systems is about the OSD. When you get the UHF system do you have to get the corresponding OSD with it or can you get different stuff? I was looking at dragonlink as a farther down the road setup from 72mhz but does that mean anything for autopilot, osd, gps and incompatibilities?
The OSD and the UHF LRS have nothing to do with each other, you can mix and match brands. DragonLink will work with any OSD.
iskess is offline Find More Posts by iskess
Old Oct 08, 2012, 03:00 AM
iskess is offline
FPV in Hawaii
iskess's Avatar
Joined Feb 2012
Originally Posted by wavekatcher View Post
I've ordered my Skysurfer kit V1 and have been trying to figure out the preferred motor type for FPV flying.
Are there interference issues with an outrunner versus an inrunner?
Based on other's success in this thread, I am leaning towards the Eflite 6 series 2700kv with apc 6X4e prop.
thanks for any help
I don't have a Bix, so I can't give you great advice. Generally FPV favors efficiency for endurance. You want the largest prop you can fit for higher efficiency. I bet your kv is too high with that motor, it's gonna be a screamer. Loud means wasted energy. If a 6" is the biggest you can fit without hitting the boom, then consider more pitch so you can turn the prop slower.
I think the stock motor is like 2000kv, that seems better to me.
But you should really hit the Bixler thread where you will get more experienced answers rather than theoretical ones.
BTW, Inrunners are fine, but cost much more, so they are less commonly used in airplanes.
Old Oct 08, 2012, 03:39 AM
kokopropelli is offline
Find More Posts by kokopropelli
Crash....Fix......repeat.
kokopropelli's Avatar
United States, UT, Eagle Mountain
Joined Jan 2012
Skysurfer and Bix thread:
http://www.rcgroups.com/forums/showthread.php?t=1533848
kokopropelli is offline Find More Posts by kokopropelli
Old Oct 08, 2012, 08:35 AM
Flybynight2 is offline
Find More Posts by Flybynight2
Will it ever Fly?
Flybynight2's Avatar
United States, AZ, Beaver Dam
Joined Nov 2011
Originally Posted by Wettfeat View Post
You can always sell it to someone and get some money back. Just try to space your equipment apart. Distance is key when positioning receivers, transmitters, and such.
Thank You for the reply.
But, the problem I have is I can't find the information, to even put my system together.
The manual OSD manual is not very clear. (At least for me)
I need some step by step instructions on what goes where, with pictures.
Quite frustrated.
Flybynight2 is offline Find More Posts by Flybynight2
Old Oct 08, 2012, 02:25 PM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
Is there any UHF systems out there that work easily with spectrum radios? It would be nice to have one that plugs into the trainer port.
stgdz is offline Find More Posts by stgdz
Old Oct 08, 2012, 02:31 PM
ror1 is offline
Find More Posts by ror1
FPV'r
ror1's Avatar
Canada, ON, Carleton Place
Joined May 2011
I just connected this one to my DX8...works fine:
http://www.rangepiloting.com/index.p...bd9f79963511c4
I bought it second hand.
DX8 is off, plug UHF Tx PPM into trainer port and DX8 comes on.
plug 3S battery into UHF Tx power...led flashes
plug battery into plane and we have control...
ror1 is offline Find More Posts by ror1
Old Oct 08, 2012, 03:14 PM
elliott000 is offline
Find More Posts by elliott000
Canada, BC, Vancouver
Joined Feb 2012
Hey guys, If I add filters should I get filters on the video tx or rx.. or both?
Also is it worth filtering my 433mhz gear running 1.3 and or 900 mhz video
elliott000 is offline Find More Posts by elliott000
Old Oct 08, 2012, 03:35 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Generally, a filter is good to run on whatever has the lower frequency and that's it. If you use 433 control, that's where the filter goes. If you use 2.4GHz control and 1.3for video, use the filter on 1.3GHz video.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Oct 08, 2012, 05:17 PM
iskess is offline
FPV in Hawaii
iskess's Avatar
Joined Feb 2012
Bump. Alex, what do you think? Do I need to cut off my sma so I can attach the adapter, or can I use two adapters, or will that shift the freq too far.
Thank you
Originally Posted by IBCrazy View Post
Buy a really cheap N to SMA adapter. The cheap ones have an impedance mismatch that puts the antenna right on 1280MHz. The cheaper, the adapter, the better. Check EBAY.
-Alex
Thank Alex that is a creative solution no one else would have thought of!
Unfortunately it already came with SMA. Any other solution, or should I get an SMA to N and then another N to SMA adapter?
How much will this frequency mismatch affect my signal?
Old Oct 08, 2012, 09:44 PM
FPV_Habu_Flyer is offline
Find More Posts by FPV_Habu_Flyer
United States, MN, Orono
Joined May 2011
Hi guys,
I had to balance out my plane by putting some weight in one wing. It is a very small metal nut, but I am concerned that it is only about a centimeter away from the end of my Dragonlink antenna. Is that going to be a problem or does metal not have any effect on antennas?
Jim
FPV_Habu_Flyer is offline Find More Posts by FPV_Habu_Flyer
Old Oct 08, 2012, 09:49 PM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
United States, TX, Houston
Originally Posted by Mike Freas View Post
Today's experience reaffirmed my decision not to fly FPV with a fixed wing plane until I buy a dragon link or similar system.
No sir, you are very very wrong here.
One of my fellow fliers at the local flying spot came out with his FPV ship to fly under goggles for the first time. He is flying 900mhz with a 1.5Mw Tx. His radio is a Futaba 2.4.
His problem was a 1.5W TX (I cannot describe to you the utter amount of fail a 1.5w TX causes). Ditch the 1.5W TX, get a 200MW version.
The other problem is 2.4 radio. They just aren't great for FPV, although Futaba is probably the best to use if you want to stick to 2.4 control.
72Mhz with a good RX is easily capable of well over a mile. In many cases, 2 miles or more.
The only thing that saved him is the fact he had solid video the whole time. after landing we discussed buying a UHF system and he agreed. Crazy...
Please, do not let him get UHF yet. Get him a 200MW TX.
gundamnitpete is offline Find More Posts by gundamnitpete
Old Oct 08, 2012, 09:56 PM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
If you use proper components 1.5 watt has no effects on any component
It's the poor or should I say poor choice of components that limit you video tx out put choice
You will have better video with higher video tx
The only problem with high video,tx is the draw from battery is high
Choose proper components and high video tx works best
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Oct 09, 2012, 06:58 AM
Vintabilly_NS is offline
Find More Posts by Vintabilly_NS
..in a Johnny Cash voice.
Vintabilly_NS's Avatar
Canada, NS, Beaver Bank
Joined Aug 2010
I'm using a pair of Sid Huang RangeLink UHF systems. They came with the trainer port plug for my Dx6i. Plugs right in, had it bound in less than 5 min after the box was open. They also plug right into my Futaba trainer port with a slightly different cable. Pretty slick, no errors, no hassles. You'll need a 3 cell battery to power the UHF when using the Spektrum because it only runs on 4 AAs.
Vintabilly_NS is offline Find More Posts by Vintabilly_NS
Old Oct 09, 2012, 06:59 AM
Joined Aug 2010
Listen to this man's advice. He's right. Learn the path.
Old Oct 09, 2012, 08:46 AM
stgdz is offline
Volts>amps
stgdz's Avatar
Joined Jul 2011
Thanks guys on the range link suggestion. Here I thought I needed a module based system.
Saved me about 150-200 bucks. But why do people get the module based systems? Is it personal preference.
Cool How cool would this be for FPV Kai_Shiden FPV Talk 4 Feb 18, 2016 08:02 PM
Discussion How to calculate flight time - guide ikorman Multirotor Talk 15 Feb 01, 2015 10:12 PM
Discussion How many FPV pilots in the world? rbmaze FPV Talk 10 Aug 03, 2011 06:16 AM
Poll Would you be interested in buying Ready to Fly FPV airplanes from a new FPV store? FPVNOW FPV Aircraft 36 Oct 06, 2010 08:56 PM
Discussion Can this cam be used for FPV ? SpookiePower FPV Talk 8 Sep 12, 2010 07:12 AM
