-Alex |
Latest blog entry: Project Covert Ops: Long range ground...
Hello everyone. My very first post, ever!
I'm 39 and have wanted a real RC plane for a long time. Had no idea that the new foamies had brought the prices down so low, and now there's no long wait while you build a plane that can't survive one hard landing. I'm ready to get in the game. The thought of flying FPV with goggles miles away is very intriguing. I'm looking to get the plane set up and flying so I can figure out what FPV gear I need to do long distance someday. I'm going to order the HK EPP FPV because it seems to be the "standard", but have absolutely no idea what motor, prop, radio, battery, etc to use. I know I could search for hours and find a million different setups, but then I'd have no idea if any of it actually works together. Do any of you know of any build threads that worked out good that I could just copy? I'd like to just place an order with HK for all the pieces and then be done with it. Any help is most appreciated. Craig |
http://tienda.stockrc.com/FPV-Cockpit-EasyStar-I Here's a build thread with all the gear info you need: http://myrcguide.com/index.php?topic=14278.0 |
The thread on the HK EPP is here: http://www.rcgroups.com/forums/showthread.php?t=1577733 But if you want a first plane I think the HK Bixler is a much better choice, it's lighter more floaty, and will resist crashes better. It also is a plane that consumes much less power, so needs smaller batteries. |
Very interesting. Thank you both. I had the Bixler in my "shopping cart" at HK, but then read some threads about it being not particularly good for a beginner. Since it is RTF, I am very hopeful it would work out good for a 1st FPV and then be something I could upgrade over time. Anyone else with a vote for the Bixler?
Any recommendations for the 2nd Version of the Spyhawk, or is it more of a toy? |
I have researched the bixler quite well, it is a similar plane to one I have, the clouds fly, but a little bit bigger and slower, and better for fpv. For learning to fly these pusher planes are about as good as a first plane can be. For a beginner's fpv without need to carry too heavy equipment, the bixler should also be very good. Just don't expect it to be easy, and learn to fly without fpv first. The spyhawk is a similar plane, maybe good if you're willing to spend a lot more money, for a much smaller plane - just to get everything ready to fly out of the box. |
Martin |
Thanks ! From my limited knowledge I thought that also whip antennas are directional, will a patch antenna be more limited to direction than the basic ones ? It seems like from the antenna I looked at I will nearly double my range then, from a 3dBi to 8dBi. But if I need to point the antenna at the plane, it will not be of much use.. Maybe best to just order and test :-). IF I ever get flying weather. |
In fact they are! But in the vertical plane, not the horizontal plane. It depends on what your goal is. If you want to fly in all directions, 360 degrees around, high & low then a low gain is better. But if you want to go for distance, a high gain is needed (and/or a sensitive receiver).
To understand it better, have a look here: http://www.rcexplorer.se/Educational/gain/gain.html The amount of 'clay' corresponds with your vtx power. btw, even with a patch you can fly behind or aside the antenna, but not as far as in front of the patch. Martin |
After abandoning my Skywalker for more than a year due to unresolved noise issues (and unresolved questions), I hope to get it airborne again by rewiring everything and doing it right.
So I hope somebody can please help me with some questions: 1. When tapping power from a 1 lipo setup, is it better to do it near the battery or near the ESC, or doesn't it matter at all? 2. Is it best to not pass the ground wire through any sort of toroid anywhere in the whole system to avoid ground potential differences? 3. Would it be a good idea to add a few 220uF capacitors between the battery to ESC wires on the ESC side since the wires are quite long in a Skywalker? |
United States, TX, Arlington
Joined Apr 2012
So i highly reccomend it, very stable for fpv, and super cheap... |
| Thread Tools | |
| Discussion How to calculate flight time - guide | ikorman | Multirotor Talk | 11 | Dec 30, 2011 07:22 PM |
| Discussion How many FPV pilots in the world? | rbmaze | Video Piloting (FPV/RPV) | 10 | Aug 03, 2011 06:16 AM |
| Poll Would you be interested in buying Ready to Fly FPV airplanes from a new FPV store? | FPVNOW | Video Piloting (FPV/RPV) | 36 | Oct 06, 2010 08:56 PM |
| Discussion Can this cam be used for FPV ? | SpookiePower | Video Piloting (FPV/RPV) | 8 | Sep 12, 2010 07:12 AM |
| Cool How cool would this be for FPV | Kai_Shiden | Video Piloting (FPV/RPV) | 2 | May 11, 2009 07:41 PM |
