Joined Jul 2010
few of mine fpv flights from vacation ( montenegro )
bit windy cuz it was august :S
One question about basic electronics
I shielded my PPM wire from the Rx to OSD using metalic thinfoil adhesive paper (its conductive) but now someone told me that its useless unless i connect the metalic shielding covering to ground. Im thinking in using a solution wich is buy shielded stereo audio wire.. its a shielded wire with 2 wires inside and using the metalic shielding as ground.. people here reported good stuff with theese wires.. The thing is since the metalic covering is used as ground it will be coneected to ground in both RX (via PPM Encoder) and the OSD.. wich is like its now since the ground wire runs from one to another as with all wires.. But im my setup (Ikarus OSD) i use 2 batteries.. one feeds the regular stuff , ESC/motor , RX , Servos via te ESC's built in BEC (plane only uses 2 servos for control plus one for pan ) and then we have another battery for the FPV stuff wich feeds the OSD wich has an internal voltage regulator and throught it feeds the Video Tx, camera , OSD and GPS (and stabylizer if pressent).. Now the regular current goes throught the OSD as well (as Ikarus has autopilot function for PPM encoding meaning it can take direct control of servos meaning they are pluged into it) to the Rx and from there goes back also to servos throught the OSD.. this is the normal working of the system So the question is... can i have a common ground for both power sources tought they never "meet" each other (each feeds separated stuff and never the same item) Is true that if i shield "manualy" (thinfoil) a wire i must conect that shielding to ground or its useless? (that would explain why i still had some interferences on PPM chanel after sheilding) |
It is true that you need to ground the shield in order for it to be effective. The good news in your case though is that you should only ground the shield from one side, not both. Grounding both ends will create a ground loop which is not good. You can therefore avoid having a common ground, just connect the receiving end, the OSD ground to the shield.
Quick question about frequencies and trees. I'm using a 1.2ghz radio and a 5.8ghz Video system right now. It's working great, but obviously trees are a problem due to the 5.8gh video. Unfortunately, the area I live in is very wooded...trying to find open spaces without trees is very difficult. I'm going to quickly exhaust the locations that I can fly.
Should I eventually upgrade my setup to 900mhz? Do frequencies that low basically ignore trees, or will I still need to find a relatively un-wooded area to fly? |
Latest blog entry: CompareRC now has Amazon Products
![]() There is nowhere on earth with a sunset like western Kansas. And then in the summer time you get those awesome storms - I would love to FPV some of those... Did you know Kansas has over 800 different types of indigenous flowers? And, almost 500 kinds of birds! http://www.surfaceandsurfacephotogra...4kq5&lb=1&s=XL http://www.surfaceandsurfacephotogra...bRRp&lb=1&s=XL (WOW! I mean... really) |
![]() Yabba |
Im guess im fine them? actually i think i have no choice... FPV guys here recomended me using stereo wire shielded cable to make good shielded FPV wires.. so if i use it i have to conect both sides to ground since the shielding itself is ground.. and even if now i conect one of the sides only of the external shielding to one of the sides grounds.. its all connected anyway |
I''m putting together a shopping list to get my feet wet with FPV. I'm flying 10-42oz planes with a barnstorming mentality in small areas..we''ll see how that goes first time under the hood LOL. Thought I would start with a simple plane, so I put together a HobbyZone Super Cub with ailerons. (starting FPV in my Precision Aerobatics Ultimate Biplane would not be the way to go)
2.4Mghz control since that's what I have. goal is short distance so 5.8Ghz video I'm going to go with Fatshark goggles, either the Dominators for image clarity or new Attitude for a little larger FOV. I'm interested in action, not relaxing, so the more immersive FOV is attractive. Either set will allow 5.8Ghz receiver on board. Transmitter would be immersion RC. Either the 250mW or 600mW. Antenna, Blue Beam Whip set seems like the way to go for flying all around and at any attitude. Camera: NTSC, 3.6mm lense, need good light handling, this camers is 12V so it may or may not work on 3s...I jsut need a good camera that will send good detail óf what's darker below the treeline while the camera is exposed to sunlight above the treeline... http://www.readymaderc.com/store/ind...roducts_id=346 Any better suggestions on the camera. Please feel free to point me in another direction, I''m open to suggestions. I'm fine soldering. I want to buy good gear so I can get my feet wet. Scheduled to take the technicians test in 2 weeks. Jim |
I highly suggest looking into a set of EVG920 goggles rather than the FatSharks. While the FatSharks are popular, the image quality of the EVG920's is better. Use the Immersion Uno receiver. This is far superior to the built-in unit in the FatSharks.
Everything else looks pretty good to me. The 600TVL camera from RMRC is the best camera I ever used. It is truly top dog there. I always felt image quality to be most important to my enjoyment of the FPV experience. Thus, I make the above recommendations because that's what I personally use. -Alex |
Latest blog entry: Project Covert Ops: Long range ground...
| Thread Tools | |
| Discussion How to calculate flight time - guide | ikorman | Multirotor Talk | 11 | Dec 30, 2011 07:22 PM |
| Discussion How many FPV pilots in the world? | rbmaze | Video Piloting (FPV/RPV) | 10 | Aug 03, 2011 06:16 AM |
| Poll Would you be interested in buying Ready to Fly FPV airplanes from a new FPV store? | FPVNOW | Video Piloting (FPV/RPV) | 36 | Oct 06, 2010 08:56 PM |
| Discussion Can this cam be used for FPV ? | SpookiePower | Video Piloting (FPV/RPV) | 8 | Sep 12, 2010 07:12 AM |
| Cool How cool would this be for FPV | Kai_Shiden | Video Piloting (FPV/RPV) | 2 | May 11, 2009 07:41 PM |
