This thread is privately moderated by IBCrazy, who may elect to delete unwanted replies.
Old Aug 18, 2012, 07:15 PM
AussieHoppy is online now
Find More Posts by AussieHoppy
what goes up, must come down..
AussieHoppy's Avatar
Joined May 2010
Originally Posted by mclarkson View Post
I was talked into going to a local casino. I wound up winning $580 at poker. I just sent it off to ReadyMadeRC.
Your results may vary.
OMG that made me laugh!!
and a distinct inference that our hobby has greater personal financial impact than gambling...
AussieHoppy is online now Find More Posts by AussieHoppy
Old Aug 18, 2012, 08:29 PM
Wettfeat is offline
Find More Posts by Wettfeat
"FPV"er not a "LOS"er
Wettfeat's Avatar
United States, NC, Charlotte
Joined Feb 2012
Originally Posted by Yabba View Post
Gee, I'm scared to post this here after the little whoop de do a few posta ago but someone mentioned Corona receivers a few days ago.
I have a couple for sale http://www.rcgroups.com/forums/showthread.php?t=1713255 if anyone is interested.
Yabba
Are they the older ones that are good for FPV? How far have you flown on them. I'd be interested in the whole lot.
Wettfeat is offline Find More Posts by Wettfeat
Old Aug 18, 2012, 09:19 PM
Plexabit is offline
Find More Posts by Plexabit
Unregistered User
Plexabit's Avatar
United States, KS, Andale
Joined Apr 2012
Maybe that's the way to go.
"You want to buy a lottery ticket?"
"I don't believe in gambling."
"I bet I can change your mind."
"You're on."
"Pay up."
For now, I'll stick with the whole job thing.
Plexabit is offline Find More Posts by Plexabit
Old Aug 18, 2012, 10:32 PM
Yabba is offline
Find More Posts by Yabba
Gravity - It's the law
Yabba's Avatar
USA, CO, Denver
Joined Jul 2008
Sorry, they are sold and thread marked closed.
Yabba
Yabba is offline Find More Posts by Yabba
Old Aug 19, 2012, 12:42 AM
AVIATION_RULZ is offline
Find More Posts by AVIATION_RULZ
Canada, BC, Surrey
Joined Feb 2011
Just a couple of quick questions about LCD displays:
1) I am looking for something that's approx. 17 inches. Is there any out there that is tested, reliable, and won't break the budget?
2) Also, what should I be using as a power source for a screen of this size?
AVIATION_RULZ is offline Find More Posts by AVIATION_RULZ
Old Aug 19, 2012, 01:19 AM
EdenSmith123 is offline
Find More Posts by EdenSmith123
Joined Aug 2012
I have a 1.2Ghz system and I just ordered a dragonlink 433mhz LRS. After ordering it, I realized that the 3rd harmonic of the LRS may interfere with the video frequency. My video RX does NOT have a SAW filter BUT I do have a couple of Low Pass filters laying around. I have a 433mhz Low Pass filter and a I also have a 1.2Ghz Low Pass filter laying around.
1) If I use these, will they help the situation and reduce interference?
2) If I were to use these.... where would I place them??
thanks in advance for your help fellas!
EdenSmith123 is offline Find More Posts by EdenSmith123
Old Aug 19, 2012, 03:07 AM
THOMASJONES is offline
Find More Posts by THOMASJONES
Closed Account
Joined May 2011
hi all,
I think it's time for an upgrade on my fatshark base goggles but I'm a little unclear about the whole concept. With the base goggles, I was able to directly plug the video Rx to the goggles using the 6-pin connector which was supplied. Now, with the Dominator goggles, I've noticed there is a 5.8ghz antenna attached to the goggle. Does this mean I can't directly connect the 6-pin connector anymore? I don't want to go wireless on my video goggles.
THOMASJONES is offline Find More Posts by THOMASJONES
Old Aug 19, 2012, 03:59 AM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
[Simplest is to use ferites on coaxes
for ground station
Separation will just eventually make thing complicated and painto set up
There are threads and posts on how to eliminate UHF video interference and keep things close
All ground and plane set ups are best when all is close to each other
Separation just is not the good ideal way
It's not complicated and easy done
You put stuff out on wings and create crap flying plane
Put stuff out on ground station and waste time and money
Ideal situation is put things nice and close and still fly long range
I will one day make video on how it is done proper
QUOTE=IBCrazy;22465074]The best thing to do is move your UHF transmitter as far away as possible. CP isn't going to fix the loud UHF system issue. What I tend to do is use a low power repeater. A small 25mW 5.8GHz tansmitter/receiver combination will repeat the signal from your 1.3 system to a small 5.8GHz rx. No fancy antennas needed for this either. If you opt for the 100mW fatshark transmitter, I suggest you also use an attenuator of ~6db to cut down on the interference from it.
-Alex[/QUOTE]
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Aug 20, 2012, 02:53 AM
williamjames is offline
Find More Posts by williamjames
United States, FL, Miami
Joined Jun 2011
I'd like to get some clarification please as to what the difference is between watts vs. thrust. Here's where the question stems from. I have a Bixler with a 6 inch prop, wanting to upgrade to a 8 inch prop. On my current setup, I'm getting 305 Watts of power (not sure how many grams of thrust) on a 6 inch prop with a 2200kv outrunner motor drawing 27amps WOT. The prop and motor combo I'd like to use is a 1500kv motor on a 8x4 prop. But according to the specs on this new motor (http://www.flybrushless.com/motor/view/194) ... I am getting only 202 watts BUT 988grams of thrust at 19amps WOT. Both planes would be using a 3S 2200mah battery.
I am using my bixler for FPV and so I need something that will be effiecient in amp draw and can comfortably push a heavy plane. I couldn't care less for speed... just something that will get me to altitude really quick.
Based on this information... what would you guy's suggest??
williamjames is offline Find More Posts by williamjames
Old Aug 20, 2012, 06:58 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Larger props produce more thrust and less speed per watt than a smaller prop.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Aug 20, 2012, 07:35 AM
Wettfeat is offline
Wettfeat's Avatar
Joined Feb 2012
Well here is my brand new ground station! Makes it a lot easier to carry my stuff back behind to the school where I fly.
I have a question as well. I've been considering Dragon Link but I think it might be too much for me. What would be the best 72mhz receiver for FPV. I've looked around and I know the older Corona's are good but now the newer ones aren't. I was looking at the R168DF by Futaba. Is that a good choice?
Old Aug 20, 2012, 12:32 PM
Closed Account
Joined May 2011
Anyone...?
Originally Posted by THOMASJONES View Post
hi all,
Old Aug 20, 2012, 01:49 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
hi all,
My Dominators have a 6-pin port. However I just use them for a repeater. Much more fuin to be wireless.
-Alex
Old Aug 20, 2012, 01:52 PM
Joined Jun 2011
-Alex
Okay, so this was something I was wondering about too. If I have a 1.2ghz video system (Tx/Rx)... does that mean that I can't use the wireless portion because I'm on a different frequency?
Old Aug 20, 2012, 03:56 PM
Cervanchez is offline
Find More Posts by Cervanchez
Habitual Line Stepper
Cervanchez's Avatar
United States, WA, Redmond
Joined Dec 2011
Anyone...?
They also have a 3.5 mm AV jack (like a headphone jack) that can connect direct to an external receiver.
Cervanchez is offline Find More Posts by Cervanchez
Discussion How to calculate flight time - guide ikorman Multirotor Talk 16 Jun 26, 2016 07:34 AM
Cool How cool would this be for FPV Kai_Shiden FPV Talk 4 Feb 18, 2016 08:02 PM
Discussion How many FPV pilots in the world? rbmaze FPV Talk 10 Aug 03, 2011 06:16 AM
Poll Would you be interested in buying Ready to Fly FPV airplanes from a new FPV store? FPVNOW FPV Aircraft 36 Oct 06, 2010 08:56 PM
Discussion Can this cam be used for FPV ? SpookiePower FPV Talk 8 Sep 12, 2010 07:12 AM
