Latest blog entry: Project Covert Ops: Long range ground...
Any antennas I make is tuned to cover the band as it is labeled. 1280MHz centers at 1280MHz, 2.4GHz centers at 2430MHz, 5.8GHz centers at 5780MHz.
-Alex |
United States, MI, Grand Rapids
Joined Oct 2011
You misunderstood. Its saying the Bluebeam antennas are going to increase performance over the stock whip antenna that came on your Tx and Rx. CP antennas are not considered Whip antennas. |
United States, MN, Orono
Joined May 2011
Hi guys,
I'm trying to hook up my GoPro to my FPV plane and it works now. However, I'm trying to figure out how to use my 3s airplane battery to power it and remove the GoPro's battery. I was told to hook it up to my receiver. So my questions are: -How do I power the GoPro to my Dragonlink? The GoPro input is 5v, which should work fine with a Dragonlink, right? -If the airplane runs out of power, does that mean I will instantly loose picture? Thanks for the help, Jim |
If you need one, I have a 5V 5A uBEC from hobbyking. It doesn't have heat shrink on it. I took it off to look at the chips. It is using two switching power supplies in parallel, without diode ORing as far as I can tell, and in a configuration that is not mentioned in the datasheet. However, there may be a whitepaper somewhere describing the hobbyking configuration. You can have it if you want it. You could also seperate the two boards that are on it with a soldering iron or even wire clipper (probably wrecking the wire cutter in the process, since you'd be cutting the stand offs), and get a 5V 3 amp BEC...which is consistent with the datasheet for the switching power supply controller populated on the card. Even 3 amps should be plenty for the gopro. If you want one with the heat shrink, I can sell you one for cost. I also have a Turnigy Watt meter which if you don't have is a good deal. Will sell you for cost...say $31. |
Latest blog entry: Rusty Thumbs on 3DHK Slick 360
What the hell? Sell your junk so where else.
Habu, Check this thread out I'm sure they'll help you out. http://www.rcgroups.com/forums/showt...ighlight=gopro |
Australia, QLD, Toowoomba
Joined Jul 2012
If you look closely, you will see that 5780 fits neatly in between Ch4 and Ch5 in your list - ie in the center of your channels. The antenna will work for all of your channels, but will probably work best on Ch4 or Ch5, which are closest to its tuned frequency. |
My FPV flights with Skywalker Sirius.
Impeccable FPV flight at sunset. Fly over people on the road. In height. Meeting with the real plane in the air. Beautiful landing.
The same flight recorded with keychain cam #16V2 placed on pan and tilt system of FPV camera.
Good evening FPV flight at an altitude with a relaxed landing with RC model airplanes Skywalker Sirius. After about 10 minutes of relaxing flight had to land because the battery started to occur in radio ...
Equipment: Skywalker Sirius FPV airplane. FatShark Predator 5.8 GHz. VTX ImmersionRC 600 mW 5.8 GHz. Sony Super HAD CCD 600TVL, Lens 2.8 mm. Super Simple Mini OSD. Clover Leaf & SkewPlannar 5.8 GHz Antennas. Turnigy 9X 9Ch Transmitter w/ Module & 8ch Receiver (Mode 2), ER9x Firmware. Pan & Tilt. |
Joined Jul 2011
| Thread Tools | |
| Discussion How to calculate flight time - guide | ikorman | Multirotor Talk | 11 | Dec 30, 2011 07:22 PM |
| Discussion How many FPV pilots in the world? | rbmaze | Video Piloting (FPV/RPV) | 10 | Aug 03, 2011 06:16 AM |
| Poll Would you be interested in buying Ready to Fly FPV airplanes from a new FPV store? | FPVNOW | Video Piloting (FPV/RPV) | 36 | Oct 06, 2010 08:56 PM |
| Discussion Can this cam be used for FPV ? | SpookiePower | Video Piloting (FPV/RPV) | 8 | Sep 12, 2010 07:12 AM |
| Cool How cool would this be for FPV | Kai_Shiden | Video Piloting (FPV/RPV) | 2 | May 11, 2009 07:41 PM |
