I replaced the R137F Futaba Rx with a Corona RP8D1 to see if the situation improves.. now while doing it i meassured both antennas.. all being in 35mhz (with the exact frequecy being channel 80 or 35.200) the RP8 antenna is exactly 105cm long wich coincides with what should.. but then the Futaba Rx antenna is just 98cm long (all measured brom the board not exterior case).. and then extracted the Futaba 7C telescopic antenna and.. oh surprise.. its 95cm.. its confising but somehow both Futaba antennas doesnt seem optimal for 35mhz.. in 1/4 wavelenght for 35mhz its said here: http://www.fpvuk.org/forum/index.php?topic=935.0 that idead lengh for antenna would be 211.4cm .. in the case of 35.200 channel 80 35.200 213.07cm 426.14cm Or 116.54cm tought i understand there are tolerances here.. my antenna extension is 110cm wich added to the Futaba 98 makes a total of 218cm.. maybe i went a bit longer than recomended.. i can allways trim it down for the Corona . Anyone here using the Corona? does it make good FPV Rx? |
Hi,
I just replaced my two Chinese receivers with two 1,2Ghz Lawmate receivers. Unfortunately I had a nasty surprise because I can see a good signal but only in black and white. My Vtx transmitter comes from SunSky and is on ch9 (1280Mhz). Lawmate receiver is on ch8 (1280Mhz) because I put down the Dip-switch 8. Then I use antennas tuned on 1280Mhz. Before to change the transmiter the signal was good and in color.. now is good but in black and white. I can not explain why. Can you help me ? |
http://www.amazon.com/VideoSecu-Dete...words=mini+dvr It's a few dollars over your range but works great for me. Its small and more portable than a laptop. |
has features we do not need |
is it reliable? what quality is the playback recording? does it record through static/video loss? the only thing i dont like is the bnc fittings, but a minor inconvenience ![]() a friend of mine needs a dvr, if you personally recommend this dvr, i will let him know I am curious because i have tried a few altenatives, from baru laptop HDD recorders to dvd burners, the only dvr to date that has actually worked flawlessly has been the Japan-FPV dvr http://www.readymaderc.com/store/ind...bfvihb7l7k3dj4 has a small lcd display (that I have actually flown home on) and rca plug lead (plugs straight into my Oracle or vRx), powered by a rechargable battery (totally portable) and continues recording through static continuously, it has been great for me but at $199 it may not suit everyone's price range... for me, I was tired of unreliable recording Quote:
| Thread Tools | |
| Discussion How to calculate flight time - guide | ikorman | Multirotor Talk | 11 | Dec 30, 2011 07:22 PM |
| Discussion How many FPV pilots in the world? | rbmaze | Video Piloting (FPV/RPV) | 10 | Aug 03, 2011 06:16 AM |
| Poll Would you be interested in buying Ready to Fly FPV airplanes from a new FPV store? | FPVNOW | Video Piloting (FPV/RPV) | 36 | Oct 06, 2010 08:56 PM |
| Discussion Can this cam be used for FPV ? | SpookiePower | Video Piloting (FPV/RPV) | 8 | Sep 12, 2010 07:12 AM |
| Cool How cool would this be for FPV | Kai_Shiden | Video Piloting (FPV/RPV) | 2 | May 11, 2009 07:41 PM |
