Another option is the time base corrector. |
Latest blog entry: Project Covert Ops: Long range ground...
FPV Pilot "Training"
I am teaching our daughter how to fly FPV. I hope you find this interesting and useful. It is a work in progress.
Here was my son's log four years ago... He's a huge help in teaching his sister. |
Latest blog entry: Travel Quad
If you're worried about the camera, then simply test without it.
Unplug camera, power up Tx and Rx verify that you're getting a clean black screen and go fly the plane a couple hundred yards away visually and see if the black screen turns noisy. If it does, it's probably external interference. Go to some very rural area and repeat the test. If it's clean, then there's your problem. At my home flying site overlooking the city, I can't fly on 900Mhz band more than 150 meters without crippling noise. In some areas of the suburbs with less visibility to the rest of the city, that goes up to a mile or so. Out in the mountains 30 miles from the ciy, flying 2+ miles away is no problem. The other place to look is at the SMA connector on the end of the patch cable. I've had numerous SMA connectors tear away from the shield ground over time and then they have to be replaced. When it happens though the connector will feel a bit loose (it may turn when it's not suppose to). ian |
Latest blog entry: My 2012 FPV year in Review
Oh, now I know your problem! It's the "blue screen of death". You never got static did you? Just went black suddenly. Sadly, this is very common with modern screens. you need a filter or some device to generate a sync signal or a screen that shows static rather than going black on you.
What happens is the when the signal begins to weaken even slightly, the video signal amplitude begins to drop. The threshold of most devices to go blue/black screen is actually quite high. Thus you get a black screen well before signal is lost. -Alex |
Simple question.
At the 100m distance you mentioned earlier, do you see static, or blue screen? ian |
He swapped his 7"LCD for an old 19" TFT television screen that did not go blue on loss of signal and the transformation was immediate! he could go the same distance than me. Now he flies on goggles. Another thing, some receivers need a ground plane to improve reception. try laying down the receiver on the floor and see if this makes it better. |
Latest blog entry: Airframes
Be aware that he has a great deal of experience at FPV. Not saying a new person can't do it, but it's always good to start simple and work your way up to more complicated setups. ![]() Check this for some cool stuff > http://www.rcgroups.com/forums/showthread.php?t=622190 ...and this.... F-16 cockpit flying! > http://www.rcgroups.com/forums/showthread.php?t=1111348 |
Joined Mar 2009
http://www.rcgroups.com/forums/showthread.php?t=1312788 |
Heres an example of a complete system with color coded heat shrink, to prevent wrong connections. (micro size but still the same ideas) http://www.rcgroups.com/forums/showp...postcount=1207 |
| Thread Tools | |
| Discussion How to calculate flight time - guide | ikorman | Multirotor Talk | 11 | Dec 30, 2011 07:22 PM |
| Discussion How many FPV pilots in the world? | rbmaze | Video Piloting (FPV/RPV) | 10 | Aug 03, 2011 06:16 AM |
| Poll Would you be interested in buying Ready to Fly FPV airplanes from a new FPV store? | FPVNOW | Video Piloting (FPV/RPV) | 36 | Oct 06, 2010 08:56 PM |
| Discussion Can this cam be used for FPV ? | SpookiePower | Video Piloting (FPV/RPV) | 8 | Sep 12, 2010 07:12 AM |
| Cool How cool would this be for FPV | Kai_Shiden | Video Piloting (FPV/RPV) | 2 | May 11, 2009 07:41 PM |
