This thread is privately moderated by IBCrazy, who may elect to delete unwanted replies.
Old Jul 01, 2012, 05:50 PM
ror1 is offline
Find More Posts by ror1
FPV'r
ror1's Avatar
Canada, ON, Carleton Place
Joined May 2011
Originally Posted by iCrap View Post
I think i will go with 5.8ghz, because i am using 2.4ghz radio gear.
So looking on the ReadyMadeRC Site i found this.
Standard Whip Antennas (I will probably make IB Crazy Cloverleaf ones or something, but later)
Camera (None, cause i ordered the 600TVL)
TX (FatShark 100mW 5.8Ghz)
Rx - Uno5800
Batteries 1100mAh RMRC Batteries for Tx / Rx
Total on that is $113 - I got this from choosing the 5.8ghz kit and removing / adding some options. Like i said i'm not sure about the vTx and vRx.
OSD I will worry about later, i will only do LOS for now.
For the video display i will use a USB capture card and then i will display it on my laptop, for now anyways. If that dosen't work i can just use one of my old monitors / tvs or something.
They say using laptop is too much video delay to be usable...You can use it to record but not as live video feed to pilot plane......that is what they say in many threads...
ror1 is offline Find More Posts by ror1
Old Jul 01, 2012, 07:10 PM
iCrap is offline
Find More Posts by iCrap
iCrap's Avatar
United States, MD
Joined May 2012
I already have the video cap card which i have used for other things, there is no delay as far as i can tell. Anyways if it dosen't work il just use something else.
I need to know if ive got the right parts on my list though before i even worry about that though...
iCrap is offline Find More Posts by iCrap
Old Jul 01, 2012, 10:54 PM
sammyc is offline
Find More Posts by sammyc
I need a bigger shed..
sammyc's Avatar
Australia, TAS, Launceston
Joined Nov 2011
I can comment about cap cards.
I had an easycap clone (~$8 ebay) and it actually worked quite well. No noticeable lag at all, high quality, and as I already had a laptop it kept my costs down. This was on a current spec windows 7 laptop btw, it seems to work quite well on older machines too.
The problems are long setup times, having to rely on an operating system and problems that can arise like crashes, popups, low battery, and also can be a little bulky to transport.
In the end, setup times and complications made me switch to a 9.5in LCD and SD card DVR.
sammyc is offline Find More Posts by sammyc
Old Jul 01, 2012, 11:45 PM
iCrap is offline
iCrap's Avatar
United States, MD
Joined May 2012
Thats what i thought, Anyways i will give it a try and if not il just get some other display.
Can anybody comment on my parts list? Any changes i should make?
Old Jul 02, 2012, 07:40 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Alright, should i do the bluebeam whip for 50 bucks more?
Is the vTx and vRx i picked good / decent?
Yes, the video tx/rx is good. But if you feel so ambitious, feel free to make your own antenna sets. I am here to support you however I can.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Jul 02, 2012, 08:59 AM
iCrap is offline
iCrap's Avatar
United States, MD
Joined May 2012
-Alex
Thanks.
I think what i will do is just get the stock antennae instead of the bluebeam, but then i will make my own using one of the examples posted here.
Old Jul 02, 2012, 10:30 AM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Originally Posted by wilem View Post
if you are responding to me the problem was not being able to find a connector to make into an antenna for this male connector. so i gave it a sex change.
Okay, now I understand. I didn't know if the problem was an intermittent connection, crappy dielectric, or what. Now I understand.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Jul 02, 2012, 12:44 PM
ror1 is offline
FPV'r
ror1's Avatar
Joined May 2011
which DVR?
does it go blue screen on bad video?
Old Jul 02, 2012, 08:00 PM
flye is offline
Find More Posts by flye
Joined Sep 2010
^That's a very poor video transmitter. I have several I use for testing. You must keep it in the full enclosure or it will burn up. In the 1.2GHz thread, I did a video review of it. I was unimpressed with it an now use the equipment from Future Hobbies and Urban Drones.
-Alex
I have made some range test and this tx eat completely my frsky!Is it possible that it's worst than a less cheap one for rc
Since I have to buy another video kit is it a good choice to go to 5.8 for a 1.5 km with your bluebeam ?
flye is offline Find More Posts by flye
Old Jul 02, 2012, 08:38 PM
jayb1rdz is offline
Find More Posts by jayb1rdz
Never fly an A model anything!
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
Noiw this may seem simple to some of you guys....but I don't want to get lost. I have had many successful flights in familiar areas but now I am using an OSD for new adventures
Here is a typical screen shot of the OSD I am using.
What I don't understand is the relationship between the "Angle of Returning to Home - 16" and the "Direction to Home Point -19" One says you turn left and the other says right. I am having a major senior moment....and I'm not ready for it yet !
Even when I draw the degrees on a Compass... it doesn't make sense to me.
jayb1rdz is offline Find More Posts by jayb1rdz
Old Jul 03, 2012, 12:59 AM
digitalCAM is offline
Find More Posts by digitalCAM
John
United States, WA, Mason
Joined Apr 2011
Jay, it looks to me like it says you are on a compass heading of 18deg and you have to come to a compass heading of 22deg to be going home (turn right). Maybe the arrow at the bottom is supposed to be your "plane" and not the "direction to home". In other words, maybe it is showing that you plane is pointing to the left of home and you must go right to be pointing at home. -- just guessing, JOHN
digitalCAM is offline Find More Posts by digitalCAM
Old Jul 03, 2012, 02:00 AM
jayb1rdz is offline
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
Thanks John, That makes some sense.
So if I had the "H" directly at 12o'clock to the arrow, I would be heading straight home.... I need to watch a video download to see how the two relate
Old Jul 03, 2012, 09:39 AM
IMEIV is offline
Find More Posts by IMEIV
The way of being is doing.
IMEIV's Avatar
Italia, Emilia Romagna, Ravenna
Joined Apr 2009
I would know what's the difference between Cloverleaf Antenna and BluBeam 3lobe TX antenna ?
Someone can help me ?
IMEIV is offline Find More Posts by IMEIV
Old Jul 03, 2012, 09:46 AM
MASHTON is offline
Find More Posts by MASHTON
United States, VA, Madison Heights
Joined Aug 2011
The Cloverleaf is the name of the 3 lobe antenna that was designed by IBCrazy. Blubeam is the product name given to the Cloverleaf/Skew-Planar Wheel antennas built and sold by IBCrazy's Company Video Aerial Systems.
MASHTON is offline Find More Posts by MASHTON
Old Jul 03, 2012, 09:51 AM
IMEIV is offline
IMEIV's Avatar
Joined Apr 2009
Do you tell that change only the name ?
Cool How cool would this be for FPV Kai_Shiden FPV Talk 4 Feb 18, 2016 08:02 PM
Discussion How to calculate flight time - guide ikorman Multirotor Talk 15 Feb 01, 2015 10:12 PM
Discussion How many FPV pilots in the world? rbmaze FPV Talk 10 Aug 03, 2011 06:16 AM
Poll Would you be interested in buying Ready to Fly FPV airplanes from a new FPV store? FPVNOW FPV Aircraft 36 Oct 06, 2010 08:56 PM
Discussion Can this cam be used for FPV ? SpookiePower FPV Talk 8 Sep 12, 2010 07:12 AM
