From what I recall, part 15, at least for WiFi, are tested with a specific antenna. Swapping antennas by the consumer is discouraged by requiring manufacturers to use non-standard antenna connectors when the product has a removable antenna. Many manufacturers use non-standard reverse polarity antennas for wifi. Of course, the RP-SMA became a defacto standard, and people swap out their antennas in practice.
Latest blog entry: Rusty Thumbs on 3DHK Slick 360
for what you want to do the 5.8 200 mw with some of alexs antennas would be awesome. my HK was going out to 7000 feet on stock whips. i did loose it but i wasnt anything to do with the video link. the problem is the connectors are backwards.. you'll have to order some off ebay and i hear those have some loss in them.
Joined Jan 2012
Need some advise on antenna selection for •1.3GHz 300mW vtx.I have this vrx
1.3GHz Receiver with Upgraded SAW Filter with 1.3GHz Optimized 8dBi Patch Antenna - SMA Male. Only plan on flying 1mile or so. Was considering one of these. http://www.readymaderc.com/store/ind...roducts_id=838 http://www.readymaderc.com/store/ind...roducts_id=301 http://www.readymaderc.com/store/ind...roducts_id=503 Your advise will be appreciated Best Mike |
For a mile, Get a BluBeam antenna set and forget the patch antenna. You don't need it. You also don't need the upgraded SAW filter. 1 mile is a walk in the park for 1.3GHz. I would recommend the 400mW VTX, though. I really like mine.
If you already have the Vee antenna, a patch will do well for you. You could still do the Blubeam set, but the patch is cheaper and far more than you will need staying inside 1 mile. -Alex |
Latest blog entry: Project Covert Ops: Long range ground...
Joined Sep 2010
but to avoid someone else make the same bad buy would it be possible to modify post on page 16? Just to keep your usefull thread to date for those like me who will not read all post and make a search for vtx |
Joined Sep 2010
I was flying a quad with 800 mw sunsky with self made inverted vee and stock whip on rx with spectrum dx8 and as expected rc link was weakest point
I am now trying tx9 with frsky for rssi to see. Planning to build CP Knowing I like low altitude10-100 feets which kit should I upgrade to? From future hobbies (Our 1000mW, 1.3GHz transmitter & Receiver Set, is the perfect match for your next Long Range FPV Project and will not interfere with 2.4GHz RC Systems) is it true and good? Or just a replacement tx?Which one is better for me? Thanks Claude |
Too much attention is paid to the transmitter and not enough attention is pad to the receiving end. The Future hobbies VRX is VERY sensitive and thus is capable of long distances. However, due to the very sensitive system, UHF control tends to cause video signal weaknesses. If you use 2.4GHz control, you have no business using such a high power system. You will have perfect video all the way down to impact due to loss of control. -Alex |
-Alex |
Joined Jan 2012
MIke |
Good catch! That used to be the old 700mW transmitter that I really liked. They replaced it with a really poor unit... So sad...
| Thread Tools | |
| Discussion How to calculate flight time - guide | ikorman | Multirotor Talk | 11 | Dec 30, 2011 07:22 PM |
| Discussion How many FPV pilots in the world? | rbmaze | Video Piloting (FPV/RPV) | 10 | Aug 03, 2011 06:16 AM |
| Poll Would you be interested in buying Ready to Fly FPV airplanes from a new FPV store? | FPVNOW | Video Piloting (FPV/RPV) | 36 | Oct 06, 2010 08:56 PM |
| Discussion Can this cam be used for FPV ? | SpookiePower | Video Piloting (FPV/RPV) | 8 | Sep 12, 2010 07:12 AM |
| Cool How cool would this be for FPV | Kai_Shiden | Video Piloting (FPV/RPV) | 2 | May 11, 2009 07:41 PM |
