This thread is privately moderated by IBCrazy, who may elect to delete unwanted replies.
Old Jun 27, 2012, 10:08 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Will that camera work with the sunsky 800 mW 1.2 Ghz vTX?
What about with OSD?
Just trying to figure out what effect the 600 TVL might have with some vTX/OSD/Displays.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Jun 27, 2012, 10:35 PM
baconflyer is offline
Find More Posts by baconflyer
cheapskate extroardinairé
United States, CA, Marin
Joined Jul 2011
hey guys, here is my situation:
looking to set up a short to mid range (maybe 1km) fpv system.
already have camera
budget: preferably under $80
baconflyer is offline Find More Posts by baconflyer
Old Jun 27, 2012, 10:49 PM
sammyc is offline
Find More Posts by sammyc
I need a bigger shed..
sammyc's Avatar
Australia, TAS, Launceston
Joined Nov 2011
already have camera
Have to assume you already have airframe and RC gear, that doesn't leave you with much left after buying a video tx/rx.
If you have 2.4GHz RC, you should use 5.8GHz video, so you will have to make your own circular polarized antennas with that budget.
Also, what about viewing screen/goggles, have them already?
Really need more information then you have provided.
sammyc is offline Find More Posts by sammyc
Old Jun 27, 2012, 11:07 PM
MASHTON is offline
Find More Posts by MASHTON
United States, VA, Madison Heights
Joined Aug 2011
Yes it will work. The camera will have no effect on the equipment. You will want to wrap the wires through a torroid about 5 times to reduce its noise level if you are using UHF I would do this regardless of any factors just as CYA.
MASHTON is offline Find More Posts by MASHTON
Old Jun 28, 2012, 12:14 AM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Thanks Mashton, just ordered one.
Old Jun 28, 2012, 12:28 AM
iCrap is offline
Find More Posts by iCrap
iCrap's Avatar
United States, MD
Joined May 2012
I didn't get an answer to my previous post... what 5.8ghz system should i get for around / under $200?
Like i said, i was looking at this but im wondering what else i can get that might be a little better or something
http://www.readymaderc.com/store/ind...roducts_id=309
iCrap is offline Find More Posts by iCrap
Old Jun 28, 2012, 01:41 AM
Joined Jul 2011
already have a homemade video hat, have a plane as well. trying to find a tx/rx with around 1-2km range for under $80 (i checked hobbyking, problem is that everything is out of stock.)
Old Jun 28, 2012, 02:05 AM
sammyc is offline
sammyc's Avatar
Joined Nov 2011
The 200mW 5.8GHz tx/rx sold on hobbyking, himodel, foxtech etc is good, I think ~$60.
I don't know how skilled you are with a soldering iron, but making your own cloverleaf and skew planar wheel antennas should get a over 1km range if your setup is done well. 2km might be a stretch with untuned antennas. You will not get 1km on the stock rubber ducky antennas with 5.8GHz.
Remember other stuff you will need to factor into budget, you will need some oddities that may include servo wire, connectors, bits to make filters etc.
Old Jun 28, 2012, 04:24 AM
Martin7182 is offline
Find More Posts by Martin7182
Wallop!
Martin7182's Avatar
Bussum, Netherlands
Joined Oct 2009
Baconflyer, have a look at bare tx/rx airwave modules from www.nghobbies.com
http://www.nghobbies.com/cart/index....th=1_10_82_131
For around $40 you have a tx/rx combo that performs well. Needs a few external components to solder though.
Martin
Martin7182 is offline Find More Posts by Martin7182
Old Jun 28, 2012, 08:38 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
First: FPV is not cheap. Buy cheap, buy twice.
If you only have $200 to spend, save it until you have enough for a good starter set. The camera and the antennas are the most important part of your FPV system. The system you pointed out and anything sold by HobbyKing is going to have junk antennas and camera.
You can build your own antennas following the tutorial in my blog. Even if you make them poorly, they still work incredibly well. The best camera out there is the 600TVL from security camera 2000. It runs about $52 and it is worth every penny.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Jun 28, 2012, 10:51 AM
flye is offline
Find More Posts by flye
Joined Sep 2010
Originally Posted by IBCrazy View Post
Nope. It is SMA
HI,I have received my vtx and I think it's a new design it has rpsma and rx sma
Its a lot bigger without enclosure and no small case
Is it what you use?
I used to mount my last(lost) one on an arm to cool it but its inpssible witch this one!
flye is offline Find More Posts by flye
Old Jun 28, 2012, 11:04 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
^That's a very poor video transmitter. I have several I use for testing. You must keep it in the full enclosure or it will burn up. In the 1.2GHz thread, I did a video review of it. I was unimpressed with it an now use the equipment from Future Hobbies and Urban Drones.
-Alex
Old Jun 28, 2012, 11:23 AM
scrtsqrl is offline
Find More Posts by scrtsqrl
Just trying to get a nut.
scrtsqrl's Avatar
United States, VA, McLean
Joined Oct 2006
Is there a usable VTx that plays well with 2.4 RC and does NOT require a HAM license? I want to put together a club field friendly plane...VLOS ranges only...
Thanks!
scrtsqrl is offline Find More Posts by scrtsqrl
Old Jun 28, 2012, 11:25 AM
Blueshy is offline
Find More Posts by Blueshy
OSUFPV - KF7VFT
Corvallis, OR
Joined Apr 2010
Thanks!
Nope. Legally they all require a license.
-Blues
Blueshy is offline Find More Posts by Blueshy
Old Jun 28, 2012, 12:18 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Thanks!
I believe the Iftron 25mW 5.8GHz VTX is FCC licensed and therefore legal as it would fall under part 15.
-Alex
Discussion How to calculate flight time - guide ikorman Multirotor Talk 16 Jun 26, 2016 07:34 AM
Cool How cool would this be for FPV Kai_Shiden FPV Talk 4 Feb 18, 2016 08:02 PM
Discussion How many FPV pilots in the world? rbmaze FPV Talk 10 Aug 03, 2011 06:16 AM
Poll Would you be interested in buying Ready to Fly FPV airplanes from a new FPV store? FPVNOW FPV Aircraft 36 Oct 06, 2010 08:56 PM
Discussion Can this cam be used for FPV ? SpookiePower FPV Talk 8 Sep 12, 2010 07:12 AM
