This thread is privately moderated by IBCrazy, who may elect to delete unwanted replies.
Old Dec 26, 2010, 02:43 AM
IMEIV is offline
Find More Posts by IMEIV
The way of being is doing.
IMEIV's Avatar
Italia, Emilia Romagna, Ravenna
Joined Apr 2009
Originally Posted by IBCrazy View Post
You need to coil the wire around a ferrite ring several times.
This is a ferrite ring: http://www.dpcav.com/xcart/product.p...5&cat=0&page=1
This is how to coil it up: http://www.dpcav.com/xcart/product.p...0&cat=0&page=1
-Alex
Thanks. Would you be so kind as to tell me the reasons for doing this ?
IMEIV is offline Find More Posts by IMEIV
Old Dec 26, 2010, 02:52 AM
Bilbobaker is offline
Find More Posts by Bilbobaker
Bilbobaker's Avatar
United States, UT, Salina
Joined Apr 2003
RF interference due to electro magnetic current resistance and more.
The chokes just suck it up in a gravity well of sorts.
Bet your computer, keyboard and such have an abundance of them, ,mostly hidden.
Bilbobaker is offline Find More Posts by Bilbobaker
Old Dec 26, 2010, 11:50 AM
Foskje is offline
Find More Posts by Foskje
Norway
Joined Dec 2009
Do I have to coil all wires around the ferrite ring? - or is it ok to coil one wire (one of the three)?
- as many times as possible?
Foskje is offline Find More Posts by Foskje
Old Dec 26, 2010, 12:24 PM
boopidoo is offline
Find More Posts by boopidoo
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
Better to wire all three of them and as many times as possible, yes.
boopidoo is offline Find More Posts by boopidoo
Old Dec 26, 2010, 10:28 PM
SamB125 is offline
Find More Posts by SamB125
Fly it like you stole it!
Rosamond,Ca
Joined Jun 2008
Is giving a 5 volt Tx 5.5 volts bad, Im guessing that it's fine but I don't want to burn anything up. Thanks!
SamB125 is offline Find More Posts by SamB125
Old Dec 26, 2010, 10:48 PM
Bilbobaker's Avatar
Joined Apr 2003
I'm pretty sure it will be fine but I have heard of really crappy stuff popping at just one volt over the requirement.
Old Dec 27, 2010, 12:25 AM
scrtsqrl is offline
Find More Posts by scrtsqrl
Just trying to get a nut.
scrtsqrl's Avatar
United States, VA, McLean
Joined Oct 2006
List of Things to Have...
Here's a list of parts/supplies/tools that can "support" your FPV Flight OPS.
scrtsqrl is offline Find More Posts by scrtsqrl
Old Dec 30, 2010, 04:49 AM
Foskje is offline
Norway
Joined Dec 2009
I am going to use one single battery for motor and fpv, so I'll use a "Sander style" LC (right?) filter.. !
my questions:
1000uF or 470uF - what is the best? (maybe it depends on my setup?!)
Can I buy any ferrite ring? - a cheap one will work just fine? - will a big ring filter more noice?
Old Dec 30, 2010, 12:51 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
The bigger the ring, the more turns you can get around it. The more turns, the lower the noise.
As for the capacitor, 470uF will work fine. 1000uF is overkill IMO.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Dec 31, 2010, 02:50 AM
Bilbobaker's Avatar
Joined Apr 2003
Alex, could you post some antenna length info for everyone.
Optimal lengths for stock 72 35 2.4 rc rx's etc.
It would be really useful info for many.
Old Dec 31, 2010, 09:15 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Changing antenna lengths does not always improve performance. This is especially true with 2.4GHz. the best way to figure out the optimal antenna length is to attach a wire about twice as long as your antenna to the end of the antenna and do a range test, trim, and range test again. Stop trimming when you don't get any farther away on the range test.
-Alex
Old Jan 05, 2011, 08:41 PM
nakelp86 is offline
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
Originally Posted by boopidoo View Post
I would like to add KYDEX as a preferred material when building stuff for FPV. It's easy to work with and can be used for a lot on a FPV model, for example a camera enclosure. The material can be cut with a scissor and when heated up with a heat gun or even a candle/lighter will work can be bent very easily. It becomes hard plastic again quite fast so a mount like the one below is easily made in about an hour including cutting drilling and trimming.
I've bought my KYDEX from www.knifekits.com t=0.06in and 0.08in, the camera enclosure is made with t=0.06in.
I've done some drawings on a pan/tilt-mount as well as a camera enclosure which fits the popular uncased cameras.
Hi
could you share some more details how to approach making this camera enclosure?
Do you need some kind of form/ press for this material to make nice little box?
Do you need to cut the corners and fold them or it just forms around some square.
Never worked with this material so any info would help probably not only me.
Thank you
nakelp86 is offline Find More Posts by nakelp86
Old Jan 06, 2011, 05:48 AM
boopidoo is offline
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
I simply put the cut out plastic part on a vise and use a heat gun until the plastic bends and gets soft. After that I use something flat, like a metal ruler, and push along the edge so the corner gets as small bend radius as possible until the plastic cools and hardens. This takes seconds so you have to be quick, but if you're not happy with the results you just heat it up again and redo the process.
You can also use a mold/plug and shape KYDEX in the oven (this is how knife/gun holsters are usually made) but I find this method simpler and quicker.
I use CA glue which is the only glue I've found to really work on KYDEX. It's a "fat" plastic so epoxy and heat-glue doesn't work. I sand the bonding surfaces and make sure they are nice and smooth without any gaps and press for a few seconds after CA is applied. This is usually enough for a good bond. None of my KYDEX enclosures have opened up unless I open them myself using a knife or equivalent.
Old Jan 09, 2011, 07:53 PM
modelerchina is offline
Find More Posts by modelerchina
Canada, ON, Mississauga
Joined Apr 2006
"Another solution is a filter. You can filter the signal by passing it through a recorder such as the AIPtek MPVR. You can also pass it through a coaxial to RCA converter box. These generate an artificial sync signal that keeps the monitor going through static."
Can you shows a setup for coaxial to RCA converter box
modelerchina is offline Find More Posts by modelerchina
Old Jan 09, 2011, 07:59 PM
Joined Apr 2006
Can you also share some experience about camera - transmitter interference.
I suspect my system is subject to camera - transmitter interference result in short range.
900mhz, 500mw, stock antenna on Tx, Patch on Rx, only about 100 meter+. I ordered the meganet ring from DPCAV on route, this is the only thing I don't have according to the "white paper for EMI/RFI noise" or the "how to be successful"
Getting so down cannot get "crispy clear signal 1km up" as many people easily get.
Discussion Can this cam be used for FPV ? SpookiePower FPV Talk 11 Aug 16, 2016 11:08 PM
Discussion How to calculate flight time - guide ikorman Multirotor Talk 16 Jun 26, 2016 07:34 AM
Cool How cool would this be for FPV Kai_Shiden FPV Talk 4 Feb 18, 2016 08:02 PM
Discussion How many FPV pilots in the world? rbmaze FPV Talk 10 Aug 03, 2011 06:16 AM
Poll Would you be interested in buying Ready to Fly FPV airplanes from a new FPV store? FPVNOW FPV Aircraft 36 Oct 06, 2010 08:56 PM
