This thread is privately moderated by IBCrazy, who may elect to delete unwanted replies.
Old Mar 06, 2012, 07:19 AM
fltekdiver is offline
Find More Posts by fltekdiver
United States, FL, Melbourne
Joined Jan 2010
Originally Posted by BCSaltchucker View Post
see above fro my 2 cents
I couldn't find your post ?
fltekdiver is offline Find More Posts by fltekdiver
Old Mar 06, 2012, 07:57 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
@Colonel Blink - White is audio. Yellow is video. That could be your problem.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Mar 06, 2012, 08:18 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by markus123456 View Post
Go for 5.8Ghz. This is the frequency with fewest problems if you don't intend to break range records. Small antennas, good working systems available, no problems with others on 2.4G flying, no influence from RC-link or cameras etc. etc.
HTH
Markus
^+1
5.8GHz is great if you fly a 2.4GHz radio.
-Alex
Old Mar 06, 2012, 08:20 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by fpvnooby View Post
hello,im new here. there are many pages to go through but I have limited time on computers. can someone suggest a good start up plane and the electronics. I have about $400.00 to spend does that look like it enough? I see many notes about helicopters here, i can't do those, so want planes only thanks.
The problem with your budget is the goggles. Goggles run $300 or so. Everything else is pretty cheap.
Get a 100mW FatShark 5.8GHz VTX and a set of FatShark Goggles and a decent camera. Put that on a airplane you already own.
That's a good way to spend your $400 budget.
-Alex
Old Mar 06, 2012, 10:38 AM
Colonel Blink is offline
Find More Posts by Colonel Blink
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
-Alex
Cheers for the pointer, Alex - but the cam only has 3 wires - red/black/white. So no built-in audio.........
Colonel Blink is offline Find More Posts by Colonel Blink
Old Mar 06, 2012, 12:04 PM
kicekilla is offline
Find More Posts by kicekilla
No you cant fly it.
kicekilla's Avatar
United States, FL, Milton
Joined Mar 2011
Right. There is just no mic on your cam. So red black are obvious and white is ou video signal
kicekilla is offline Find More Posts by kicekilla
Old Mar 06, 2012, 12:54 PM
Blueshy is offline
Find More Posts by Blueshy
OSUFPV - KF7VFT
Corvallis, OR
Joined Apr 2010
Hey Blues - I'm seeing 1.20V at the RCA plug.... so it is putting out something. Whether that is an intelligible signal is anyones guess. Also, the camera is getting noticably warm - is this normal?????
Hm, well is the voltage changing or is it constant? Sometimes a multimeter
will be good enough to catch some of the voltage swings of the signal.
Warm is fine, hot is bad.
-Blues
Blueshy is offline Find More Posts by Blueshy
Old Mar 06, 2012, 01:23 PM
Floater73 is offline
Find More Posts by Floater73
But often down to earth
Floater73's Avatar
Oklahoma, USA
Joined Sep 2010
Originally Posted by chicken sashimi View Post
If anyone has done the wifi booster mod for the dx6i, i'd like to pick your brain.
Do you HAVE to use a patch antenna as part of the equation? I expected that the booster would simply add omnidirectional range to my 2.4tx. I was also under the impression that patch antennas are pretty narrow field and as such have to be pointed to the rx in order to be effective.
I'd like to broaden my range omnidirectionally since i'm not really interested in going on long missions in one direction and back again. Is this mod not suitable for my needs, or could i still benefit from the wifi booster?
Thanks for your helps.
An omni is fine. I have an amp on my DX8. I've flown over 2 miles and have a solid link. I even use the small 3 dbi omni on the Tx.
http://www.ebay.com/sch/i.html?_nkw=....c0.m270.l1313
Here's a link to a thread where you get more info:
http://www.rcgroups.com/forums/showthread.php?t=1247186
Good luck,
Steve
Floater73 is offline Find More Posts by Floater73
Old Mar 06, 2012, 02:22 PM
BCSaltchucker is offline
Find More Posts by BCSaltchucker
fly by night
BCSaltchucker's Avatar
Joined Sep 2011
I made bullet points replying to your queries within your quote in my prev post
BCSaltchucker is offline Find More Posts by BCSaltchucker
Old Mar 06, 2012, 02:32 PM
Joined Jan 2010
Thanks, Ill look now
Old Mar 06, 2012, 02:40 PM
Joined Jan 2010
Allot of great advise, you just helped me out allot
After spending 40+ hours reading, you just sumed it all up withen a few lines
I'm going to start to buy some equipment soon
I'll take your advise on the Easy Star , or Sky walker or something similiar, I think the 56" Delta wing I'll leave for night flying only with LED's , no FPV
I want a slow, stable, long battery life plane for FPV
Old Mar 06, 2012, 02:48 PM
Joined Nov 2008
Originally Posted by kicekilla View Post
Right. There is just no mic on your cam. So red black are obvious and white is your video signal
...or not, as seems to be the case!!
Originally Posted by Blueshy View Post
Hm, well is the voltage changing or is it constant? Sometimes a multimeter will be good enough to catch some of the voltage swings of the signal.
-Blues
Couldn't see variation - and the avo shows two decimal places. I'm coming to the conclusion it is dead. Ho hum!
Old Mar 06, 2012, 03:01 PM
Martin7182 is offline
Find More Posts by Martin7182
Wallop!
Martin7182's Avatar
Bussum, Netherlands
Joined Oct 2009
Colonel,
Just to be sure, did you test your TV composite input with another camera or game console?
Martin
Martin7182 is offline Find More Posts by Martin7182
Old Mar 06, 2012, 03:05 PM
Wallop!
Martin7182's Avatar
Bussum, Netherlands
Joined Oct 2009
Last edited by Martin7182; Mar 06, 2012 at 03:08 PM. Reason: Double post after errmsg "this forum requires you to wait 10 seconds before posting" or something alike. Pushed post-button.
Old Mar 06, 2012, 03:08 PM
Joined Nov 2008
Originally Posted by Martin. View Post
Colonel,
Just to be sure, did you test your TV composite input with another camera or game console? Martin
Yes, the Wii is normally connected to those inputs; and I've even been remembering to change the source to 'Game'.
Thanks!
Discussion How to calculate flight time - guide ikorman Multirotor Talk 16 Jun 26, 2016 07:34 AM
Cool How cool would this be for FPV Kai_Shiden FPV Talk 4 Feb 18, 2016 08:02 PM
Discussion How many FPV pilots in the world? rbmaze FPV Talk 10 Aug 03, 2011 06:16 AM
Poll Would you be interested in buying Ready to Fly FPV airplanes from a new FPV store? FPVNOW FPV Aircraft 36 Oct 06, 2010 08:56 PM
Discussion Can this cam be used for FPV ? SpookiePower FPV Talk 8 Sep 12, 2010 07:12 AM
