![]() cheers |
I got a Cam/Tx/Rx combo from HK. I also got a commercial patch antenna and the recommended V Tx antenna from a vendor mentioned here.
The Rx connector is a different size than the one on the lead from the patch. Can I get an adapter at Fry's without impacting the signal, or do I need to change out one of the connectors to match? Thx! ..a |
Hillsboro OH
Joined Sep 2005
North vancouver, B.C. Canada
Joined Apr 2008
If there is an electronics store near you, they can shorten the coax to your preferred length an professionally crimp on most likely abetter crip than stock.
Its nice to have the video rx close to the rx antenna with the right connector. |
This is all very good stuff. Thanks to all that are contributing the information
![]() Question about the RTL feature Is the RTL something that comes with an OSD or an integral part of it, or is it bought separately. I could not find it on any of the vendor sites. ============================================ What do you need to buy to have the RTL feature? ============================================ With the flight stabilization, I am assuming that you must have ailerons. I found this flight stabilization system on DPC: http://www.dpcav.com/xcart/product.p...cat=277&page=1 Thanks, Randy |
Temple, GA, USA
Joined Jun 2009
RTL is a function of the OSD. Buy an OSD that has RTL. The OSD must have GPS capability or they cannot make it do RTL. I suppose that a flight stabilization system could conceivably be put on a stable (high wing with dihedral) 3 channel FPV plane with the left-right channel being either rudder or aileron. You could even have RTL steer the ailerons on a 4 channel. The effect would be to change the left-right control (even on a rudder airplane) from a "roll rate" control to a "bank angle" control e.g. when you hold full left, it will fly at a 45 degree bank instead of doing continuous rolls. You would: 1 - connect RC Receiver to OSD/RTL to Stabilization to Servo 2 - set the RTL up to give say a 15 degree bank (takes a long time to turn around) 3 - the stabilization would keep the plane in a constant bank and keep it from rolling all the way over This would work in a similar fashion to having a setup without flight stabilization and with the RTL set up to put in just a tiny amount of left-right. Be aware when setting up without a flight stabilization system that it will fail if your plane is out of trim. Either left trim will cancel out the right given by the RTL or left will add to left and cause too steep of a turn. I believe that RTL with a flight stabilization system on a 3 channel plane would work better than RTL without stabilization on a 3 channel plane because the bank angle is more predictable. The better way is to have a stabilized 4 channel with stabilization on the ailerons and RTL on the rudder. This is kind of the minimum standard. An even better way to do this is to have flight stabilization on both aileron and elevator and RTL set a fixed throttle setting plus control the rudder to steer a course, but that is a lot of hardware. The elevator stabilization helps in the turn arounds. The main problem left here (for this and any simple system where elevator is not controlled by RTL and altitude) is that the plane will probably constantly ascend or descend a little and may get too low or too high over a long RTL. Think about it. You were a long way away. You plane flew away. Some time later your quiet plane crosses overhead 1000 feet up from some direction and you don't notice it. It flies away, turns around and comes back from some different direction and maybe higher still. The battery runs out and it continues to do this while gliding down. The plane is probably somewhere within a 1/2 mile radius of the launch point, but that generally means it is lost. Better get a loud beeper hooked up to RTL too, and hope there is enough power left in your battery after ESC cutoff to control the plane for several minutes and run the RC and beeper for an hour. Better have an ESC with a hard cutoff at a high voltage to leave juice. The best way to do this is to have a complete auto-pilot (the yet to be released openpilot.org comes to mind) that controls everything (keeps the plane from ascending or decending by watching altitude) has stabilization too, and will auto-land after circling for 5 minutes (probably in a tree, but close to launch point at least). Sorry, but I don't know which OSD systems have what capabilities. It would be good for someone who knows to give us a table of functionality (the basics like how many channels the RTL controls). Cliff |
Latest blog entry: Travel Quad
-Alex |
Latest blog entry: Project Covert Ops: Long range ground...
Thanks for the info, I'll be using there 7 channel receiver, unless I need more. But I don't think I will as I'm flying a radian, only 3 channels. I'll try the range check.
Good idea. Looking forward to some FPV flying, so far there is soooo much info to read. Almost gets you lost before you start flying. Marc |
| Thread Tools | |
| Discussion How to calculate flight time - guide | ikorman | Multirotor Talk | 11 | Dec 30, 2011 07:22 PM |
| Discussion How many FPV pilots in the world? | rbmaze | Video Piloting (FPV/RPV) | 10 | Aug 03, 2011 06:16 AM |
| Poll Would you be interested in buying Ready to Fly FPV airplanes from a new FPV store? | FPVNOW | Video Piloting (FPV/RPV) | 36 | Oct 06, 2010 08:56 PM |
| Discussion Can this cam be used for FPV ? | SpookiePower | Video Piloting (FPV/RPV) | 8 | Sep 12, 2010 07:12 AM |
| Cool How cool would this be for FPV | Kai_Shiden | Video Piloting (FPV/RPV) | 2 | May 11, 2009 07:41 PM |
