This thread is privately moderated by IBCrazy, who may elect to delete unwanted replies.
Old Dec 20, 2010, 06:02 AM
boopidoo is offline
Find More Posts by boopidoo
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
One main battery for everything is IMO the best and safest installation.
Read the guidelines in this thread and especially in the first post: http://www.rcgroups.com/forums/showthread.php?t=1323951
boopidoo is offline Find More Posts by boopidoo
Old Dec 20, 2010, 03:26 PM
Bilbobaker is offline
Find More Posts by Bilbobaker
Bilbobaker's Avatar
United States, UT, Salina
Joined Apr 2003
Originally Posted by Foskje View Post
Well I have changed opinion again!
For now, I think I will go for a camera that I will be happy to use, otherwise I will buy a new camera very soon.. I hope that I will not crash ( that hard)..
I have tied to search for cameras and watched videos on youtube, I found these cameras:
http://www.bevrc.com/bev-wdr700-high...pal-p-171.html
120$
and..
http://hobbywireless.com/cart/index....roducts_id=394
115$
I will not spend more mony on the camera, but I am alwas willing to spend less if theres some cameras that is just as good as these... or even better...
Is it a bad idea to use main battery for all electronics in the plane? - even if I'm using a separate ubec?
A good inexpensive Panasonic GP-CX161 can be had for less than $20 here if your on a budget.
Bilbobaker is offline Find More Posts by Bilbobaker
Old Dec 20, 2010, 04:06 PM
Foskje is offline
Find More Posts by Foskje
Norway
Joined Dec 2009
He does'nt support international shipping ... and I think I will go for a camera that has good resolution, even if its not that good ... It seems like that GP-CX161 camera is no better than a 60$ camera, so next step will be around 120$ ... I think, - actually with no experience
I think I will go for the camera at bevrc.com - because I will buy the 800mW 1.3gHz Vtx/rx there...
Is it true that not all cameras support OSD? - how do I find out if it supports OSD or not?
You are really helpful here I like it! - thaks!
Foskje is offline Find More Posts by Foskje
Old Dec 20, 2010, 05:06 PM
boopidoo is offline
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
In some cameras you can adjust its settings such as white balance etc. This is done using an OSD within the camera and has nothing to do with the FPV OSDs such as RVOSD, DOSD+, ET OSD PRO etc. You can of course use a camera that doesn't support OSD to a FPV OSD.
Old Dec 20, 2010, 05:10 PM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
the big difference is in the actual quality of the camera and the connectors
there is a difference and you do get what you pay for
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Dec 21, 2010, 12:35 PM
paintz2007 is offline
Find More Posts by paintz2007
Guess Who's Back? :D
paintz2007's Avatar
Joined Sep 2006
Originally Posted by Bilbobaker View Post
Radio shack has them.
yep in the slide out drawers... about 5 bucks for a cap and baggy of ferrite rings
paintz2007 is offline Find More Posts by paintz2007
Old Dec 21, 2010, 10:14 PM
beginner4life is offline
Find More Posts by beginner4life
beginner4life's Avatar
United States, MD, Ellicott City
Joined Mar 2008
Is there anything in the part of the cable coming from the camera where it goes from one wire into A/V and power that i need? Or can i cut that and just use the origial 4 wires coming from the camera? thanks
beginner4life is offline Find More Posts by beginner4life
Old Dec 22, 2010, 01:44 AM
scrtsqrl is offline
Find More Posts by scrtsqrl
Just trying to get a nut.
scrtsqrl's Avatar
United States, VA, McLean
Joined Oct 2006
Wiring Basics.
For all of our electrical systems, there are three basic connections:
  1. Ground - Think of this as the electrical "foundation". In general, it is common to anything electrical in our systems.
  2. Power - Think of this as the "Fuel" to that device
  3. Signal - Think of this as what the device inputs, outputs or both. The number of Signals into or out of the device's can vary from zero to ???.
Some examples:
A light bulb has ground and power.
A servo has ground, power, signal in.
A camera has ground power, video out.
A mic has ground, power, audio out.
A VTx has ground, power, Video in, Audio in.
Wiring colors vary though you can be 99.9% sure that Ground is BLACK(sometime brown), Power is RED.
scrtsqrl is offline Find More Posts by scrtsqrl
Old Dec 22, 2010, 06:29 AM
flipflap is online now
Find More Posts by flipflap
Joined Mar 2009
Very nice idea an document !
I'd suggest some small changes/additions :
-Could be useful to add a glossary of all terms (and common abbreviations)
-"Having a prop out in front isn’t necessarily a bad thing. When night flying the prop disappears anyway."
Well, at night everything disappears more seriously, I think night flying is not something to evoke in this document if it's aimed for beginners.
-"For some, seeing the spinning prop gives a more realistic feel to the plane. It also is necessary for flying gliders where the prop opens up and takes up much of the video screen."
Can be a little confusing for a beginner to talk about the propeller of a glider, he might not get that it's a motorized glider.
-"You need to build a system to suit your personal goals. This is why this is a do-it-yourselfer’s paradise."
As that section talks about video TX systems, it can be good to add a remark about some legal aspects (the authorized frequencies varies by country, remember that your video signal can disappear for many reasons, etc)
- you mention several distance 'records', but I would say it's not the best place to do it, maybe just give them as examples. (I mean or you should add the record claimed by Trappy here http://www.rcgroups.com/forums/showthread.php?t=1326375 then it's a discussion about what is a record, how to prove it etc)
-"The cameras are basic CCD cameras."
CCD or CMOS, for example the dx201 and gopro are cmos.
-in the camera section, buy a ntsc or pal according to the user's country, mention that transmitters and receivers will work with both but some tv sets or video recorders will only work with one type
Excellent work so far !
Ben
flipflap is online now Find More Posts by flipflap
Old Dec 22, 2010, 06:15 PM
David22 is offline
Joined Apr 2008
Here is an interesting statistic
3 of the 4 guys who have flown the furthest long range on rc groups, use stock antennas on their video tx's
so in order to get perfectly clear video, even at long range over 23 km away, there is really no reason to make up a do it yourself antenna
however all of them use after market video rx antennas and lawmate video rx's
and all of them use uhf for rc control
sometimes statistics don't lie
Old Dec 22, 2010, 07:56 PM
rcmonster99 is offline
Find More Posts by rcmonster99
Houba ! Houba !!
rcmonster99's Avatar
United Kingdom, England, Milton Keynes
Joined Sep 2003
This is a problem
we are seen all sorts of inputs, ideas,recommendations,specific questions,electricity questions etc etc.
One document can deal with this, but it will end up the size of the Encyclopaedia Britannica.
Even if this thread is a sticky, all the information will get lost in a techno babble cloud.
There was a similar thread for newcomers about what to buy,but it has lost its appeal long time ago and this thread may go the same way.
So... I recommend creating a website where all newcomers could be redirected.
It might be organised into specific chapters, from safety aspects to wiring specifics, and, could have different levels of involvement.
A website could be really dynamic too if well maintained.
unfortunately I don't have a clue on how to make a website and I can see this as a herculean task if made by one person alone, so there would have to be different web masters covering different disciplines.
For example :
-IB could be the aerial specialist
-Daemon the video specialist
-Trappy the safety specialist (sounds weird for some but he knows how to make a system safe)
-Crist Rigotti the applications guru
-David22 the glider and aerodynamics consultant
(just to mention a few) etc etc...
Then, when a newbie asks question about the best setup for 27km flights using a parkzone vapor, he could be directed to the "in your dreams" section of the website.
the different web masters could cut and paste ideas or discussions from ordinary members of RCgroups in this particular thread.
The thing is there is such a massive amount of experiences to collect that it would be a massive job in its own right.
Did someone mention a wiki link before? is this the same sort of thing?
rcmonster99 is offline Find More Posts by rcmonster99
Old Dec 23, 2010, 10:33 PM
Dan110024 is offline
Find More Posts by Dan110024
Adelaide, South Australia
Joined Nov 2010
Maybe you don't need to get so in depth, afterall... I had a read over the guide last night....it's exactly as it's called. A guide. Not a one-stop-shop for all things FPV/RC. From my understanding, noobs/beginners can read it and get started and up to speed on the subject. They can then go off and complete their own research on the subjects you're wanting to know more about, after learning the terminology and basics.
That's how I've interpreted it anyway....and it does a fine job at that.
You could be setting yourself up for failure if it's too in depth. That's my 2c anyhoo...
Keep up the good work IBC..Your efforts are definitely not going unrecognised!
Dan110024 is offline Find More Posts by Dan110024
Old Dec 24, 2010, 04:02 AM
boopidoo is offline
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
I think it's good especially now that it's a sticky. There's plenty more in the forum to read but I agree that your suggestion should be included if it not already is. That being that lurking and reading the forum is one of the best way of learning.
Old Dec 25, 2010, 05:30 PM
IMEIV is offline
Find More Posts by IMEIV
The way of being is doing.
IMEIV's Avatar
Italia, Emilia Romagna, Ravenna
Joined Apr 2009
Congratulations for the great guide but I have a question...
You speak about VSN500 camera http://usasecuritysystems.com/produc...VSN500NHB.html as a great product and then "but requires a filter if using a GPS".
Ok, I ask you.. What's a filter for GPS ? Why do I use it and where can I find ?
Matteo
IMEIV is offline Find More Posts by IMEIV
Old Dec 25, 2010, 07:09 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
You need to coil the wire around a ferrite ring several times.
This is a ferrite ring: http://www.dpcav.com/xcart/product.p...5&cat=0&page=1
This is how to coil it up: http://www.dpcav.com/xcart/product.p...0&cat=0&page=1
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Discussion How to calculate flight time - guide ikorman Multirotor Talk 15 Feb 01, 2015 11:12 PM
Discussion How many FPV pilots in the world? rbmaze FPV Talk 10 Aug 03, 2011 07:16 AM
Poll Would you be interested in buying Ready to Fly FPV airplanes from a new FPV store? FPVNOW FPV Aircraft 36 Oct 06, 2010 09:56 PM
Discussion Can this cam be used for FPV ? SpookiePower FPV Talk 8 Sep 12, 2010 08:12 AM
Cool How cool would this be for FPV Kai_Shiden FPV Talk 2 May 11, 2009 08:41 PM
