This thread is privately moderated by IBCrazy, who may elect to delete unwanted replies.
Old Feb 20, 2011, 07:43 PM
tbear2195 is offline
Find More Posts by tbear2195
Wannabe Engineer
tbear2195's Avatar
Pennsylvania
Joined Feb 2011
Originally Posted by IBCrazy View Post
I cannot comment on the FrSky system. I fly 72MHz and a DragonLink. However the WiFi booster really does work. You can even couple it with an inexpensive patch antenna by getting an inexpensive IPX (U.FL) jumper cable.
PM sent on the equipment.
-Alex
It really doesn't matter to me which control system it is. I just want something that is affordable that will get me that range I am looking for. About the antennas, how many do I need and should they be on the transmitter or receiver? With one of your helical antennas and that $60 transmitter/receiver combo, can I achieve 3-4 miles of range?
tbear2195 is offline Find More Posts by tbear2195
Old Feb 20, 2011, 07:48 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
If you fly in a good location and aim the antenna properly, then yes you can. However, remember the range equation. Selection of a site, keeping the Fresnel zone clear, and aiming the antenna properly are essential and not easily understood until you've experienced problems with it. Experience gets you as much range as your equipment does.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Feb 20, 2011, 08:17 PM
Wannabe Engineer
tbear2195's Avatar
Pennsylvania
Joined Feb 2011
Alright thanks for all the help. I really just wanted to get an estimate of how much it would cost to equip a plane with a camera and all the necessary electronics. I will probably buy a plane soon in the future but I will fly it some and get used to it before I buy any video equipment.
Old Feb 21, 2011, 08:48 PM
Stacky is offline
Find More Posts by Stacky
Pants first, then shoes
Joined Jan 2011
I did search the forums but didnt find the answer so forgive me if its out there somewhere. There is a guy in Brazil, has the nickname of Gabriel. I have seen some of his FPV flights and in one he passes through 2 car tunnels. I was under the impression that fpv needed some sort of line of sight for the antenna. Im amazed that he got through 2 reasonably long tunnels. Is he using something different from the usual gear?
Stacky is offline Find More Posts by Stacky
Old Feb 21, 2011, 08:59 PM
galaxiex is offline
Find More Posts by galaxiex
my karma ranover my dogma
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
His ground station was positioned at one end of the tunnel... so his signal would be LOS while flying thru said tunnel....
galaxiex is offline Find More Posts by galaxiex
Old Feb 21, 2011, 09:09 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Pretty sure that one was flown from a chase car.
ian
Daemon is online now Find More Posts by Daemon
Old Feb 21, 2011, 09:18 PM
galaxiex is offline
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
ian
Ahhh, right you are... I was thinking of a different vid...
Old Feb 21, 2011, 10:15 PM
Stacky is offline
Joined Jan 2011
ian
The one I saw he hand launched it from the side of the road, didnt seem like a car chase but could have been. thanks for the replies.
Old Feb 21, 2011, 10:16 PM
Stacky is offline
Joined Jan 2011
Its this video
FPV from suburbs to the beach (5 min 19 sec)
Old Feb 21, 2011, 10:20 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
The launch was from the middle of the road. Should be pretty obvious that
the ground station was in a car.
ian
Old Feb 21, 2011, 10:47 PM
Stacky is offline
Joined Jan 2011
cool thanks
Old Feb 22, 2011, 06:01 AM
scrtsqrl is offline
Find More Posts by scrtsqrl
Just trying to get a nut.
scrtsqrl's Avatar
United States, VA, McLean
Joined Oct 2006
Note to newbies:
What constitutes an "acceptable operating area and safe practices" varies from locality to locality...
scrtsqrl is offline Find More Posts by scrtsqrl
Old Feb 22, 2011, 06:46 AM
hotdog1 is offline
Find More Posts by hotdog1
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
Originally Posted by scrtsqrl View Post
Note to newbies:
You would think common sense would cover "acceptable operating area and safe practices" ! but In many cases that is not the case
hotdog1 is offline Find More Posts by hotdog1
Old Feb 22, 2011, 09:19 AM
kristaps_r is offline
Find More Posts by kristaps_r
kristaps_r's Avatar
Latvia, Riga
Joined May 2010
Power connector
Hi
Can anyone suggest best option what battery connectors are prefered to use in FPV? I see a lot of OSDs and current sensors use T-Connectors like these.
Maybe it shoud be pointed in document on first page wich connector is prefered for maximum compatibility.
Kristaps
kristaps_r is offline Find More Posts by kristaps_r
Old Feb 22, 2011, 03:42 PM
PHMX is offline
Find More Posts by PHMX
Never trust laughing dolphins
Joined Feb 2011
Originally Posted by kristaps_r View Post
Hi
I must say I like those T-connectors as they won't go loose easily.
But basically any kind will do, just as long as your plane will operate under normal circumstances using those connectors. I'd pay a little attention to what A it can handle, but that's about it.
PHMX is offline Find More Posts by PHMX
Cool How cool would this be for FPV Kai_Shiden FPV Talk 4 Feb 18, 2016 08:02 PM
Discussion How to calculate flight time - guide ikorman Multirotor Talk 15 Feb 01, 2015 10:12 PM
Discussion How many FPV pilots in the world? rbmaze FPV Talk 10 Aug 03, 2011 06:16 AM
Poll Would you be interested in buying Ready to Fly FPV airplanes from a new FPV store? FPVNOW FPV Aircraft 36 Oct 06, 2010 08:56 PM
Discussion Can this cam be used for FPV ? SpookiePower FPV Talk 8 Sep 12, 2010 07:12 AM
