This thread is privately moderated by IBCrazy, who may elect to delete unwanted replies.
Old Feb 14, 2011, 01:01 PM
Wearyman is offline
Find More Posts by Wearyman
Just dog tired.
Wearyman's Avatar
USA, NY, Buffalo
Joined Dec 2010
I've been on the forums here for a while now, and need to ask what is probably a stupid question, but due to my own inexperience I just can't suss this one out myself. Hopefully IBCrazy will have mercy upon me and enlighten me with his technical wisdom.
There seems to be much discussion about RcTX and VTX and the proper way to balance these two. But with the advent of long-range multi-channel RX/TX systems (Such as Dragon Link and the like) Why are we not simply using a single RX/TX system and slicing out 2 or 3 channels to handle the video and audio downlink?
Perhaps I am missing something obvious, but if one has a 12 channel capable RX/TX system and is only using say, 8 channels, why not use the remaining 4 channels for your other onboard systems and save weight, battery, and complexity?
Has anyone ever tried this? Is it even POSSIBLE with a multichannel radio, or would you need to include some kind of chip-based compression/decompression system to get the video data stream down to a manageable size?
Thoughts? Suggestions? Rebukes for being ridiculous?
Wearyman is offline Find More Posts by Wearyman
Old Feb 14, 2011, 01:22 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Lots of problems with this:
First, an RX does not transmit. You still need a transmitter on board the plane to communicate back to you.
Second, the bandwidth of a control system is a couple of kilohertz. The video feed is a couple of Megahertz. The video takes about 40X more bandwidth to transmit and recieve.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Feb 14, 2011, 01:39 PM
Wearyman is offline
Just dog tired.
Wearyman's Avatar
USA, NY, Buffalo
Joined Dec 2010
-Alex
Now see, I SHOULD have known that first item. *forehead smack* Duh.
Of course, knowing the second items helps too. At least as far as the video is concerned, it's a bandwidth issue.
So really, what we need is a unified TX/RX - RX/TX unit that encapsulates both systems on both ends, along with a built-in video compression/decompression module that can handle both NTSC and PAL video streams from a variety of sources.
If only I had the technical knowhow...
Old Feb 14, 2011, 03:50 PM
PHMX is offline
Find More Posts by PHMX
Never trust laughing dolphins
Joined Feb 2011
Originally Posted by kstmark View Post
horrible. I have 2 of them. I bought a much more better from www.securitycamera2000.com
I disagree. It's not bad for it's price and still cheaper than most random other cameras too, even if you decide to change the (often scratched) lens for a new one.
I'd say it's worth a try for sure, especially in the early times when crashes happen, but you should pay attention to resolutions too and not just the price these cheap cameras go for.
Obviously people shouldn't expect an excellent quality for those prices, but for an FPV beginner it's not smart to start out with a modded GoPro camera or the like for sure.
Just my 2cts.
PHMX is offline Find More Posts by PHMX
Old Feb 14, 2011, 09:49 PM
traderdmb is offline
Find More Posts by traderdmb
FPV nut
traderdmb's Avatar
Sorrento, FL
Joined Nov 2010
Thanks in advance to everyone for your help. I see that this is a very helpful forum. SO I guess Ill start with my FPV configuration. Here Goes:
Easy Star with stryker motor and ESC running with mostly 2100 3s lipos.
Spektrum DX6i tx with 6100 RX
FPV-
Readymade 480 camera
900mhz rx with 8dbi patch mounted on Tripod. frim readymade
900mhz tx 500 mw power mounted on wing about 6 inches off fuse. also readymade
Eagletree OSD expander with data logger and GPS
receiver (spektrum) mounted outside of fuse just below removable hatch.
My question is pretty simple. I just don't have the nerve to head outside of 1500 feet. I have actually lost radio contact a couple of times temporarily but recovered. I think this may have been due to the direction my spectrum antennae was pointed. How far are you guys able to fly with a setup like this? Is my video tx situated too close to my other stuff? How far apart do they need to be? I see all kind of setups with the tx right in front of the wing.1500 feet just doesnt seem very far to me and with the stryker motor on this thing I can cover 1500 feet FAST. It does have great vertical clime though.
Also, i am considering a draonlink or something similar. Any suggestions?
Again, thanks for looking and helping.
traderdmb is offline Find More Posts by traderdmb
Old Feb 14, 2011, 09:59 PM
FPV nut
traderdmb's Avatar
Sorrento, FL
Joined Nov 2010
Uploaded with ImageShack.us
Old Feb 14, 2011, 10:32 PM
garrcass is offline
Find More Posts by garrcass
bucket of prop wash
garrcass's Avatar
reddinng CA
Joined Nov 2007
you should put pictures up on RCG it makes it easier for RGC people to view them
garrcass is offline Find More Posts by garrcass
Old Feb 14, 2011, 10:44 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Spektrum AR6100 is a parkflyer receiver. It is not, I repeat *not* a full range receiver.
If you're going to stick with Spektrum (not the most proven 2.4Ghz system for FPV) at
least something decent on there like an AR7000. Going half assed with your RC control
gear will only result in a lost plane.
ian
Daemon is offline Find More Posts by Daemon
Old Feb 14, 2011, 10:47 PM
FPV nut
traderdmb's Avatar
Sorrento, FL
Joined Nov 2010
OK, I can do that. Like I said, Im a nuub. Thanks for the advice, I will pick one up tomorrow.
I certainly didn't skimp intentionally on the receiver. It's just that I have about 6 of them so I slapped it on there. I didn't know it was a short range deal. Thanks a lot for letting me know. I am just glad I didn't lose my plane. I came real close to messing it up pretty good.
Old Feb 14, 2011, 10:48 PM
FPV nut
traderdmb's Avatar
Sorrento, FL
Joined Nov 2010
I will read up and see how to post pics on here. It asked for a link so I just threw them up how I knew too.
Old Feb 15, 2011, 12:11 AM
mark hitchman is offline
Find More Posts by mark hitchman
Zephyr 66" Blunt
mark hitchman's Avatar
New Zealand
Joined Sep 2009
The ar7000 is ok for up to 2 km flights if you are careful with the installation. Get an extension (600mm) for the satellite receiver and put it as far away from the receiver as you can, I used to put receiver at the front and satellite on the tail but it can go out on the wing too.
Range test without fpv gear powered up, then test with fpv gear on and make sure no or minimal reduction in range check, trust me it's worth spending time to get this right.
Mark
mark hitchman is offline Find More Posts by mark hitchman
Old Feb 15, 2011, 01:11 AM
shinee is offline
Find More Posts by shinee
Joined Jan 2011
what kind of camera is best for FPV ?
shinee is offline Find More Posts by shinee
Reply With Quote  (Disabled)
Old Feb 15, 2011, 06:26 AM
PHMX is offline
Joined Feb 2011
That's a tough question to answer and it somewhat depends on what you're looking for. Most cameras will have a decent resolution, sufficient color depth and light adaptation to be suited for FPV flying, but I'd say you should look into the 50$ range for the better FPV cameras without the risk of buying the overpriced 'crap' (not literally crap in the sense of quality, just not very cost effective for something that might break in a crash).
You might want to look at build quality or improve the durability yourself by making a custom camera casing. Well worth spending some time and effort for.
Old Feb 15, 2011, 06:28 AM
PHMX is offline
Joined Feb 2011
Mark
For what it's worth, Spektrum receivers often can't handle a lot of potentially interfering radio noise from nearby video transmissions, so I'd generally not advice to use Spektrum. The range is not all that matters here, some transmitter systems simply work better in this 'radio shade' of a video transmitter than others.
Old Feb 15, 2011, 06:47 AM
FPV nut
traderdmb's Avatar
Sorrento, FL
Joined Nov 2010
Mark
Can you suggest a better rcvr compatible with the dx6i?
Cool How cool would this be for FPV Kai_Shiden FPV Talk 4 Feb 18, 2016 08:02 PM
Discussion How to calculate flight time - guide ikorman Multirotor Talk 15 Feb 01, 2015 10:12 PM
Discussion How many FPV pilots in the world? rbmaze FPV Talk 10 Aug 03, 2011 06:16 AM
Poll Would you be interested in buying Ready to Fly FPV airplanes from a new FPV store? FPVNOW FPV Aircraft 36 Oct 06, 2010 08:56 PM
Discussion Can this cam be used for FPV ? SpookiePower FPV Talk 8 Sep 12, 2010 07:12 AM
