This thread is privately moderated by IBCrazy, who may elect to delete unwanted replies.
Old Feb 09, 2011, 01:01 PM
NDw is offline
NDw
Find More Posts by NDw
NDw
Ireland, Limerick, Kilmallock
Joined Aug 2010
The Hk recievers have f connectors don't they? Same as the Sunsky.
NDw is offline Find More Posts by NDw
Old Feb 09, 2011, 02:03 PM
hotdog1 is offline
Find More Posts by hotdog1
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
Ok so here is what I have so far for FPV gear
GoPro HD (will be using Live video out and recording in HD)
800mw 900mhz vtx/vrx
900 MHz Vee Antenna
Fatshark RCV922 Aviator Edition Goggles
Dx6i with 1watt booster mod
HK Epp Fpv plane running 2 Turnigy 3000mah 3s 40c batteries in parallel
so if i am not using a seperate battery for my VTX how do I wire in a LC filter ? will the servo wire in the filter be able to handle the power draw from the batteries?
also my VTX says it runs on 12v should this be ok to run straight off the 3s lipos?
hotdog1 is offline Find More Posts by hotdog1
Old Feb 09, 2011, 02:13 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Put the filter in series with the power wires to the vodeo system. Servo wires are plenty big.
IBCrazy is offline Find More Posts by IBCrazy
Old Feb 09, 2011, 02:25 PM
hotdog1 is offline
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
Not sure what you mean by this
Also I am making my Live video out cable for my go pro I am making it out of the cable that came with the camera but i am not sure if I should leave the filter on it or not ?
Thanks you for all you help
Old Feb 09, 2011, 03:46 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Neither. You'd never use that wire onboard your plane.
Most people tap off the big power plug that feeds your ESC
with a smaller gauge wire to go feed all your other FPV gear.
The LC filter should be the first thing on that wire,
and from it, you branch out to your 12V Tx, a 5v BEC if you need one.. etc.
ian
Daemon is online now Find More Posts by Daemon
Old Feb 09, 2011, 04:11 PM
hotdog1 is offline
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
Daemon to clarify my question
That wire in that picture is from my gopro hd camera it will go between the camera and VTX what i need to do is cut it and solder it to a standard servo wire to plug into my VTX the only part of that wire I will be using is the 2.5mm mono plug end .
my question was should I cut it before the " filter " or what ever that thing is or after and leave that thing on there ?
Old Feb 09, 2011, 04:28 PM
nakelp86 is offline
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
deleted - no answer to my question, sorry
nakelp86 is offline Find More Posts by nakelp86
Old Feb 09, 2011, 04:30 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
dont waste the original you can buy one already cut with leads and 45 degree plug.
here is the link:
http://hobbywireless.com/cart/index....roducts_id=547
Old Feb 09, 2011, 04:40 PM
hotdog1 is offline
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
the camera came with both these AV and rgb composite cables I use neither so I am going to just use what I have rather than going and buying something i dont need to .
Old Feb 09, 2011, 05:25 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Having a straight plug hanging out there is a great way to break it off,
and damage the A/V socket in the camera.
ian
Old Feb 09, 2011, 08:19 PM
hotdog1 is offline
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
ian
Good point I did not think of that
I just found a 2.5mm 4c plug at radio shack for 3.99
Old Feb 09, 2011, 09:34 PM
garrcass is offline
Find More Posts by garrcass
bucket of prop wash
garrcass's Avatar
reddinng CA
Joined Nov 2007
(Do not fly with a R/C frequency higher than the video frequency (e.g. 2.4GHz R/C, 900MHz video)
???? this is not possible to use 2.4 for controll and 900MHZ (910) for video ?
garrcass is offline Find More Posts by garrcass
Old Feb 09, 2011, 09:35 PM
hotdog1 is offline
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
oh I just read that it is not good to run a 12v VTX straight off a 3s battery. so what would you guys reccomend ? my flight battery's are 2 3000mah 3s in parallel
Old Feb 09, 2011, 09:42 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
It will work fine. The problem is harmonics specifically with the 1.2GHz transmitters. The first order harmonic of 1.2GHz is 2.4GHz and could seriously inhibit the range of your 2.4 GHz radio system. Using 900 MHz video should be fine.
-Alex
Old Feb 09, 2011, 09:44 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
You need a filter. use a "Sander style" filter on the power wires to your video system. There are pictures in the guide at the beginning of this thread.
-Alex
Discussion How to calculate flight time - guide ikorman Multirotor Talk 16 Jun 26, 2016 07:34 AM
Cool How cool would this be for FPV Kai_Shiden FPV Talk 4 Feb 18, 2016 08:02 PM
Discussion How many FPV pilots in the world? rbmaze FPV Talk 10 Aug 03, 2011 06:16 AM
Poll Would you be interested in buying Ready to Fly FPV airplanes from a new FPV store? FPVNOW FPV Aircraft 36 Oct 06, 2010 08:56 PM
Discussion Can this cam be used for FPV ? SpookiePower FPV Talk 8 Sep 12, 2010 07:12 AM
