-Alex |
Latest blog entry: Project Covert Ops: Long range ground...
It's all in the guide on the first page. However you can go to the FPV vendors websites for greater selection in the "What to buy for video piloting" thread as well. That's where most of us buy our goodies.
-Alex |
Joined Feb 2011
FIRST POST!
I have been stalking for a while and figured I would join. Im getting into FPV and have a Sunsky 1.2ghz 800mw system on the way, if they ever get back in stock that is. I have been reading a lot and will continue to digest some of the great information on this forum. I'm looking forward to the new direction in my flying addiction and have an Easy* all built and ready for action. I will have humble beginnings but plan on upgrades after proving my system and setup. Sunsky 1.2mhz 800mw VTX/RX Multiplex Easystar Power Up 32A ESC 2836-22 (2200kv) inrunner 6X3E prop TP 9G servos LMA HK $17 Sony camera Hitec Prism7 FM RX/TX and a couple 950mah 3S and 2200mah 3S lops to run it all off of. I have been flying for a few years now and have always dreamed about FPV flying and decided it was time to have a go at it. I cant wait to get my system all installed and start testing it. |
Welcome to the addiction
I like your handle!You set up sounds fairly good. If I may make a few suggestions: 1. Get a better camera. Any of the cameras in my the document will do well. I will be adding a few more soon. 2. Build my inverted Vee antenna for the TX. Or if you are really ambitious, build two skew-planar wheel antennas for the ultimate FPV performance. Tutorials are in my blog. 3. Put something stronger than 9 gram servos in the plane for control surfaces. I have had good success with the Bluebird 380MGs Hitec HS81's and Hitec HS82MGs. The reason is FPV planes tend to stay airpborne longer than a standard plane and you run a higher risk of burning up those servos. With the added equipment on board, a crash is more costly and thus well worth the investment of a better servo. 4. Consider a single battery setup using a power filter such as the "Sander style" filter. This just makes life easier for you by only having to keep track of one battery. It won't increase performance. 5. Get you HAM radio license if you don't already have one. Take about 10 practice tests online and then go take the real thing. It's fairly easy to pass. Good luck. You are off to a great start! -Alex |
Those "rules" are what I call soft rules. As of right now those are merely suggestions for what the FAA has determined to be safe operations. However if you look at AC91-57 subpart E there is an exception for those who plan appropriately. Still, there is no law limiting what you can do. This is highly debated and is speculated to change in the near future.
However, the rules in AMA 550 are defined rules that must be followed at AMA fields unless you have permission to do otherwise. I find that no AMA field I have been to enforces AMA 550 after they see a flight or two. -Alex |
Birmingham AL
Joined Jul 2010
No. that is RP-SMA. You need this one: http://cgi.ebay.com/N-Male-SMA-Male-...item5adee476d7
| Thread Tools | |
| Discussion How to calculate flight time - guide | ikorman | Multirotor Talk | 11 | Dec 30, 2011 07:22 PM |
| Discussion How many FPV pilots in the world? | rbmaze | Video Piloting (FPV/RPV) | 10 | Aug 03, 2011 06:16 AM |
| Poll Would you be interested in buying Ready to Fly FPV airplanes from a new FPV store? | FPVNOW | Video Piloting (FPV/RPV) | 36 | Oct 06, 2010 08:56 PM |
| Discussion Can this cam be used for FPV ? | SpookiePower | Video Piloting (FPV/RPV) | 8 | Sep 12, 2010 07:12 AM |
| Cool How cool would this be for FPV | Kai_Shiden | Video Piloting (FPV/RPV) | 2 | May 11, 2009 07:41 PM |
