This thread is privately moderated by IBCrazy, who may elect to delete unwanted replies.
Old Aug 10, 2011, 11:48 PM
prelator is offline
Find More Posts by prelator
FPV Browncoat
prelator's Avatar
United States, CO, Parker
Joined Mar 2011
What kind of motor do you need to get that off the ground though? I have a Dynam Hawk Sky Ez* clone and it's already rather heavy with 2x 2200mah 3s batteries, such that I often have problems launching it in calm winds. I have a 2200kv motor and 6x4 prop on it, and I'm a little worried that with the added weight of an FPV system it might not be able to take off, at least with no wind. Perhaps I'll need a different prop, maybe one with less speed but more torque (I really don't understand power systems at all)?
prelator is offline Find More Posts by prelator
Old Aug 11, 2011, 01:29 AM
ScooterInVegas is offline
Find More Posts by ScooterInVegas
Village Idiot!
ScooterInVegas's Avatar
United States, NV, Las Vegas
Joined Apr 2011
That sounds like a lot of battery for that plane.
ScooterInVegas is offline Find More Posts by ScooterInVegas
Old Aug 11, 2011, 01:36 AM
prelator is offline
FPV Browncoat
prelator's Avatar
Joined Mar 2011
I like it because it allows me to fly up to 20 minutes per flight, whereas I could only do half that with one. The plane can carry it alright and they fit in the nose just fine--I'm just not sure how much more weight it can handle with the FPV system and am wondering if there's any way to increase its lifting power by changing the prop or something.
Old Aug 11, 2011, 02:37 AM
swallabat is offline
Find More Posts by swallabat
swallabat's Avatar
United Kingdom, England, Redditch
Joined Apr 2008
HANG ON A BIT FOLKS!! How does this work then?
Prelator gets 20 mins out of 2x2200 batteries, that's only slightly more than twice the time my mate gets out of his 450 helicopter, which has 1x2200 lipo. I thought aeroplanes had much better efficiency than helicopters...
Would anyone care to ignore my obvious ignorance, and set me straight on this?
swallabat is offline Find More Posts by swallabat
Old Aug 11, 2011, 03:10 AM
Village Idiot!
Joined Apr 2011
The plane is heavy with that much battery. It is designed to be run with ONE 1250mha 3s battery. It is much lighter that way and might fly 8-9 min. But gets 20 min with almost 4 times the capacity. The more it weighs, the more power it takes to fly, the faster he drains the packs. Get it?
There is a guy on here (rcg) that flew 6 hours on 1300mAh total. Yes. 1300mAh. To just depends on the type of plane, wing loading.
Old Aug 11, 2011, 04:38 AM
scrtsqrl is offline
Find More Posts by scrtsqrl
Just trying to get a nut.
scrtsqrl's Avatar
United States, VA, McLean
Joined Oct 2006
...and flying style.
scrtsqrl is offline Find More Posts by scrtsqrl
Old Aug 11, 2011, 05:43 AM
swallabat's Avatar
Joined Apr 2008
Thanks for the replies, gentlemen.
I'll keep putting this aeroplane together and see what endurance I can actually get.
The eventual "mission" is to haul 200 grams of electronics about 30 miles, with a current draw of around half an amp from the electronics package, plus whatever the motor needs. (yes, I want to do it with an electric motor, rather than an i/c motor).
I'd read somewhere that someone got an hour out of his easy*, must have got that wrong.. Doh!
Wonder what airframe I should have picked...
Old Aug 11, 2011, 09:49 AM
Yabba is offline
Find More Posts by Yabba
Gravity - It's the law
Yabba's Avatar
USA, CO, Denver
Joined Jul 2008
There seems to be at least 22 threads on RCG regrading the EZ*, Bixler, Skysurfer.
Although your question is not OT you might be better served to check out a couple of the other threads.
Here's a good one
http://www.rcgroups.com/forums/showthread.php?t=1363621
Not trying to be nasty or mean. just trying to help
Yabba
Yabba is offline Find More Posts by Yabba
Old Aug 11, 2011, 10:07 AM
AlanFlorida is offline
Find More Posts by AlanFlorida
AlanFlorida's Avatar
USA, FL, Palm Harbor
Joined Jul 2004
Can someone please point me in the right direction for the following:
1) Best ground station power source
2) Best voltage control source for ground station- voltage regulators, etc.
3) Best way to not have "blue screen of death"- product and link would be awesome
THANK YOU!!
AlanFlorida is offline Find More Posts by AlanFlorida
Old Aug 11, 2011, 11:59 AM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
THANK YOU!!
BEST? No... nobody can tell you what's "best" for you...
1) I use Lipos - 1 for the RX and goggles and one for the recorder
2) nothing... a regulator would only increase power usage with little benefit
3) Fat Shark goggles will display static
jasmine2501 is offline Find More Posts by jasmine2501
Old Aug 11, 2011, 12:30 PM
Joined Jul 2004
I understand….best recomendation will do.
1) Any other recomendations for most consistant power/ voltage distribution to ground station
3) I am asking in reference to using a display. I have heard about Coax to RCA converters and Video buffers which eliminate "blue screen of death"
Thanks!
Old Aug 11, 2011, 12:31 PM
Village Idiot!
Joined Apr 2011
Same as jasmine, 2200 3s powers Rx's and goggles. No reg.
Old Aug 11, 2011, 12:33 PM
Village Idiot!
Joined Apr 2011
Thanks!
I use a lipo, but you can use a car battery if you like.
Old Aug 11, 2011, 12:34 PM
CaliDave is offline
Find More Posts by CaliDave
CaliDave's Avatar
Bay Area
Joined Dec 2010
...and power combo. I put stronger motors onto my TwinStar and while it had nice strength, I could only get about 20 minutes out of it compared the the same setup with a better power combo that wasn't so overpowered. With that setup I was able to get about 32+ minutes with the same battery and flying style.
CaliDave is offline Find More Posts by CaliDave
Old Aug 11, 2011, 04:24 PM
swallabat's Avatar
Joined Apr 2008
Thanks for the help there yabba.
I wouldn't have any objection at all to having it pointed out that I'm off topic, however: Given that the thread is entitled "How to be successful in FPV - A guide for newcomers (Newbies post questions here)", and I am definitely a newbie (at least as far as FPV is concerned) with a fair few questions, I thought this would be the place to ask them..
My confusion aside, I really do appreciate the links, I'll certainly go look at them and see what I can learn.
Discussion How to calculate flight time - guide ikorman Multirotor Talk 16 Jun 26, 2016 07:34 AM
Cool How cool would this be for FPV Kai_Shiden FPV Talk 4 Feb 18, 2016 08:02 PM
Discussion How many FPV pilots in the world? rbmaze FPV Talk 10 Aug 03, 2011 06:16 AM
Poll Would you be interested in buying Ready to Fly FPV airplanes from a new FPV store? FPVNOW FPV Aircraft 36 Oct 06, 2010 08:56 PM
Discussion Can this cam be used for FPV ? SpookiePower FPV Talk 8 Sep 12, 2010 07:12 AM
