This thread is privately moderated by IBCrazy, who may elect to delete unwanted replies.
Old Aug 08, 2011, 09:52 PM
GreenAce92 is offline
Find More Posts by GreenAce92
Physics hate's my ideas
GreenAce92's Avatar
USA, NY, Dunkirk
Joined May 2007
Originally Posted by ScooterInVegas View Post
Oh, I forgot a camera cable $14 and the two little jumper cables $3.50.
http://www.readymaderc.com/store/ind...roducts_id=134
http://www.readymaderc.com/store/ind...roducts_id=282
Camera cable goes from the camera to the "transmitter" cable. transmitter cable was on my original list. Oh, so its a couple bucks over $500. All good stuff though. You can mount the camera behind a prop if you want, cant even see the prop with the camera. I like it.
Alright more things on the list, is there an OSD on here ?
GreenAce92 is offline Find More Posts by GreenAce92
Old Aug 08, 2011, 10:05 PM
TexasAggie is offline
Find More Posts by TexasAggie
Gig 'Em!
TexasAggie's Avatar
United States, TX, College Station
Joined Nov 2010
Originally Posted by IBCrazy View Post
When you say the video quit, I suspect you mean it went blank/blue screen, right? if your monitor goes blue, you need to fix that problem. Monitors going blue is a huge problem and will cut your range by a factor of 20 in most cases.
-Alex
I'm using a laptop and it went snowy - like a VHS with no tape in.
TexasAggie is offline Find More Posts by TexasAggie
Old Aug 08, 2011, 10:55 PM
ScooterInVegas is offline
Find More Posts by ScooterInVegas
Village Idiot!
ScooterInVegas's Avatar
United States, NV, Las Vegas
Joined Apr 2011
You said $500, RVOSD and Dragon Link UHF will set you back $570 more. But well worth it!
Get the stuff on the list from ReadyMadeRC.com and when your ready add the UHF and the OSD.
Oh ya, your going to need a couple of antennas too. Just adding a 8db patch with put you out about 3-5 miles.
ScooterInVegas is offline Find More Posts by ScooterInVegas
Old Aug 08, 2011, 11:13 PM
cactus is offline
Find More Posts by cactus
cactus's Avatar
United States, CO, Durango
Joined Sep 2001
Well, my search as come up with nothing so I'll see if I can get some help here. I have the following equipment being setup for an RC buggy ground system:
Camera
vTx
Various displays and cables have been used to test this new camera. The vTx comes with a nice harness that supplies 12v (three wire) to a camera. Using the supplied camera cable from SC2000 with a BNC to RCA adapter and a 12v wall wart power supply plugged into an old CRT tv shows a nice color picture. This also works going into my old Sony miniDV camcorder. But going into the dvd player and the Range Video tx/rx system I get a b/w picture.
What I wanted to do was make a light weight cable based on this cable so I could use a male servo plug on one end to mate with the Range Video harness. But I get a b/w picture. Is this an impedance mismatch issue causing the b/w picture? If so, what can I do to the cable I made to make it work?
cactus is offline Find More Posts by cactus
Old Aug 09, 2011, 12:59 AM
GreenAce92's Avatar
USA, NY, Dunkirk
Joined May 2007
I'm not even sure if my transmitter could even reach that, what's a good rx to pair with a Hitec Eclipse 7?
Old Aug 09, 2011, 10:20 AM
banzi28 is offline
Find More Posts by banzi28
United States, WI, Eau Claire
Joined May 2011
How are the ReadymadeRC packages? I'm interested in purchasing a package from them to fit to a Hawksky or Bixler. I run Spektrum Rx/Tx equipment (DX8). Our field is quite a strange layout - we have a large hill on one site and a even bigger hill in front of us (about a mile) that's a slowly-growing landfill, but you cannot fly out that far because of the methane-burning power generation plant inbetween our position and the landfill mountain (it's pretty big).
Would 5.8 be the best choice or would 1.3 be okay?
banzi28 is offline Find More Posts by banzi28
Old Aug 09, 2011, 10:50 AM
Village Idiot!
Joined Apr 2011
I was assuming range with the vTx listed AFTER you upgrade to a UHF long range system. FM should get you out a couple of miles. Just hold your transmitter antenna at a 45 deg angle, when you get a radio glitch, hold you trasmitter stright up and turn around. (The plane, not you)
Old Aug 09, 2011, 01:18 PM
GreenAce92's Avatar
USA, NY, Dunkirk
Joined May 2007
Alright thanks! I'll keep that in mind next time I fly.
Old Aug 10, 2011, 01:08 AM
GreenAce92's Avatar
USA, NY, Dunkirk
Joined May 2007
Another question, I have an HD Bloggie, it has an AV Out port, is it possible for me to use this camera via the port?
Old Aug 10, 2011, 01:37 AM
msev is offline
Find More Posts by msev
Joined Sep 2010
Yes Renatoa uses it quite a lot there is also a thread about that subject: http://www.rcgroups.com/forums/showthread.php?t=1041732
..but it has recording time limit of about 30 minuts, but after that you still get av output (in most cases - one guy is experiencing problems)..so you can still fly and record on your ground station...
Btw guys can you list some possible causes of osd reducing rc range..
msev is offline Find More Posts by msev
Old Aug 10, 2011, 01:40 AM
GreenAce92's Avatar
USA, NY, Dunkirk
Joined May 2007
Oh my goodness he tore the camera up! Well that's how you save weight I suppose
This is a great thread! Thank you!
See the way the other guy did his setup, that's how I would do it, I don't see a need to gut the camera (I have a big enough plane) And you can use the camera for other purposes.
Old Aug 10, 2011, 01:52 AM
msev is offline
Joined Sep 2010
Yeah I'll mount mine in a static position at first, I'm scared of panning it, tilt isn't a problem ...
Old Aug 10, 2011, 01:52 PM
swallabat is offline
Find More Posts by swallabat
swallabat's Avatar
United Kingdom, England, Redditch
Joined Apr 2008
Bixler / easy star all up weight question.
Hello, I'm attempting to build a bixler FPV platform. I would like to get the maximum time in the air that I can, but I'm unsure what the all up weight should be. I've seen 600 odd grams quoted somewhere, but since my empty airframe already weighs 480 grams, and my receiver / dragon osd / esc combo adds another 100 grams, and I still need to select a battery and add the camera system. I reckon that I'll be into 650 grams, before I add propulsion or the camera battery...
I've got some real piloting and engineering experience, and I realise that there is a minimum all up weight, and a maximum all up weight for any aeroplane. beyond which one should not go.
Would anyone be kind enough to either advise me, or even weigh your FPV bixler, and tell me the overall weight, plus the size of your propulsion battery? Thanks, Steve C.
swallabat is offline Find More Posts by swallabat
Old Aug 10, 2011, 02:26 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Generally FPV planes fly better heavy because they typically do not maneuver as much as a POV plane. That said, keep it around 850 grams or so for best results. Up to 1000grams is fine.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Aug 10, 2011, 03:47 PM
swallabat's Avatar
Joined Apr 2008
Brilliant, that's a weight off my mind. I couln't see it coming in much lighter than 800grams. Good. I can use a decent size battery. And maybe shield some of the electronics...
Last edited by swallabat; Aug 10, 2011 at 03:48 PM. Reason: Despite nearly 40 years in the trade I still can't spell "electornincs". See?
Discussion How to calculate flight time - guide ikorman Multirotor Talk 16 Jun 26, 2016 07:34 AM
Cool How cool would this be for FPV Kai_Shiden FPV Talk 4 Feb 18, 2016 08:02 PM
Discussion How many FPV pilots in the world? rbmaze FPV Talk 10 Aug 03, 2011 06:16 AM
Poll Would you be interested in buying Ready to Fly FPV airplanes from a new FPV store? FPVNOW FPV Aircraft 36 Oct 06, 2010 08:56 PM
Discussion Can this cam be used for FPV ? SpookiePower FPV Talk 8 Sep 12, 2010 07:12 AM
