Old Dec 14, 2010, 09:15 PM
Alcyone is offline
Find More Posts by Alcyone
The Song of Moses
Joined Nov 2010
DLE Engine Manuals
Has anyone seen the downloadable DLE manuals on Tower? Geez... they're pretty awful. Can anyone explain to me what exactly they're telling you to do to drill the bolt holes for the DLE-55? How do I find the holes that I drilled half depth when I turn it over? I love the "spark plug reading" too. Yellow tipped electrode? When was the last time you saw a yellow tipped electrode? Maybe in the early 80's... or perhaps that was copied from the Chinese manual where they have more sulphur in their gas?
Rewrite these things or delete them, Tower. Give me back the sketchy Chinese manual DL supplied with the 50cc anyday! Don't read the Tower manual. Throw it away.
Alcyone is offline Find More Posts by Alcyone
Old Dec 15, 2010, 07:29 PM
Fokker DII is offline
Find More Posts by Fokker DII
Gas Only
Fokker DII's Avatar
USA So. Cal.
Joined Sep 2010
Actually the Tower manual has a lot more detailed information than I got in my DLE manual from a different supplier.
And about the prop holes, you half drill the finish hole... there is a pilot hole called out. Sounds good for drilling a wood prop.
Fokker DII is offline Find More Posts by Fokker DII
Old Dec 16, 2010, 07:05 PM
Alcyone is offline
The Song of Moses
Joined Nov 2010
Fokker, for someone relying on this manual and following it literally, there's going to be a lot of problems. I challenge you to actually follow one of these manuals to the letter and successfully get to the end without a problem or quickly, for that matter.
On the DLE-55 manual, let's start on page 10
STEP 1) - Why would I need the prop washer to help me find the center of the crankshaft hole? Props already have a hole here, all I need to do is enlarge it (preferably with a reamer).
STEP 2) - this is OK. This is what you're talking about, Fokker
STEP 3) - Now it gets weird! OK, ignition magnet position is good info, but what I'm really going to have to note is the position of the four "outer" bolt holes because in the next step I'm going to have to put the prop washer on to mark the position of these holes.
STEP 5) - You better look at the picture because that's just how you'll have to position the prop washer to drill the "outer" holes right. Hey, why not just tell us to position the prop washer "like so" with the prop "like so" then mark it and drill the holes? Forget about all the steps about setting the engine at compression. You're not teaching us anything.
STEP 6) - OK, so I'm going to use my trusty #35 drill bit on the drill press to drill one "outer" hole all the way through the prop. Then I'm going to switch up to a #5 drill bit to enlarge the hole. Gee, that's a little big, isn't it?
STEP 7) - Whatttt???
STEP 8) - Why didn't you just have me use the dead center tool you made me buy to mark all 4 holes at the same time?
For that matter, I love all of the detailed pics of the connectors on pages 5 and 6.
Nice going Tower!
Old Dec 16, 2010, 08:46 PM
Gas Only
Fokker DII's Avatar
USA So. Cal.
Joined Sep 2010
If you do not own a drill guide then following the steps in the manual are the best way to insure success. I own a drill guide and you can't beat them for accurately drilling your prop.
Step 1 seems like an unused step unless you are procuring or carving your own undrilled wood props.
Step 2 gets the prop in the proper rotation for ease of flip starting. You really don't want the prop at the 3-9 or 4-2 firing position to try to start it.
If you try to mark all 4 outer holes with a dead center locator then drilling them I guarantee that at least 1 will be slightly out of position and the prop will not bolt to the engine.
I guess you just don't like their manual so it does not matter. It is typical of the Chinese translations. Sort of like the Japanese translations of 50 years ago...... pretty bad
Old Feb 13, 2011, 08:41 PM
RCPowerAustralia is offline
Find More Posts by RCPowerAustralia
RC Power Australia
Ipswich, Australia
Joined Feb 2011
RC Power has english manuals for DLE-20, 30 and 55
http://www.rcpower.com.au/informatio...6b9bcce380bb26
RCPowerAustralia is offline Find More Posts by RCPowerAustralia
Old Feb 13, 2011, 09:15 PM
new1200 is offline
Find More Posts by new1200
United States, MO, Cape Girardeau
Joined May 2008
Towers are a lot better
new1200 is offline Find More Posts by new1200
Old Feb 17, 2011, 08:55 PM
RC Power Australia
Ipswich, Australia
Joined Feb 2011
Manuals
Yeh a lot of work has gone into them there great
Old Feb 18, 2011, 12:16 PM
flygilmore is offline
Find More Posts by flygilmore
Pro Bro #1963
United States, VA, Dublin
Joined Mar 2004
Perhaps if you are having that much trouble with the manual (and Towers is far better BTW) then perhaps you should just stick to glow or buy another brand gasser
flygilmore is offline Find More Posts by flygilmore
Data Engine Manuals In PDF - Please Post Dated Manuals Here Happymcc Engines 337 Apr 20, 2016 07:34 AM
For Sale (NIB) DLE Engines DLE-55cc Gas Engine zzr Aircraft - Fuel - Engines and Accessories (FS/W) 5 Nov 02, 2014 06:17 PM
For Sale New DLE-55 50cc Gas Engine/new version of ever popular dl50 3Daddiction Aircraft - Fuel - Engines and Accessories (FS/W) 14 Apr 01, 2009 05:39 PM
