Old Dec 14, 2010, 03:00 PM
miniprinter96 is offline
Find More Posts by miniprinter96
Psalms 23:4
Goshen, IN, USA
Joined Nov 2010
Help!
RC Scratchbuilt from Harbor Freight Piper
I've been working on a scratch built trainer plane using parts from a harbor freight piper cub http://www.harborfreight.com/remote-...ane-92906.html, but it wont get enough power to fly, I'm using a larger prop than recommended, could that be the problem? I also accidentally charged the battery overnight without realizing that the charger didn't have a cutoff, could that have ruined the battery?
Specs
Weight~12.1 oz
Span~39"
Chord~4"
Nose to base of tail~20"
Wing mounted 5" from nose
miniprinter96 is offline Find More Posts by miniprinter96
Old Dec 14, 2010, 03:13 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
The site has too little info on the plane to tell, but it looks like a brushed motor. If it is, there's no way it's gonna spin that big of a prop fast enough to get it flying.
Also, you run a high risk of frying your ESC and motor.
Prop down, or better yet get a brushless/lipo setup. The plane itself looks good, though....
Piece is offline Find More Posts by Piece
Old Dec 14, 2010, 04:51 PM
Psalms 23:4
Goshen, IN, USA
Joined Nov 2010
would it work to try trimming the prop to size?
Old Dec 14, 2010, 05:00 PM
Piece is offline
Piece's Avatar
Joined Aug 2009
Not really, because you'd have to chop off about 2/3 of the material and you'd probably have to make the chord smaller as well. THe prop will be less efficient, and there's balancing to think about as well.
It'd be better to just buy a smaller prop, around the size of the one that came on the Cub....
Old Dec 14, 2010, 05:32 PM
ChillPhatCat is online now
Find More Posts by ChillPhatCat
AMA 537620
ChillPhatCat's Avatar
United States, NY, Lafayette
Joined Oct 2008
The prop is on backwards as well, but it doesn't matter... as others have said it's too big. The convex side of the prop should face forward and the concave part should face backward. Also, you can't glue the prop on and expect it to stay attached. You need to find a hub that will properly attach it to the motor.
ChillPhatCat is online now Find More Posts by ChillPhatCat
Old Dec 14, 2010, 08:01 PM
Piece is offline
Piece's Avatar
Joined Aug 2009
Oh, jeez, I didn't even notce that. I just glanced at the thumbnail in the post; upon closer inspection I must concur that the prop is on backwards.
It looks like you shoved the prop onto a pinion gear on the motor, then glued it. Correct? Is that the prop that came on the Cub?
Old Dec 14, 2010, 09:33 PM
Psalms 23:4
Goshen, IN, USA
Joined Nov 2010
I used heat shrink tubing to enlarge the shaft size to where it would fit, then glued the prop on. Is it bad to have the prop on backwards?
Would the battery be bad because of overcharging it?
Old Dec 14, 2010, 10:15 PM
AMA 537620
Joined Oct 2008
The battery is probably fine. You need to get the prop off and attach the correct sized prop to it and not backwards. They are highly inefficient in that configuration. What happened to the plane that it came from and the propeller/hub that it had? You just cannot attach a prop to the motor like you did, it will not hold up.
Old Dec 15, 2010, 11:14 AM
Psalms 23:4
Goshen, IN, USA
Joined Nov 2010
The plane had been in a crash, and had a broken prop. i ordered the correct size prop earlier today, hopefully will come Saturday!
Old Dec 15, 2010, 07:41 PM
cyclops2 is offline
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
Well you are learning.
The Battery needs about 5 flights to really get strong.
The plane can barely fly in some wind.
Both Cubs I put together needed a different COG.
The props break VERY easy. Or almost break in any grass landing.
THI IS NOT A BEGINNERS FIRST PLANE........A club field is the right place to have it checked out & maybe flown by a good pilot to see if it is ready.
The wall charger WILL overcharge the battery. Feel the battery every 1/4 of a hour. When you feel a little warming, Take it off of charging.
You DO NEED to charge it a couple of hours before a flight.
The battery likes to move around sometimes......use double sided tape or Velcro.
cyclops2 is offline Find More Posts by cyclops2
Old Dec 16, 2010, 08:03 AM
cyclops2 is offline
Joined Mar 2003
96
I have done many different modifications to them. ALL COST MORE THAN parts or another BETTER.. FIRST BEGINNER plane would cost.
I can afford to spend a LOT more money, than I will save.
I suggest you post what you have in parts, what you can spend right now, & what should you do or save up for..... Post in the Beginners section.
You will see the good & bad planes on any budget you may have.
Flying alone is VERY expensive & frustrating. Try to connect with a local ??? AMA flying club. They ARE WHAT YOU REALLY NEED at this time.
below is the website for the AMA. They have hundreds of clubs around the country. type in your ZIP CODE there.
Post back if you have trouble with the website.
Rich
www.flyingmodels.org
Harbor Freight Piper J3 Cub Eljimb0 Parkflyers 6 Jun 26, 2011 01:02 PM
Discussion Harbor Freight workbench - how bad is it? Fly2High The Builders Workshop 68 Mar 13, 2011 06:39 PM
Question will the p51 from harbor freight accept a 11.1 lipo? ZEROSKIN76 Electric Warbirds 0 Dec 12, 2010 03:45 AM
Help! SDM Harbor Freight Piper Cub j-3 Antoni USA - District X 2 Mar 30, 2009 11:14 PM
Discussion Yellow Bee & Piper J3 Cub at Harbor Freight clava Electric Plane Talk 4 Jan 16, 2006 05:50 PM
