This thread is privately moderated by ALL American, who may elect to delete unwanted replies.
Old Dec 14, 2010, 11:03 AM
ALL American is offline
Find More Posts by ALL American
It's Not Too Windy...Man Up
ALL American's Avatar
USA, CT, Wallingford
Joined Oct 2009
Build Log
Airfield Version 2 / FMS Version 5 P51D
Modifications to my Airfield Version 2 P51D (AKA: FMS Version 5)
Click on Photos to Enlarge
Assembled Bird - A work in progress
Description:
Spinner Refit
· Trimmed back of spinner with a Dremel Cut Off Wheel for a close fit to the cowl and then machined it on a router table to true it
· Polished spinner on buffing wheel
Cowl:
· Opened cooling slot in the cowl
· Opened cooling slot behind cowl
· Opened cooling slot in front of battery compartment to allow cooling air through the battery compartment
· Painted all foam behind cowl black
· Re-trimmed cowl to remove silly looking right angle
· Spray painted the Cowl and Rudder in a matching Testors Red to correct factory mismatch.
Motor: = Stock 600KV
· Removed motor
· Added Loctite to motor mount screws
· Checked for motor shaft E-Clip
· Oiled motor bearings
· Added a retaining collar on rear motor shaft to prevent the shaft from ever exiting the plane.
· Corrected motor mount for proper thrust angle = NO RIGHT Thrust, Just Down Thrust
Name: P51 Front.jpg
Description: Name: Spinner Refitting.jpg
Description:
Hobby Lobby Servo Mount / Fairings
· Installed four Hobby-Lobby servo mount / cover / fairings ($17.00) and spray painted silver, black and white to blend in with the trim scheme on the wing bottom.
Name: Wing Servo Holder Installed.jpg
Description: Name: Wing Servo Holder Mod.jpg
Description:
Cockpit and Pilot Detailing
My pilot had come unglued inside of the cockpit. I also noticed the canopy was loose and was bound to blow off in flight. Since I had to remove the canopy for regluing I did a little detailing. It's not scale, but to me it looks a lot better.
The Canopy was so foggy it was hard to see through it so I polished it inside and out. Now it's clear (It still needs to be repainted)
Name: Polished Canopy.jpg
Description: Name: Detailed Cockpit.jpg
Description: Name: Bare Cockpit.jpg
Description: Name: Pilot in Cockpit.jpg
Description: Name: Pilot.jpg
Description:
Steerable / Retractabale Tail Wheel Install.
I have since replaced the mechanical retract with a Hobby King 312 E-Tract. I have used the same method for steering the tail wheel with the new E-Tract.
Tail Wheel:
· Made a T-Bar actuator rod / pushrod for retractable tail wheel from brass bar with a piano wire rod silver soldered- The push rod has a large Z bend so it lines up perfectly with the servo in the servo tray
· Modified tail wheel retract mechanism so servo is in front of the mechanism instead of behind the tail wheel
· Installed retract servo back in the radio compartment’s servo tray, versus having servos in the tail.
· Made a custom aluminum tail wheel leg and steerable tail wheel strut.
· Installed a pull-pull cable setup for steering, using one servo for rudder and tail wheel steering
Name: Tail Wheel Retract Actuator Bar.jpg
Description: Name: Tail Wheel Retract Mounts.jpg
Description: Name: Tail Wheel.jpg
Description: Name: Tail Wheel Close UP.jpg
Description: Name: Cable Exits.jpg
Description: Name: Rear Header for Pull-Pull Cables.jpg
Description: Name: Pull-Pull Cable Installation.jpg
Description: Name: Pull-Pull Cable Installation at Servo.jpg
Description: Name: Pull Pull.jpg
Description: Name: Steerable Tail Wheel.jpg
Description:
Retract Retrofit 2.0
These are the Hobby King 514 E-Tracts. After the plastic mounts failed entirely, I installed this hardwood rail and plywood mounting system.
Name: Front Retract Mounting Rail.jpg
Description: Name: Rear Retract Mounting Rails.jpg
Description: Name: Plywood Retract Mounting Plate.jpg
Description: Name: Locked in Place.jpg
Description:
Name: Finished Retract Open 2.jpg
Description: Name: Finished Retract Open.jpg
Description: Name: Finished Retract Closed.jpg
Description: Name: Finished Retract Strut Covers Close Fit.jpg
Description:
Landing Gear / Retract Updates 2.5
Previously, I modified my wings adding hardwood mounts and 514 e-tracts but I didn't add enough forward rake to prevent the occasional noseover while taxiing on thicker grass.
I have now bent the landing gear struts forward to add more forward rake and I modified the wings so the retracts could close. While I was at it, I cleaned up the bottom of the wings where FMS had left all of the gaping holes for the mechanical retracts by filling them in and covering the entire area.
This modification has substantially improved ground handling to the point that taxiing in rougher grassy areas and hot landings are no longer an issue.
Name: Retract Rake Mod.jpg
Description: Name: Retract Rake Mod 2.jpg
Description: Name: Retract Rake Mod 3.jpg
Description: Name: Retract Rake Mod 4.jpg
Description: Name: Retract Rake Mod 5.jpg
Description: Name: Retract Rake Mod 6.jpg
Description: Name: Retract Rake Mod 7.jpg
Description: Name: Retract Rake Mod 8.jpg
Description: Name: Retract Rake Mod 9.jpg
Description: Name: DSC02854.jpg
Description: Name: DSC02855.jpg
Description: Name: DSC02856.jpg
Description: Name: DSC02859.jpg
Description: Name: DSC02860.jpg
Description: Name: DSC02862.jpg
Description: Name: DSC02872.jpg
Description: Name: DSC02874.jpg
Description:
Servos and Control Surfaces
· All control surfaces (Rudder, Elevator, Ailerons and Flaps) have been properly re-hinged with Du-Bro pinned hinges. 4 Hinges for each elevator and 4 for the rudder. 5 hinges on each aileron and 3 hinges on each flap. (28 Hinges Total = Overkill)
· Re-bent the elevator and rudder pushrods so they are perfectly aligned with the control horns at the tail. Between this and the re-hinging, virtually all friction has been eliminated and there is no binding.
· Replaced stock servos with Hextronic HXT 900 servos for ailerons, flaps and rudder.
Name: Rudder Hinges.jpg
Description: Name: Elevator Hinges.jpg
Description: Name: Wing Hinges.jpg
Description: Name: Re-Bent Tail Linkages.jpg
Description:
Miscellaneous
· Gorilla Glued the hatch magnet onto the hatch because it had fallen off and epoxy would not hold it. I added additional opposing neodymium magnets to the hatch and fuselage for added security.
· Repainted silver and white and black invasion stripes in between hinge lines and touched up all hinge line areas not fully painted at the factory.
· The seats in the fuselage for the Horizontal and Vertical Stabilizer were sanded to allow for a perfect airframe alignment, which is exhibited through the plane’s flight characteristics.
· The Horizontal and Vertical Stabilizers were screwed and lightly glued in with epoxy.
· Much More
ALL American is offline Find More Posts by ALL American
Old Dec 14, 2010, 12:01 PM
Tubo is offline
Find More Posts by Tubo
Old, New Guy
Tubo's Avatar
USA, FL, Fort Walton Beach
Joined May 2010
Thanks for the great info. I got so ingrosed in studying your blog I misposted here.
Tubo
Tubo is offline Find More Posts by Tubo
Old Dec 14, 2010, 12:21 PM
Joined Oct 2009
Tubo
No Problem! Thanks for looking.
If you do a search, I explained how I did all of these mods back in the FMS P51 thread. When I get a chance, I'll copy the text from those posts into my blog.
Regards,
Anthony
Old Jan 24, 2011, 02:11 PM
dotey10 is offline
Find More Posts by dotey10
dotey10's Avatar
Virginia
Joined Dec 2010
I'm back! Will this retract work for my p-51? I know you said something about the hobbyking 312 retract but this is the closest I could find, the 312 is on backorder
http://www.hobbypartz.com/pz-15090-retract.html
dotey10 is offline Find More Posts by dotey10
Old Jan 24, 2011, 02:16 PM
Joined Oct 2009
Yes Dotey. The PZ 15090 is the same as the HK 312 and almost the same as what came in your FMS P51. Follow the procedures I specified in the FMS thread and you'll have your plane back in the air in no time at all. Don't forget that you'll need a 12" servo extension lead for the retrofit. You may as well buy two extensions because sooner or later you will need to replace the FMS E-Tract in the other wing.
Regards,
Anthony
Old Jan 24, 2011, 05:35 PM
dotey10 is offline
dotey10's Avatar
Virginia
Joined Dec 2010
Regards,
Anthony
Ok great. Thanks again for your help. Two more questions...
1. You say that the retract opening where you put the wheel strut is too small? How do you recommend opening up that space? Any tips?
2. Is the speed of the PZ15090 similar to that of the stock fms retract? I think it would actually be cool if their speeds were slightly different!
Old Jan 24, 2011, 05:54 PM
Joined Oct 2009
1. http://www.rcgroups.com/forums/showp...ostcount=10205
2. The PZ 15090 / HK 312 is the same as the FMS e-tract except for the pivot arm, the mounting plate and the length of the servo lead. The 312 has a shorter servo lead than the FMS, the mounting plates are interchangeable so that's an easy fix and the 312 has a better pivot arm with a brass pivot but the hole is 3 mm, versus 4.5 mm.
Regards,
Anthony
Discussion FMS P51D 1.4m Mustang Martyble Electric Warbirds 5 Dec 03, 2010 11:07 AM
Discussion FMS P51D Mustang 1.4m Martyble Foamies (Kits) 0 Dec 02, 2010 01:15 AM
Discussion NEW - Airfield/FMS 1400 mm 57" P51D Mustang **See For Sale section** staged22 Electric Warbirds 1 Aug 24, 2010 12:32 PM
Sold NEW - Airfield/FMS 1400 mm 57" P51D Mustang staged22 Aircraft - Electric - Airplanes (FS/W) 4 Aug 23, 2010 08:25 AM
Found NEW - Airfield/FMS 1400 mm 57" P51D Mustang ALL American Aircraft - Electric - Airplanes (FS/W) 3 Jul 13, 2010 09:42 PM
