Old Dec 13, 2010, 07:26 AM
TheBatman is offline
Find More Posts by TheBatman
Joined Dec 2010
Long range transmitter and reciever
I was wondering if anyone could point me in the direction of a transmitter and receiver with the longest range possible(looking for a couple miles). thanks.
TheBatman is offline Find More Posts by TheBatman
Old Dec 13, 2010, 08:57 AM
radialarm is offline
Find More Posts by radialarm
Stinger!
radialarm's Avatar
USA, TX, Boyd
Joined Sep 2009
I found this the other day, but I'm not sure if it will stretch 2 miles. It's what some of the FPV guys are using.
http://www.dragonlabs.net/site/DragonLink/installation
radialarm is offline Find More Posts by radialarm
Old Dec 13, 2010, 11:31 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
http://www.webx.dk/rc/uhf-link3/uhf-link3.htm
Julez is offline Find More Posts by Julez
Old Dec 13, 2010, 12:22 PM
ferdous7466 is offline
Find More Posts by ferdous7466
ferdous7466's Avatar
Joined Mar 2010
hei can any one tell me how i can increase the range of ordinary 2.4 Ghz radios?
ferdous7466 is offline Find More Posts by ferdous7466
Old Dec 13, 2010, 12:25 PM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
Are they legal?
RC Man is offline Find More Posts by RC Man
Old Dec 13, 2010, 01:27 PM
MikeMayberry is offline
Find More Posts by MikeMayberry
Hitec/Multiplex USA
MikeMayberry's Avatar
Poway, California, United States
Joined Sep 2000
The Hitec AFHSS system is easily good to 3 miles and has the ability to avoid any interference from other 2.4 devices as seen here:
Review: Hitec Spectra AFHSS 2.4GHz receiver and module (part 3) (6 min 2 sec)
MikeMayberry is offline Find More Posts by MikeMayberry
Old Dec 13, 2010, 02:21 PM
chrisf testpilot is offline
Find More Posts by chrisf testpilot
You can call me FANBOY!
Goodlettsville, TN
Joined Sep 2006
Originally Posted by RC Man View Post
Are they legal?
Not in the US unless you are licensed.
chrisf testpilot is offline Find More Posts by chrisf testpilot
Old Dec 14, 2010, 06:52 PM
bingo17 is offline
Find More Posts by bingo17
bingo17's Avatar
Auckland, NZ
Joined Sep 2009
Would this be for FPV or just general long range?
Good for at least 10km if setup properly:
or
or
http://www.immersionrc.com/
@Mike
I used a Hitec Aurora 9 for FPV and got shot down at 1000m so be careful assuming it's good to 3 miles...
bingo17 is offline Find More Posts by bingo17
Old Dec 14, 2010, 06:57 PM
bingo17 is offline
bingo17's Avatar
Auckland, NZ
Joined Sep 2009
What is the receiver sensitivity on the optima's?
or what baud rate does the transceiver use for data comms?
http://www.youtube.com/watch?v=7f43mydRdjA
Old Dec 14, 2010, 07:21 PM
ScottSails is offline
Find More Posts by ScottSails
Balsa addiction since age 3
ScottSails's Avatar
Upstate NY
Joined May 2005
or
or
@Mike
Got shot down? - you went into failsafe?.... or you lost receiver power?.... or there was unexplained 2.4 interference (really really unlikely with Hitec)?
I would think that there is something clearly wrong - either receiver, ESC BEC overcurrent (undervoltage), transmitter output, installation, etc. and maybe it should be sent to Hitec for check out?
Scott
ScottSails is offline Find More Posts by ScottSails
Old Dec 14, 2010, 07:41 PM
bingo17 is offline
bingo17's Avatar
Auckland, NZ
Joined Sep 2009
It went to fail safe.
Unexplained interference on 2.4ghz - never!
2.4ghz is a ISM band frequency, it is used for all sorts of things including ground radar!
Hitec's Frequency hopping makes it more resilient but one wifi access point transferring data at full speed (using 20mhz bandwidth, even worse turbo mode uses 40mhz) within that frequency range will instantly kill your link - (in this case for instance where the plane was 1000m away).
I do however agree that Hitec is good though, better than others but not the best solution for FPV.
Scott
Old Dec 14, 2010, 08:14 PM
Goodlettsville, TN
Joined Sep 2006
Hitec's Frequency hopping makes it more resilient but one wifi access point transferring data at full speed (using 20mhz bandwidth, even worse turbo mode uses 40mhz) within that frequency range will instantly kill your link.
Not with any kind of separation it wont. Even with the receiver or transmitter right on top of a standard wifi access point it should completely kill the link. The Cisco access points we use at work might, but a standard wifi AP like a linksys or similar should have no effect on it. And yes, I have tested it. Even tested using a microwave.
Old Dec 14, 2010, 08:32 PM
bingo17 is offline
bingo17's Avatar
Auckland, NZ
Joined Sep 2009
What does it matter what brand name of access point is used, it boils down to spectrum usage.
What do you mean "tested using a microwave"?
A microwave oven's radiated energy is confined within the walls of the device so should not really affect 2.4ghz control.
Do you have access to a spectrum analyser to confirm your tests?
Old Dec 14, 2010, 09:00 PM
Goodlettsville, TN
Joined Sep 2006
Because industrial access points in some cases use more power and have higher gain antennas than the wifi routers that are sold for home use. So yes it does matter. Spread spectrum devices are by design able to operate simultaneously, that is the point of being spread spectrum. Can devices interfere, absolutely. But two ISM compliant devices operating simultaneously are not going to cause one or the other to stop working.
You are correct, but it is possible albeit not safe to over ride the safety features on a microwave. Or to cause the door seal to leak enough to be apparent on a spectrum analyzer. It was a PC based analyzer, not as accurate as it could be but well enough to illustrate what was happening.
Old Dec 14, 2010, 09:07 PM
Hitec/Multiplex USA
Joined Sep 2000
@Mike
So are you saying that some specific equipment you were using shot you down or it just happened as if you were flying a normal plane? While I'm not saying it could never happen, it's just highly unlikely as there have been almost zero reports of a signal lockout with our system. Did you use scan mode to set your channels?
Mike.
Discussion long range rc transmitter? b-29er FPV Talk 4 Dec 05, 2010 07:10 PM
Discussion long range video transmitter? jstntmcdrmtt FPV Talk 38 Sep 08, 2010 09:43 PM
Discussion long range video transmitter? jstntmcdrmtt UAV - Unmanned Aerial Vehicles 2 Sep 07, 2010 06:33 AM
Long Range Transmitter Question MTS Radios 3 Dec 21, 2008 08:58 PM
long range transmitter madoc Radios 3 Jun 23, 2004 06:35 PM
