Closed Thread
Old Dec 13, 2010, 01:59 AM
tiltrotorcoaxial's Avatar
Joined Nov 2010
EPP Tilt Wing Free Wing CNC wire cut/blade cx foamy freewing
Here is a bench test of the greenwing tiltrotor blade cx, I cant decide on the terminology for this thing, explaining it makes it sound more complicated than it is: It just a flying wing mounted on an axle, so that it can pivot in pitch on the back of a coaxial helicopter. On the axle, a servo is mounted with an arm, which when lowered locks the wing against the fuselage for airplane mode, so that it flies as a tailsitter in airplane mode! If the servo arm is fully raised, the wing weathervanes in the headwinds and the rotor wake from the coaxial's rotors. I was calling it a variable pitch range locking freewing tiltrotor but im looking for better terminology
Tilt Rotor Coaxial Helicopter (locking) FreeWing Bench Test (3 min 25 sec)
Tilt Wing/Freewing Coaxial Helicopter VTOL (1 min 19 sec)
Tilt Rotor Variable Pitch Range (Locking) Free Wing Coaxial Helicopter (1 min 15 sec)
she's all foam! wings cut with cnc hot wire cutter carbon fiber ube spar inside EPP wing look for the white wing
Tilt Wing Coaxial Helicopter VTOL RC (0 min 42 sec)
Tilt Wing Coaxial Helicopter VTOL RC 2 (0 min 40 sec)
Tilt Rotor Variable Pitch Locking Free Wing Coaxial Helicopter (5 min 56 sec)
Tilt Rotor Coaxial Helicopter Para Glider Free Wing (0 min 49 sec)
tiltrotorcoaxial is online now Find More Posts by tiltrotorcoaxial
Old Dec 13, 2010, 06:41 AM
Canadian Bacon
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Great idea for getting into VTOLs What's the mechanism you used to tilt the wing.??
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Dec 13, 2010, 09:34 AM
CMelton
cmelton11's Avatar
USA, NC, Burlington
Joined Jul 2009
cool lets see more i like it
cmelton11 is offline Find More Posts by cmelton11
Old Dec 13, 2010, 01:20 PM
Joined Nov 2010
The wing is tilted by a servo with a metal crank arm (plastic would break). need to build this immediately
Pionowzlot (0 min 34 sec)
Old Dec 14, 2010, 03:49 PM
The lunatic is on the grass
ridgewalker's Avatar
Joined Aug 2008
Very cool!
They look to work pretty well....you must have really taken some time to get it all working right,good job!....and it sounds good.
Any pics close up to see how it all works?...the mechanics of it.
Imagine doing this with a larger heli like a t rex or a blade sr.
Ridgewalker
ridgewalker is offline Find More Posts by ridgewalker
Old Dec 14, 2010, 04:24 PM
Joined Nov 2010
Id like to find a coaxial Trex. I have cad files ready to manufacture a 40lb coaxial helicopter for tilt rotor purposes but it would cost me 5grand. I set my sights too high
Old Dec 14, 2010, 04:37 PM
Wake up, feel pulse, be happy!
C₄H₁₀'s Avatar
United States, AK, Fairbanks
Joined Aug 2009
I have cad files ready to manufacture a 40lb coaxial helicopter for tilt rotor purposes but it woulod cost me 5grand. I set my sights too high
No, you just set your budget too low
This is very cool........... I wonder how it would work on a micro scale (Blade mCX)?
C₄H₁₀ is offline Find More Posts by C₄H₁₀
Old Dec 14, 2010, 04:41 PM
Joined Nov 2010
it always works! ive done this with dozens of different off the shelf coaxials. my next project will be an mcx.
Old Dec 14, 2010, 07:00 PM
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
A question. My memory is that most off-the-shelf coaxes have a 45 degree stabilization flybar that tries to keep the rotor axis vertical.
Trying to tilt the axis too quickly (lots of cyclic) often results in the CW and CCW rotor blades hitting each other or the aircraft body.
How do you avoid these problems? The photos still show flybars.
Do you just change the tilt slowly enough for the flybar to reorient itself?
flying-llama is offline Find More Posts by flying-llama
Old Dec 15, 2010, 12:28 AM
Joined Nov 2010
the blade cx will blade strike cx alot as a tiltwing, but like you said a slow transition can avoid that. the new one i use has the rotors way apart and thus no more blade or flybar strike.
Old Dec 15, 2010, 01:35 AM
Joined Mar 2006
... the new one i use has the rotors way apart and thus no more blade or flybar strike.
Thanks. I forgot that moving the rotors apart also prevents the blades from hitting things.
Old Dec 15, 2010, 07:14 AM
USA
Joined Apr 2007
cofused
i'am lost
space 1 is offline Find More Posts by space 1
Old Dec 15, 2010, 10:21 AM
schumar's Avatar
Duisburg, Germany
Joined May 2007
This is awesome! Can you give us some more info and/ or pictures? I wanna build one, right now!
schumar is offline Find More Posts by schumar
Old Dec 15, 2010, 02:00 PM
Joined Nov 2010
The blade cx tailsitter is just a strap a wing on it deal. hs85mg servo worked for tilting a blade cx, also very easy to engineer. Piloting it is really for beginners compared to torque rolling a 3D YAK foamy. The servo for the big tilt wing is 2 100 oz inch Futabas or one 300oz inch JR. I have more pictures on my rc blog of the internals.
The coaxial tiltwings have the potential to be flown acrobatically (with a coaxial t-rex once someone invents it) although im not a good pilot for it
Old Dec 22, 2010, 11:55 PM
Joined Nov 2010
Closed Thread
Discussion Airscoot Coaxial Helicopter 18.5 volt lipo tiltrotorcoaxial Coaxial Helicopters 46 Apr 06, 2011 10:38 PM
Discussion Freewing/Tiltwing Airscoot coax Helicopter test flight series tiltrotorcoaxial VTOLs 23 Feb 19, 2011 04:51 PM
Discussion VTOL Tilt Wing Coaxial Helicopter flights tiltrotorcoaxial VTOLs 1 Dec 11, 2010 10:50 PM
