Old Jul 23, 2012, 12:27 PM
camilleg is offline
Find More Posts by camilleg
FS One
Urbana, Illinois
Joined Dec 2004
Phil, http://www.fsone.com/systemRequirements.php says nothing about laptops vs desktops. Shape of the box holding the guts of the PC doesn't matter per se.
camilleg is offline Find More Posts by camilleg
Old Jul 26, 2012, 12:40 AM
TTRotary is offline
Find More Posts by TTRotary
Rangers Lead the Way
Joined Mar 2010
What is your return / refund policy?
TTRotary is offline Find More Posts by TTRotary
Old Jul 26, 2012, 06:14 AM
Puzom is offline
Find More Posts by Puzom
Puzom's Avatar
Joined Oct 2007
Not happy with the sim?
Policy is on their site.
Cheers!
Puzom is offline Find More Posts by Puzom
Old Jul 26, 2012, 11:53 AM
TTRotary is offline
Joined Mar 2010
Actually, it is not, or is so well hidden that I couldn't find it - hence my post here. However, CS on their website has been responsive to my email.
Old Jul 26, 2012, 12:22 PM
Puzom is offline
Puzom's Avatar
Joined Oct 2007
Warranty or Customer service..........
Old Jul 26, 2012, 04:52 PM
MSelig is offline
Find More Posts by MSelig
FS One
MSelig's Avatar
United States, IL, Champaign
Joined Sep 2005
Looking for some help here. If there are any Hitec Aurora 9 users reading this thread today, can you let me know if this Aurora 9 FAQ is on the mark:
http://www.fsone.com/tech_6018.php
I just added item 1. The following 3 are same as before.
.... I wish I owned an Aurora 9 ...
Thanks.
MSelig is offline Find More Posts by MSelig
Old Jul 26, 2012, 06:08 PM
TTRotary is offline
Joined Mar 2010
Mike, I'll try this protocol when I get home tonight and let you know.
Old Jul 27, 2012, 01:10 AM
TTRotary is offline
Joined Mar 2010
The procedure provided works fine for the Aurora 9. No glitches.
Old Jul 27, 2012, 08:23 PM
MSelig is offline
FS One
MSelig's Avatar
Joined Sep 2005
Thanks checking it.
Old Aug 11, 2012, 08:16 PM
philfun is offline
Find More Posts by philfun
Windsor, Canada
Joined Sep 2003
stick
Help needed for new user:
I just got FS ONE 2 .I am using a Spektrum Dx6 ,mode 1 ,airplane.
The problem:after calibrating the transmitter some channels are reverse
for example;the up is down etc.
Any way to solve that issue ?
I try to edit as a new transmitter but is freezing fsone.
Except that it looks good.
Phil
philfun is offline Find More Posts by philfun
Old Aug 11, 2012, 08:26 PM
MSelig is offline
FS One
MSelig's Avatar
Joined Sep 2005
A couple of things: Make sure you use the "Universal Tx" per instructions (quick start guide). If you move the sticks per instructions when you calibrate, then it should not be reversed. Make sure you update to the latest version 2.0.9. Sounds like you're running the original V2 from DVD.
You don't need to edit a Tx in the sim.
BTW - With DX6, turn on the flap switch per FAQ on www.fsone.com homepage.
Let me know of this get's you going.
Old Aug 11, 2012, 08:27 PM
Sctholson is offline
Find More Posts by Sctholson
Woodstock, VT
Joined Jan 2007
I was just about to reply... Mike your on top of things tonight!
Sctholson is offline Find More Posts by Sctholson
Old Aug 13, 2012, 05:32 AM
philfun is offline
Windsor, Canada
Joined Sep 2003
fs one
Thanks for the explanations Mike,
Now all surfaces works in the correct direction.
The next step is to improve an existing Tribute
72".This plane fly very close to an a Telink EPP foam 40"Sukkoi.(It's what
I fly in the real world) but need some improvements:
1/ how to move the CG back ?
2/Is it a way to improve the knife edge flight,not realistic now.
3/ Need more aileron ,rudder ,elevator
Another general question:is the transmitter is emitting when connected to
the sim ?
Great sim.Love the simple surroundding.
Phil
Old Aug 13, 2012, 09:40 PM
MSelig is offline
FS One
MSelig's Avatar
Joined Sep 2005
the sim ?
Phil
This is a good question. To start with, the Tribute was designed to be a stable foamie for hovering. It's basically a hover trainer. So I think turning that into your 44" Sukhoi foamie will never be "realistic". They are too different.
How about this idea: Start with the stock E-flite Extra 260 foamie. It's much more aerobatic than the Tribute. Make a copy and then edit it -> go into the Scaling Wizard. Change the wing span to 44 inch and set the weight to match your airplane. Make no other changes. Let me know if this gets you closer from the outset. I hope it does, and then from that point you can make tweaks. But still who knows how close the Extra 260 will get to your Sukhoi.
Once you're in the editor, you can also change the c.g. It's under the "Mass" tab. Note(!): When you're in the "Mass" tab, do not change the weight there. Only change the weight from the "Scaling Size/Wgt" tab at the bottom of the list (left side).
Glad you like the sim!
Old Aug 13, 2012, 09:42 PM
MSelig is offline
FS One
MSelig's Avatar
Joined Sep 2005
Yes, I was stuck on my computer! Par for the course lately.
For Sale Hanger 9 FSOne Rc Simulator: Disks, Cord/Dongle, and Instruction/Box. airplanfreak Aircraft - General - Miscellaneous (FS/W) 7 Jan 07, 2011 07:59 AM
Wanted FSone expansion pack truevine77 Aircraft - General - Miscellaneous (FS/W) 0 Nov 13, 2010 06:54 PM
Sold FSOne flight sim GFBurke Aircraft - General - Miscellaneous (FS/W) 2 Nov 02, 2010 09:06 PM
Sold FsOne NEW!! rcplanes1234 Aircraft - General - Miscellaneous (FS/W) 0 Sep 03, 2010 07:09 PM
