Espritmodel.com Heli Air
Old Dec 12, 2011, 11:57 AM
FS One
Urbana, Illinois
Joined Dec 2004
Diceco, serrations work on non-flat foils too, although we didn't measure that ourselves. The paper cites someone else who did, with the bumps on the LE of whale fins.
camilleg is offline Find More Posts by camilleg
Old Dec 17, 2011, 09:36 PM
RealCrankyGrandpa!
skorski's Avatar
Oak Ridge, Tenn.
Joined Aug 2004
OK,
I'm in trouble now, I just purchased a Vandal DLG!
Now I need an equivalent in FSone!
What's available?
Mike.
skorski is offline Find More Posts by skorski
Old Dec 18, 2011, 09:44 PM
FS One
MSelig's Avatar
United States, IL, Champaign
Joined Sep 2005
Originally Posted by skorski View Post
OK,
What's available?
Mike.
We have a DLG in the pipeline -- Vladimir's Model ELF which looks pretty cool.
MSelig is offline Find More Posts by MSelig
Old Dec 19, 2011, 09:16 AM
RealCrankyGrandpa!
skorski's Avatar
Oak Ridge, Tenn.
Joined Aug 2004
An ELF will do fine!
Mike.
Old Dec 31, 2011, 04:15 PM
Tree Trimmer
bonner's Avatar
alex va.
Joined Oct 2008
Troble loding fs One
my grandfather gave me a FSONE v.1.0 flight simulator.serial number JIETPS-842962 AND IT DOES NOT WORK. Can anyone help me fine a working number so i can download the simulator?
thanks in advance Jeffey Bonner
bonner is offline Find More Posts by bonner
Old Dec 31, 2011, 04:56 PM
FS One
MSelig's Avatar
Joined Sep 2005
I do not know what code you have listed above. I would be surprised if it did work, i.e. it should not work. You will need to find the one that came w/ your simulator (V1). It is usually on the back of the CD package.
ps If you cannot find it, use the contact form on FSOne.com.
Old Jan 12, 2012, 12:07 AM
Cleveland Ohio
Cleveland Ohio
Joined Jan 2006
confusing and non functional sim
i have every sim out there and this new version is most confusing. i am trying to calibrate a 9303 mode 2 tx and a supra. the four servos in wing are really out of wack. can even get simple ailerion. get flaps instead. i am afraid to delete functions for fear they are gone forever. unflyable!!!
where is there a sherman knight for setting up this program when you need one?
Bill
wsnowfall is offline Find More Posts by wsnowfall
Old Jan 12, 2012, 12:40 AM
FS One
MSelig's Avatar
Joined Sep 2005
Bill
Well, I'm no "Sherman Knight", but here goes:
Steps:
1) On the 9303, start w/ a reset model (don't use your Tx programming). You might need to turn off INH (inhibit) on one of your switches.
2) Pick Supra
3) Click on Tx (should have 'Universal' selected per Quick Start Guide)
4) Calibrate per on screen instructions (it's the same for all airplanes)
5) Click on flight manual to see all mixes ... lots of mixes.
... these steps are the same for any airplane in the sim, and taking this route is easy.
So I will guess here that you are trying to use your 9303 programming? Don't do that because it's as hard as doing it in real, and as you might know the Supra has a ton of mixing. BTW: We use all of Mark Drela's mixes per (somewhere) online, and he uses the Evo. All of that programming is already setup for you in the sim w/ steps 1-5 above.
Old Jan 12, 2012, 11:51 PM
Cleveland Ohio
Cleveland Ohio
Joined Jan 2006
setup
I also have an
evo
in the edit secton, i took the jr tx picture and gave it a unique name. than i tried to calibrate it. None of the widgets linked with right servo. i tried to use axis 1 - 4 for main control. it was always stuck in crow and the throttle stick changed them, could not yet get the three postion toggle to do it. i have not used the tacom tx yet; with fs2 i did use my jr ok. i haven tried any of the mixes. i really would like to clean out all the mixes and reenter them one at a time. i am not sure to get rid of mixes. my fear if i delete them they are gone forever.
will try your suggestion tomorrow when i have the time and am not so tired.\
thanks so far. there should be a manual to explain how all those mixes got into the jr tx. btw, i have no problems programming the evo or the 9303, just fsone, go figure
Old Jan 13, 2012, 10:38 AM
Joined Sep 2008
I've been wondering about 90 degree 3.5mm adapters to use on the USB cord which connects to my DX6i. Basically I'm wondering if something like this works without any problems.
http://www.amazon.com/IEC-3-5mm-Ster.../dp/B003U49L2G
I don't like how I have to hold my transmitter with the cord sticking out the way it does on the backside. The jack for the USB cord is right above the battery cover on the DX6i and it really bothers me. I feel like I'm going to destroy my connector for FS One if I keep using it this way.
mwilson914 is offline Find More Posts by mwilson914
Old Jan 13, 2012, 09:45 PM
FS One
MSelig's Avatar
Joined Sep 2005
The connector for the DX6i is a mono plug. So I'd go w/ a 90-deg mono plug because the contact points inside the Tx are designed for mono ... and a stereo plug might not work correctly.
Old Jan 14, 2012, 08:36 PM
Inciting Riots
village_idiot's Avatar
Joined Dec 2006
I'd cut it off and solder on a right angle connector.
village_idiot is offline Find More Posts by village_idiot
Old Jan 15, 2012, 04:38 PM
FS One
Urbana, Illinois
Joined Dec 2004
right-angle Tx cable adapters
mwilson194, a properly wired stereo adapter ought to work fine, as long as tip goes to tip, ring to ring, sleeve to sleeve. A stereo plug at the tx's mono jack means that either ring or sleeve gets no connection at that end... but the same layout happens at the other end of the adapter.
I'm merely belaboring this point because 90-degree mono adapters are hard to find. There's one at http://www.cablesandconnectors.com/25000-25.HTM sku 25016 / PHILMORE # 561A for $5.
But stereo ones are less than a buck in many stores, e.g. http://www.mycablemart.com/store/car..._detail&p=2372 .
Old Jan 22, 2012, 04:11 PM
Inciting Riots
Joined Dec 2006
If a person is willing to solder, there are plenty of right angle stereo connectors out, just jumper sleeve to ring to make sure it works in most "mono" devices (tip/sleeve).
Old Jan 22, 2012, 06:39 PM
Inciting Riots
Joined Dec 2006
What are the chances of getting an F-86 EDF model? One that scales down to the 15 inch size of the new Hobbico plane.
For Sale Hanger 9 FSOne Rc Simulator: Disks, Cord/Dongle, and Instruction/Box. airplanfreak Aircraft - General - Miscellaneous (FS/W) 7 Jan 07, 2011 07:59 AM
Wanted FSone expansion pack truevine77 Aircraft - General - Miscellaneous (FS/W) 0 Nov 13, 2010 06:54 PM
Sold FSOne flight sim GFBurke Aircraft - General - Miscellaneous (FS/W) 2 Nov 02, 2010 09:06 PM
Sold FsOne NEW!! rcplanes1234 Aircraft - Electric - Miscellaneous (FS/W) 0 Sep 03, 2010 07:09 PM
