Old Oct 21, 2011, 02:07 AM
Kris... is offline
Find More Posts by Kris...
Registered Addict
Kris...'s Avatar
United Kingdom, Stoke-on-Trent
Joined Jul 2010
.......Any clues ?
Kris... is offline Find More Posts by Kris...
Old Oct 21, 2011, 01:09 PM
LostVisual is offline
Find More Posts by LostVisual
Launch high, go long
LostVisual's Avatar
Boise, ID
Joined Sep 2006
Originally Posted by MSelig View Post
Yes, we are interested in DLG models for the sim (have none so far).
We have info on the DLG ELF and large MAXA directly from Vladimir's Model.
Do you have experience making 3D graphics models?
We've put some details of the model spec online here:
http://www.fsone.com/modelSpec.php
Ok ... back to that warbird for now.
It would be great to have a DLG in the FS One arsenal. The ELF would be a fun plane but not representative of what guys fly everyday. The Maxa is new (and expensive) and looks like an awesome TD plane. I'm more focused on electric powered gliders. I guess it would be easier to convert a sim glider to electric than a real world plane.
My 3D modeling has been on the mechanical design side using SolidWorks and a little Pro/E. I guess I would use Blender to design for FSOne however since its open source and free? Somewhat the same skillset with a different tool and mindset. I'll read thru the guidelines you've indicated and after some serious flying with FSOne, I'll give modeling a plane a go. I've got my own planes I can use for measurements.
LostVisual is offline Find More Posts by LostVisual
Old Oct 24, 2011, 05:52 PM
bluesky123 is offline
Find More Posts by bluesky123
Crash=change of flying medium
bluesky123's Avatar
Boulder, CO
Joined May 2002
Blender has such strikingly non-standard interface, that it's hard to use it even for people who are proficient with mechanical CAD systems. I'm pretty good with SolidWorks, but I had to go through tons of tutorials to even start doing anything in Blender, but I haven't gotten too far...
Boris
bluesky123 is offline Find More Posts by bluesky123
Old Nov 02, 2011, 01:08 AM
MSelig is offline
Find More Posts by MSelig
FS One
MSelig's Avatar
United States, IL, Champaign
Joined Sep 2005
Originally Posted by Kris... View Post
.......Any clues ?
Focke-Wulf Fw 190 ... almost there.
MSelig is offline Find More Posts by MSelig
Old Nov 03, 2011, 12:57 AM
skorski is offline
Find More Posts by skorski
No conspiracy in theory
skorski's Avatar
Oak Ridge, Tenn.
Joined Aug 2004
OK Mike,
I now posess FSOne V2......waiting for my new computer to be finished.
Do you think i'll have any problems running on a quad core 16gig memory with windows7 & two 10k rpm Hdd's? (vid card will be Nvidea with ?(max)? amount of memory onboard).
600 watt power supply will furnish the juice.
Operating system will be on master Hdd, FSOne on the slave.
Mike(also).
skorski is offline Find More Posts by skorski
Old Nov 03, 2011, 12:58 AM
Kris... is offline
Registered Addict
Kris...'s Avatar
Joined Jul 2010
Nice a new warbird cant wait
Old Nov 03, 2011, 01:21 AM
MSelig is offline
FS One
MSelig's Avatar
Joined Sep 2005
Originally Posted by skorski View Post
OK Mike,
Mike(also).
That's sounds like a really sweet system! Are those WD Raptor drives @ 10k rpm? I've been tempted to get a couple of those ... but I instead opt for 5-yr warranty WD "Black" drives (this approach comes after running through 6 failed Seagate drives in ~2 yrs, literally!).
Old Nov 03, 2011, 02:05 PM
skorski is offline
skorski's Avatar
Oak Ridge, Tenn.
Joined Aug 2004
Mike,
actually one of each!
Bigger one for slave.
Mike(also)
Old Nov 05, 2011, 06:50 PM
MSelig is offline
FS One
MSelig's Avatar
Joined Sep 2005
2.0.8 (r1026) - FW 190 A-8
Some updates here.
We've just uploaded the 2.0.8 update which includes the FW 190 A-8 (20% and 25% scale versions).
We've also added a rewind feature which is pretty cool.
The FW 190 has split flaps which makes the landings pretty neat -- slow w/ lots of drag. We did not include a bunch of mixing (the original did not have it!), so you'll see that when the gear is down there's some nose down pitch from the gear drag and when the split flaps go down there's pitch up from the lift. But with full 90-deg split flaps deployed, it settles into a nice landing approach.
The 25% scale is 102-in span = Giant Scale @ 36 lb similar to the Meister Scale model. The 20% scale is 79-in span w/ 17 lb and close to the Dave Platt model. This smaller one seems to be the more popular size (less $$$).
Old Nov 05, 2011, 09:21 PM
diceco is offline
Find More Posts by diceco
diceco's Avatar
United States, ME, Stonington
Joined Aug 2005
Nice plane that FW. Now if only it had a radial engine sound. There are more model radial engines on the market than ever. How about some sounds? (I never did like the sound of a single two stroke gasser.)
Thanks for the update. diceco
diceco is offline Find More Posts by diceco
Old Nov 05, 2011, 10:49 PM
Lee Jay is offline
Find More Posts by Lee Jay
Joined Oct 2008
This thing flies great except for one thing - it feels like it has right rudder trim built right into the airframe. It's there with or without thrust, with or without gear and regardless of flap angle. I've recalibrated my transmitter and tested with other planes and they all fly straight so what's up?
Lee Jay is offline Find More Posts by Lee Jay
Old Nov 05, 2011, 11:17 PM
MSelig is offline
FS One
MSelig's Avatar
Joined Sep 2005
Yes, something does seem quirky there. Good catch. Looking at it ...
Old Nov 05, 2011, 11:28 PM
MSelig is offline
FS One
MSelig's Avatar
Joined Sep 2005
Ok, figured it out and will make update soon.
Old Nov 06, 2011, 12:16 AM
MSelig is offline
FS One
MSelig's Avatar
Joined Sep 2005
Lee Jay, OK, if you download the update again and install (new exe), it fixes the problem. As you figured out, it was not related to thrust, gear or flaps ... but instead a goof now fixed. Thanks for calling this out!
ps The goof was equivalent to, yes, right rudder built into the airframe.
Old Nov 06, 2011, 09:45 AM
Lee Jay is offline
Joined Oct 2008
What service! Yep...flies good AND straight now. Thanks!
For Sale Hanger 9 FSOne Rc Simulator: Disks, Cord/Dongle, and Instruction/Box. airplanfreak Aircraft - General - Miscellaneous (FS/W) 7 Jan 07, 2011 08:59 AM
Wanted FSone expansion pack truevine77 Aircraft - General - Miscellaneous (FS/W) 0 Nov 13, 2010 07:54 PM
Sold FSOne flight sim GFBurke Aircraft - General - Miscellaneous (FS/W) 2 Nov 02, 2010 10:06 PM
Sold FsOne NEW!! rcplanes1234 Aircraft - General - Miscellaneous (FS/W) 0 Sep 03, 2010 08:09 PM
