Northants, UK
Joined Jul 2003
FWIW,
I have been charging a 2S pair of Kokam 1200HD's at 2C rate with no problems. Also, I have been charging them to 4.28V/cell. In use, after a flight, the cell no load voltage is 3.8 This would suggest I am making little use of the cells, however, on the bench I am consistently seeing 900mah delivered before the same resting voltage is met. Can't explain this. These particular cells were, for the first 5 charges, charged at the 1C rate and it did take 2 hours+ to hit 4.2V/cell. The charger I have put together starts out with 4.9V/cell and this is enough to hit the 2C rate for the first 20 minutes or so. I ramp the voltage down to 4.3V/cell once it hits 4.15ish........ this means I get (for my purposes) a full (900mah) charge in almost exactly an hour. (I had had to use an 18V PSU to get this, the LM wouldn't go to 2A at 14V..............) These cells when in the air are powering a SP400 6V on a 2.3:1 with an APC 8X6 and current draw is maxing out at 8A static. These cells now have over 150 cycles and are showing no signs of wear, other than abrasions due to insertion into plane! Scott |
Yup, agree with Lightflight.
The mA setup is only valid during part of the charge. Then the amps decrease in order to top the desired voltage. At the end, amp are really minimal, and even close to 0 at the very end. That's why it does not take 1 hour at 1C. Constant amp at the start, and constant voltage at the end, different process than for std chargers nicad or nimh ( that's why we need these special chargers, btw). |
Joined Oct 2001
Back to the original question:
Lithiums have 5 times the energy density of NiCd, therefore you can fly 5 times as long for the same weight. This, IMHO, is the main attraction of Lithiums because the main gripe of electric fliers in the past has been short flights. Flights of 30+ minutes are possible without having to carry around massive battery loads. |
The get comments after every flight of my Mustang w/TP7800-2S4 & 3S4P. One glow guy wants to buy it, and everyone one else loves the sound of my four blader; sounds more like the real thing than any glow powered warbird.
Saved 12oz going from P3000s in SPTs (8 & 10); re-geared so I didn’t loose much power by dropping a couple of volts. Flight performance is awesome. Could make one really long flight but I prefer several flights of normal duration. 1st couple of times out I only put 2 flight on a single charge; emptying then a little over half. Yesterday 3 flights on 5100mah, down to 3.7volts/cell; that’ll probably be standard fare. I only draw 33amps @ WOT, so 2AH give me a very nice flight. *** Key LiPo advantage for me – not having to peak before a flight! Or charging between flights Imagine take 3 LiPo birds to the field; do 3 flights on each that’s 9 flights for that day – a very nice day at the field. Oh did I mention, no need to take my charger or deep cycle battery – planes and TX, that’s all!!!! Better than glow no fueling/refueling, or cleaning. |
| Thread Tools | |
| Discussion Reasons why we have it so good..... | Doc Austin | Electric Plane Talk | 12 | Sep 04, 2006 12:18 PM |
| Why EasyStar is so good in wind? | rkhoo | Beginner Training Area (Aircraft-Electric) | 11 | Aug 22, 2005 05:32 PM |
| why are so many people using 12-1300 mah LIPOS? | Willard | Micro Helis | 11 | Nov 23, 2004 06:35 PM |
| Wonder why there is no Good/not-so-good buyer list. | skyking99 | Aircraft - Electric - Airplanes (FS/W) | 4 | May 16, 2004 01:57 AM |
| Why are so many heli esc popping? | bradpaul | Electric Heli Talk | 10 | Jul 02, 2002 04:41 PM |
