Old Dec 12, 2010, 04:47 PM
Ed Crowell's Avatar
Southern Calif
Joined Dec 2005
Canterbury J # 529 Build
I received my Canterbury J sail boat a few days ago and have started to build it. For the people who are not familiar with this boat it is 48 inches long and weight at least 14 lbs and 5 oz. It is sanctioned by the AMYA as a racing class boat, mostly on the east coast. For further information see the following web site{ http://www.pmycsail.com/catalog_1.html }.
I started by building a construction stand made of MDF, not a good choice but if your careful it will work OK. The lead keel is attached by two stainless steel screws. I sanded the bottom of the hull and the top of the lead keel with 80 grit sand paper. I made sure the lead keel and hull lined up before installing it. I then screwed the lead keel to the hull but left a gap of 3/4 inch which I then applied Bondo into the gap on both sides then finished screwing the keel to the hull, then wipe off the excess bondo that squeezed out.
Ed
Ed Crowell is offline Find More Posts by Ed Crowell
Old Dec 12, 2010, 08:10 PM
Ed Crowell's Avatar
Southern Calif
Joined Dec 2005
I started this thread as a build log but forgot to change so it ended up as a Discussion.
Any way to change It?
Ed
Old Dec 12, 2010, 11:01 PM
Taking care of the pond.
MILLERTIME's Avatar
USA, CA, Fresno
Joined Apr 2004
Maybe we should discuss this.
Looking good Ed, I'm watching this build.
MILLERTIME is offline Find More Posts by MILLERTIME
Old Dec 12, 2010, 11:40 PM
poltergeist's Avatar
Pomona, CA
Joined Apr 2007
Looking forward to watching you get this one built Ed. Sailed with you once out at Fairmount Park and your EC12 was absolutely BEAUTIFUL!!! Can only imagine how nice this one will be.
poltergeist is offline Find More Posts by poltergeist
Old Dec 14, 2010, 01:03 PM
Ed Crowell's Avatar
Southern Calif
Joined Dec 2005
I used a rasp to fair the lead keel to the hull, using 2 layers of blue tape to use as a guide. Later I used bondo to fill in the gaps and low spots between the hull and the Keel, then sprayed it with a light coat of primer. It needs some minor touch up but I will deal with that when I get ready to paint it.
So far the weight of the boat with the keel attached is 10lbs 5 1/3 oz.
The minimum weight allowed per class rules is 14lbs 5oz which is what I am shooting for.
Ed
Old Dec 14, 2010, 06:07 PM
Ed Crowell's Avatar
Southern Calif
Joined Dec 2005
This afternoon I put the boat in the tub to check and see how level the shear is on the hull. The starboard side was a little higher so I sanded it down down to match the port side. This should give me a level deck once I install it.
Ed
Old Dec 15, 2010, 05:19 AM
Japan
Joined Apr 2010
This is going to be great. I obtained a Canterbury J "kit" directly from New Zealand, and am now in the process of putting it all together.
My winch mechanism is completed and, yes, the whole thing can be serviced and removed from the main hatch. Obvious details to you guys, but not as immediately obvious to a beginner like me. I've only built one sailboat before, a Metcalf 'Moonbeam" purchased from Britain.
I'll be watching your build with great interest and hope to pick up lots of good information that I can apply to mine.
Forbes is offline Find More Posts by Forbes
Old Dec 15, 2010, 09:02 AM
Ed Crowell's Avatar
Southern Calif
Joined Dec 2005
Forbes,
What are you using for the winch mechanism? I will probably use a digital servo with a double arm.
Ed
Old Dec 15, 2010, 03:02 PM
seefest's Avatar
United States, MA, Bristol
Joined Sep 2009
Beautiful boat. Makes me want to order a kit!! Did you order the deck beams with the kit? Do the class rules book come with the kit? Does it come with plans/rig/deck dimensions? I know, lots of questions.
seefest is offline Find More Posts by seefest
Old Dec 15, 2010, 04:54 PM
Ed Crowell's Avatar
Southern Calif
Joined Dec 2005
seefest,
I ordered the Hull, Lead Keel, Rudder, Wood beam Kit, and Bumper for a cost of $290 including shipping.
The kit comes with a booklet that has the class rules and drawings and written instructions for building. You have to purchase the servos, sails, mast, booms, wood for the deck and deck hardware. Hans Berger the builder of the hull is very good at answering emails.
I plan on documenting all the construction and all the parts cost and suppliers as I go.
Ed
Old Dec 15, 2010, 05:06 PM
Ed Crowell's Avatar
Southern Calif
Joined Dec 2005
Last night I installed the shear planks. The plans suggest you use a strip of masonite on the outside of the hull to even out the pressure when clamping the hull and beams together, or you will end up with ripples on the outside of the hull. I thought I had enough clamps so I did not use the masonite; well I ended up with some shallow ripples on the top edge of the hull. But they are very shallow and may sand out or may need a very thin coat of bondo.
Moral of the story Read the instructions and Follow the instructions.
Ed
Old Dec 15, 2010, 05:39 PM
obses4sail's Avatar
Visalia, CA
Joined Sep 2010
you're catching up, I will have to put some more time in on Second Wind so I can start a 48"
obses4sail is offline Find More Posts by obses4sail
Old Dec 15, 2010, 08:08 PM
Japan
Joined Apr 2010
My sailwinch is a RMG from Australia. I set it up with a pole to the bow for a return pulley and a jib slot adjuster servo. It seems to work OK on the bench, and I hope that it will work as well in practice. here's a couple of photos. Criticisms are welcome, its easier to fix now than during sailing season.
Ian
Old Dec 15, 2010, 09:55 PM
Monterey Bay California
Joined Feb 2004
Looking very nice...
Aerominded is offline Find More Posts by Aerominded
Old Dec 15, 2010, 10:58 PM
Ed Crowell's Avatar
Southern Calif
Joined Dec 2005
Forbes,
Looks like you have it set up very nice; I really like the way you set up the rudder servo. Are you going to have a hatch over the rudder servo for access? What is the (ounce-inch) of torque on your rudder servo? I am trying to find out what is required for the rudder servo.
Ed
Discussion J-Power 50mm T-33 build Frenche Foamy EDFs 114 Mar 15, 2012 10:18 PM
Discussion Anybody here have a Canterbury J sailboat? Ed Crowell Sailboats 61 May 12, 2011 06:50 PM
Discussion 1/5-1/6 scale J-3 Cub build forevercat Scale Electric Planes 0 Sep 20, 2010 10:27 PM
Build Log Canterbury Sailplanes Arrow Build thread. flybaby2000 Slope 34 Feb 10, 2008 01:28 PM
Canterbury Monster F20 build thread Fourthearth Slope 59 Jun 20, 2006 10:09 AM
