Old Jul 20, 2003, 06:56 PM
jas_Qfix is offline
Find More Posts by jas_Qfix
jas_Qfix's Avatar
Santa Clara, CA, USA
Joined Sep 2000
My First Home Made Prop For bitG Rudder Steering 4mm Pager Motor
Have decent thrust to be used in place of mag-coil actuators.
Any tried it yet?
jas_Qfix is offline Find More Posts by jas_Qfix
Old Jul 20, 2003, 07:02 PM
jas_Qfix is offline
jas_Qfix's Avatar
Joined Sep 2000
Prop in motion
These pager motors are getting cheaper and easier to mount.
With bi-directional setting, it can be blended into the vert-stab fin.
With single directional, using two motors. One for each wing tips facing down, we might even use them as flaps to slow down or extra lift to stay afloat. With differential on the two motors for steering
Old Jul 20, 2003, 07:42 PM
jas_Qfix is offline
jas_Qfix's Avatar
Joined Sep 2000
For regular non bitG setups
I planned to use these motors for the one LiPo BitG settings. If you want to stick to the R4P Rx, you might need to cut up a bursted pico servo's driver board. And still control these pager motor proportionally and bi-directionally. Isn't that great?! I am a little worried that these motors might be a little too hot at 5v.
Old Jul 21, 2003, 10:27 AM
Jgardner is offline
Find More Posts by Jgardner
Fanfold abuser
Jgardner's Avatar
Rochester Monroe Cty, New York, United States
Joined Aug 2002
Too hot
I tried it out using a bit motor for steering. Plenty of uumph for the rudder, but the drive motor slowed when the steering motor was stalled at full turn. You may need a resister between the Rx and the steering motor. I do think something along these lines will work well. Lpark had success with the smallest of pager motors.
Jgardner is offline Find More Posts by Jgardner
Old Jul 21, 2003, 05:14 PM
bmutlugil is offline
Find More Posts by bmutlugil
bmutlugil's Avatar
Turkey
Joined May 2002
If gears are not feasible - or even if gears are used - you could use a sliding mechanism that keeps the motor turning without stalling after a certain torque level is reached - don't ask me how, though.. Of course in this case the motor can not be coupled directly to the control surface, the mechanism should take care of the control movement, and there should be a way of adjusting the limit torque level..
Bulent
bmutlugil is offline Find More Posts by bmutlugil
Old Jul 22, 2003, 01:51 AM
AIR MOVER is offline
Find More Posts by AIR MOVER
Master of the Wind
AIR MOVER's Avatar
TEXAS
Joined Jun 2001
yea another fast way is a friction plate that gives once the rudder has moved as far as it can the slipping is still loading the motor up but not stalling it... lil plastic disks work fine... =)
AIR MOVER is offline Find More Posts by AIR MOVER
Old Jul 27, 2003, 05:50 PM
jas_Qfix is offline
jas_Qfix's Avatar
Joined Sep 2000
Everything seems to be scaling as we scale down the size of our plane including the Lipo battery's chemistry, except the servos.
Actuator mag-coil even with gallopping ghost proportional are not real proportional and it suffers heavy gravity influence error.
Hot wire suffers from heavy battery drain and temp cooling errors.
Where is piezo electic? Are Polymer actuators vailable outside the Labs?
Worm gear servo suffers from heavy Mechanical slop.
Should we bring back the old single coil vibrator with spring cocking?
There must be a cheap and simple solution to replace our smaller tiny proportional RC servos.
Old Jul 27, 2003, 06:19 PM
epilot is offline
Find More Posts by epilot
Remote island inhabitant
Joined Nov 2000
In flight my magnetic actuators have a very proportional feel about them although the response does vary according to airspeed. You really can't tell it's not a servo.
Michael
epilot is offline Find More Posts by epilot
Old Jul 27, 2003, 06:28 PM
red91sit2 is offline
Find More Posts by red91sit2
Red Lake Falls, Minnesota, USA
Joined Jul 2003
Sorry for being off topic but can u give me a wiring diagram for that circuit board for the wires that come off the board and what they go to pleez? i was going to make an r/c paper airplane but i couldn't get the board to work.
BTW that is from an r/c microsizer right?
red91sit2 is offline Find More Posts by red91sit2
Old Jul 27, 2003, 07:00 PM
tah is offline
tah
Find More Posts by tah
tah
Oslo, Norway
Joined Jul 2003
Electrostatic actuators?
Has anybody tried electrostatic actuators? In principle, a few pieces of tinfoil and Saran Wrap should do it. But I haven't done the math on this scale.
Page 6 and out of this PDF discusses it: http://www.gravity.uwa.edu.au/honour...onours2002.pdf
Probably need to convert the power up a bit though (they use 2.5 kV = 2500V)
tah is offline Find More Posts by tah
Old Jul 27, 2003, 07:01 PM
jas_Qfix is offline
jas_Qfix's Avatar
Joined Sep 2000
Also see this thread.
http://www.rcgroups.com/forums/showt...threadid=94563
Old Jul 27, 2003, 07:20 PM
Joined Jul 2003
thank u
Data My first Home made double stator motor UAVPilot Electric Motor Design and Construction 22 Aug 03, 2007 04:47 AM
Discussion My very first home-made scatchbuild micro sized foamie!! TheDustyPagan Micro Ready-to-Fly 24 Nov 28, 2006 08:50 AM
Discussion My very first home-made scratch build micro plane! TheDustyPagan Beginner Training Area (Aircraft-Electric) 27 Nov 25, 2006 04:58 PM
My first home made actuators Alfredo Rubio Scratchbuilt Indoor and Micro Models 7 Sep 14, 2004 08:19 PM
Home made decals for foam... Beaver-man Parkflyers 4 Jun 17, 2003 03:50 PM
