Old Dec 12, 2010, 11:09 AM
shrub wacker is offline
Find More Posts by shrub wacker
Got Epoxy
shrub wacker's Avatar
Salisbury Ma
Joined Dec 2004
Contest
Fun build 4-Herr Piper Tri-Pacer
I think I’ll keep it simple this time around ,seeing I didn’t get to finishing the last Fun build entry. This one will be the Herr Engineering PiperTri-Pacer kit#204, 18” laser cut and I’m sticking with the tissue as well, I would like to use the vapor gear in this one but we’ll see this little gem weighs out at?? Should be a fun one. how
Glenn
shrub wacker is offline Find More Posts by shrub wacker
Old Dec 12, 2010, 11:47 AM
jofrost is offline
Find More Posts by jofrost
It flew once before...
jofrost's Avatar
Northwood , New Hampshire
Joined Jul 2004
Hi Glenn,
You are going to like how the Herr kit goes together ( I've done 2 ...as you know and have seen fly first hand )
I'm sure you will knock this one out quite easily my friend
Glad to see you back again this year .
-John
jofrost is offline Find More Posts by jofrost
Old Dec 12, 2010, 12:52 PM
Got Epoxy
Salisbury Ma
Joined Dec 2004
Ya, it appears to be pretty straight forward
I was Looking through old photos to get an idea of a nice color scheme and came across this ol’e Comet ready to fly…ahhh the good old days of getting dizzy and falling down.
Glenn
Old Dec 12, 2010, 01:56 PM
jofrost is offline
jofrost's Avatar
Joined Jul 2004
Glenn
Hi Glenn ,
How'd you know I fell down with my old Cox P40 CL Was great flight while it lasted
Ooooh , I like the military scheme !!
-John
Old Dec 12, 2010, 03:57 PM
glewis is online now
Find More Posts by glewis
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Cool!.
This one looks like it will go really well on the vapor stuff.
A suggestion, I would make the lower fuselage at the nose the hatch and mount the brick as far forward as possible.
That's the way I did my Guillows T-28 and Skyraider conversions. They use the P-51 motor and they are actually overpowered. The cessna/vapor motor might be perfect depending on the weight.
<another> Glenn
glewis is online now Find More Posts by glewis
Old Dec 12, 2010, 05:43 PM
Got Epoxy
Salisbury Ma
Joined Dec 2004
Thanks for the input Glenn, I was hoping the vapor set would be in the range, I think the front landing gear may help as well keeping some weight forward, I learned the hardway on my last build with the Luscomb, It was a bit tail heavy and needed help up front.
Glenn
Old Dec 12, 2010, 06:13 PM
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Yeah the gear will help but use some lightweight wheels.
If you get it finished somewhere around 40 grams it'll fly great.
If it turns out tail heavy you could use the P-51 motor for more power and noseweight.
Old Dec 12, 2010, 08:29 PM
supercubman is offline
Find More Posts by supercubman
supercubman's Avatar
Slaton, TX
Joined Oct 2008
Glenn, great to see ya!! I will be following along!!
Trey
supercubman is offline Find More Posts by supercubman
Old Dec 13, 2010, 05:19 AM
jofrost is offline
jofrost's Avatar
Joined Jul 2004
Originally Posted by glewis View Post
Cool!.
<another> Glenn
Glenn ,
Will the PZ P51 motor work with the Vapor brick ? Was thinking of using one ( Vapor brick ) for the 17" Dumas Tiger Moth ...
-John
Old Dec 13, 2010, 04:40 PM
Got Epoxy
Salisbury Ma
Joined Dec 2004
Not sure John, the Vapor battery is 3.7V 70mAh, and the P-51 is 3.7V 120mAh I'll have to check the Micro thread to see if anyone has tried them.
Old Dec 13, 2010, 05:27 PM
jofrost is offline
jofrost's Avatar
Joined Jul 2004
Hehe...I had quoted the "other" Glenn Still interested to see how this will all go together . Figure I ought to build at least one micro before I go blind
Was looking through the micro threads this morning and stumbled on this ...trying to resist ...must have......Albie
http://www3.towerhobbies.com/cgi-bin...?&I=LXZFK0&P=7
-John
Old Dec 19, 2010, 04:57 PM
Got Epoxy
Salisbury Ma
Joined Dec 2004
Here is a little progress, but not much, this kit is a peanut compared to what I'm used to building, my hands are to big and my eyes are so bad I need a magnifying glass just to see the peices
Here is a shot of the o'le Luscomb Phantom enlarged from 25" ws Comet plan from Fun Build 2 all put back together,
Glenn
Old Dec 19, 2010, 05:15 PM
jofrost is offline
jofrost's Avatar
Joined Jul 2004
Glenn ,
Great progress ! The Herr kits go together nicely ...The Lusky is looking sharp again too !
-John
Old Dec 26, 2010, 09:34 AM
Got Epoxy
Salisbury Ma
Joined Dec 2004
Looks as though we are going to be snowed in for a few days here in the north east, perfect building time as long as we don't lose power
a little more progress this morning, I'm going to keep the build pictures to a minimum, this one is pretty easy
Glenn
Old Dec 26, 2010, 10:56 AM
HawkerTyphoon is offline
Find More Posts by HawkerTyphoon
HawkerTyphoon's Avatar
United States, NY, Patterson
Joined Jan 2009
Looks good, is this one designed by Pat?
It looks LIGHT!
HT
HawkerTyphoon is offline Find More Posts by HawkerTyphoon
Question 1/4 Scale Piper Tri Pacer PA-22 topgun61 Scale Fuel Planes 8 Dec 16, 2011 10:28 AM
Discussion Piper Tri-Pacer? 65stang Control Line 2 Dec 15, 2010 08:51 PM
Wanted Sterling piper tri-pacer astrohog1958 Aircraft - Fuel - Airplanes (FS/W) 0 Nov 27, 2010 07:28 AM
Wanted piper tri-pacer astrohog1958 Aircraft - Fuel - Airplanes (FS/W) 8 Oct 08, 2010 11:08 AM
Contest Build Off: Piper PA-22 Tri-Pacer rebell Scale Kit/Scratch Built 23 Aug 17, 2007 10:04 AM
