Old Oct 10, 2012, 07:28 PM
TcCobra13 is offline
Find More Posts by TcCobra13
TcCobra13's Avatar
Seymour,TN
Joined Feb 2010
ok thanks for the tip i got them out.
TcCobra13 is offline Find More Posts by TcCobra13
Old Oct 10, 2012, 07:48 PM
TcCobra13's Avatar
Seymour,TN
Joined Feb 2010
anyone know what size screws that go in the wing and landing gear are?
Old Oct 10, 2012, 07:58 PM
Galand is offline
Find More Posts by Galand
Galand's Avatar
Long Island, NY
Joined May 2010
The manual says:
LG: 2.5mm x 8mm (picture #5 page 4)
Wings:2.3mm x 20mm (picture #18 page 6)
Galand is offline Find More Posts by Galand
Old Oct 11, 2012, 06:02 AM
hydro_pyro is offline
Find More Posts by hydro_pyro
Blade mSR freak
hydro_pyro's Avatar
Irish Hills - SE Michigan
Joined Jan 2010
Another way to make those screws work is to turn an extra screw into a tap: sharpen the edge of a Dremel wheel with a honing stone, then carefully slice a narrow lengthwise slot into the screw just behind the tip. Similar to a self-tapping screw. This will cut threads into the plastic inserts. Then use the normal screw and it will go in like butter.
hydro_pyro is offline Find More Posts by hydro_pyro
Old Oct 11, 2012, 10:56 PM
hate2crash is offline
Find More Posts by hate2crash
Joined May 2010
Thx Guys for help in deciding between fms and dynam...Question: does stock dynam have a better power weight ratio then FMS?...also I really like the fact that FMS has nav lights...is there a nav light kit available for dynam at Hobbypartz or HK that is cheap and easy to install? Also are red and green nav lights visable on cloudy days when plane gets pretty far out and you can't see it well...Sometimes with my glider i lose site and can't tell if its coming or going away further and never had lights being a newbe...and if you had a red light on one wingtip and green on the other that was visible it would be very beneficial in getting orientation back ... thx again for all the help making this new hobby a much better experience..
hate2crash is offline Find More Posts by hate2crash
Old Oct 12, 2012, 08:52 AM
gooniac33 is online now
Find More Posts by gooniac33
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
Dynam is better in all ways. I have flown the 2 back to back and the Dynam was much better. Light and agile but still very docile as well...
gooniac33 is online now Find More Posts by gooniac33
Old Oct 12, 2012, 09:50 AM
dbc is offline
dbc
Find More Posts by dbc
dbc
United States, FL, Brooksville
Joined Apr 2008
I have the Dynam as well as the FMS 40" and FMS 55" Cessnas. Each plane has different strengths and weaknesses; therefore the "best" will depend on what is important to you.
The factory installed lights on the FMS planes are not very bright and are really only visible late evening or in the dark.
dbc is offline Find More Posts by dbc
Old Oct 12, 2012, 05:56 PM
Joined May 2010
I guess the best choice is dynam..The arf is dirt cheap for what u get...I just hope its not much harder to fly then my axn cloads fly..thx
Old Oct 13, 2012, 06:43 PM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
you will do fine. it is a great plane for the money!!
Old Oct 13, 2012, 08:29 PM
Joined May 2010
Originally Posted by gooniac33 View Post
Well take a look at how I did it. The strips all come ready to go and all you do is power them with a 12volt battery. I use the main battery wired into a brushed esc connected to the gear switch. I recessed the strips into the wings so that they don't affect airflow over the wings and during the day you can't even see them really. But at night this is what you get....
http://www.rcgroups.com/forums/showp...&postcount=306
http://www.rcgroups.com/forums/showp...&postcount=311
Are these lights visible during the day to help prevent loss of orientation? If so i would like to do this to mine when i receive it..thx
Old Oct 15, 2012, 09:48 AM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
Not so much... they are best used at dawn or dusk....and full on pitch black works well too!! Take a look
Flying my Dynam Cessna 182 LED plane (0 min 51 sec)
Old Oct 17, 2012, 11:05 PM
Joined May 2010
http://www.youtube.com/watch?v=k8lRW...&feature=g-upl
very cool...thx
Old Oct 18, 2012, 06:39 PM
Spookeay is offline
Find More Posts by Spookeay
Always puts it on the numbers.
Spookeay's Avatar
United States, AL, Sylacauga
Joined Jul 2012
The new one came today. this will be the 4th in my collection. I had been thinking about doing a USCG for a while but the C-130 has been out of my budget. So today when the new 182 came, I thought, This is a good time to do the CG Paint scheme. First some research to see if they had any Cessna's in there fleet and they did, so here is my version of it...
Spookeay is offline Find More Posts by Spookeay
Old Oct 20, 2012, 04:58 PM
Galand is offline
Galand's Avatar
Long Island, NY
Joined May 2010
Parallel Leds
The 6 parallel connector arrived from HK.
I hooked up the wing leds (2 Greens and 4 Reds) to the balance plug of a 3S after soldering an 80ohm 1W resistor into the red lead.
They all light up perfectly. Resistor is approx 50C and steady. Just a bit too hot to feel comfortable for the fingers after 10 seconds.
Been switched on for 1 hour, no problem sofar.
Old Oct 20, 2012, 07:57 PM
Joined May 2010
Hi I just received this plane... Very nice model....Can someone tell me the best way to hook up the stock nav lights? Should i just plug into 3s 2200 balance plug? I'm just not sure if these lights can handle 12 volts or not....Thax
Sold Dynam cessna 182 Chapino4 Aircraft - Electric - Airplanes (FS/W) 2 Nov 08, 2010 07:23 PM
For Sale CMP 50 Cessna 182 Electric Conversion kc135boomer Aircraft - Electric - Airplanes (FS/W) 8 Nov 03, 2010 11:14 AM
For Sale New CMP Cessna 182 63" $95 local in Western NC 34Ford Aircraft - Fuel - Airplanes (FS/W) 0 Oct 09, 2010 08:09 AM
Sold NEW - Hobbico Cessna 182 Skylane Select Scale Rx-R FlattyFlier Aircraft - Electric - Airplanes (FS/W) 5 Sep 21, 2010 08:25 PM
