Old Sep 20, 2011, 07:28 PM
hydro_pyro is offline
Find More Posts by hydro_pyro
Blade mSR freak
hydro_pyro's Avatar
Irish Hills - SE Michigan
Joined Jan 2010
Broke the shaft on my blue motor tonight. Pulled up too early on takeoff with a half-discharged pack, tip stalled, flipped and tumbled.
What can I use as a replacement motor? I don't care if I need to switch to a more standard-style shaft and prop, as long as I can still get it balanced and clear the cowling.
Can I swap out the bearings and shaft to something more typical?
thanks...
hydro_pyro is offline Find More Posts by hydro_pyro
Old Sep 20, 2011, 09:47 PM
dbc is online now
dbc
Find More Posts by dbc
dbc
United States, FL, Brooksville
Joined Apr 2008
Chad:
PM'ed you with some suggestions.
Let us know what you come up with.
dbc is online now Find More Posts by dbc
Old Sep 21, 2011, 08:46 AM
12345 is offline
Find More Posts by 12345
I am Bill
12345's Avatar
United States, AZ, Mesa
Joined Feb 2010
thanks...
Eflite power10 looks like a decent fit, I plan to upgrade mine with one, soon as I find the time.
12345 is offline Find More Posts by 12345
Old Sep 21, 2011, 02:57 PM
Blade mSR freak
hydro_pyro's Avatar
Joined Jan 2010
Thanks for the PM, dbc.
The shaft could not be removed from my flux ring. Even with the allen set screw loose, it will not budge. Heat cannot be used, as it may weaken the magnets. That fact also makes silver brazing difficult, not to mention the heatsinking effect.
The Power 10 is almost double the weight of the Dynam blue motor, and costs half as much as the entire plane. Not sure is the stock 30A ESC would work with it, as I have very little experience with matching up these combos.
Old Sep 21, 2011, 03:10 PM
dbc is online now
dbc
dbc
Joined Apr 2008
The power 10 would not be an appropriate choice - far too large and heavy.
Hydro:
The motor shaft is always a tight press fit onto the bell. After loosing the grub screw, use a large vice and a shim for the bell ( a large socket works well). You can almost always press the shaft out like this without damaging the bell. Alternatively, others hammer the shaft out; but that's not recommended.
Problem is going to be finding a suitable replacement. I think the shaft dia is 3.17 mm and you'll find lots of generic replacements in this dia. You might have to settle for a slightly shorter, unthreaded shaft and use a prop adapter.
If you'd like to try the headsup motor I mentioned, I've still got the one I used and would sent it to you, if you want. As I recall, it's a "drop in" fit and does an adequate job of powering the plane.
I could also suggest other appropriate choices. There are lots of other 2830 1100kv motors that would work.
Old Sep 21, 2011, 05:35 PM
12345 is offline
I am Bill
12345's Avatar
Joined Feb 2010
Sounds like you have it all figured out. Happy flying. . . .
Remember if you want answers to your questions on RC groups, the best way to get one is, to post something incorrect and people will come out of the woodwork to correct you. Peace
Old Sep 21, 2011, 05:48 PM
dbc is online now
dbc
dbc
Joined Apr 2008
Nitro has put the ARF version back on sale for $79. Maybe just buy a backup and use it for parts.
Old Sep 21, 2011, 06:36 PM
Blade mSR freak
hydro_pyro's Avatar
Joined Jan 2010
I got that email too.
Says 950kv, hope it's actually the 1100kv blue, not the red.
Might get one anyway for the motor and a spare airframe.
Old Sep 21, 2011, 08:03 PM
Blade mSR freak
hydro_pyro's Avatar
Joined Jan 2010
Oddly, their sister site shows the blue 1100kv motor in stock...
http://store.yahoo.com/yhst-62196343...15-kv1100.html
We'll find out soon if they actually have it and ship it...
Old Sep 21, 2011, 09:00 PM
dbc is online now
dbc
dbc
Joined Apr 2008
I got a backup last time they were on sale for $79 a few weeks ago. It has the blue motor.
Interesting they show in stock one place and out another - you never know for sure when you're dealing with Nitroplanes!
Old Sep 22, 2011, 09:37 AM
dbc is online now
dbc
dbc
Joined Apr 2008
Hydro:
Check out the last post in this thread from Okie 1. The motors used in the Grand Cruiser are the same as the Sky Trainer. Apparently, he's found a suitable replacement shaft for the blue motor:
http://www.rcgroups.com/forums/showt...314947&page=70
Old Sep 22, 2011, 07:00 PM
Blade mSR freak
hydro_pyro's Avatar
Joined Jan 2010
Indeed... thans again for the link. Here's the shaft kit, $2.99...
http://www.graysonhobby.com/catalog/...bly-p-247.html
They also list several bearings for this size shaft-- My front bearing is VERY noisy. http://www.graysonhobby.com/catalog/...8a01395472f1ad
Old Sep 23, 2011, 03:40 PM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
yea, all those sales end 9/26 (or when they go out of stock)
Melnic is offline Find More Posts by Melnic
Old Sep 29, 2011, 08:44 PM
Blade mSR freak
hydro_pyro's Avatar
Joined Jan 2010
My new Dynam (BLUE) motor arrived for the Cessna. Installed today. All better.
Old Sep 30, 2011, 07:10 PM
dbc is online now
dbc
dbc
Joined Apr 2008
Good to hear your Cessna is back in action, Chad.
The 1100kv Dynam motor just works best with this plane. It sounds raspy but sure powers the plane nicely. I've tried several other similar sized motors but nothing works as well.
I'm still flying mine almost daily and now have 194 flights on it.
Sold Dynam cessna 182 Chapino4 Aircraft - Electric - Airplanes (FS/W) 2 Nov 08, 2010 07:23 PM
For Sale CMP 50 Cessna 182 Electric Conversion kc135boomer Aircraft - Electric - Airplanes (FS/W) 8 Nov 03, 2010 11:14 AM
For Sale New CMP Cessna 182 63" $95 local in Western NC 34Ford Aircraft - Fuel - Airplanes (FS/W) 0 Oct 09, 2010 08:09 AM
Sold NEW - Hobbico Cessna 182 Skylane Select Scale Rx-R FlattyFlier Aircraft - Electric - Airplanes (FS/W) 5 Sep 21, 2010 08:25 PM
