Dec 11, 2010, 11:07 PM
Joined Jan 2010
I just wanted to expand a bit on what Bartricky said:
Increasing diameter will give you more thrust, but will also reduce RPM and therefore will normally cost you speed.
Increasing pitch should give you more speed, but because you lose some thrust it can technically also take away speed if you're trying to get a very draggy plane to an unnaturally high speed.
For your sleek, aerodynamic wing, you'd want to go up in pitch without going up in diameter. Looking at the APC prop list, your only real choice is a 4.75x5.5 Speed 400. Running some numbers through one of the flight calculators, I'd say you're quite close to the limits on your motor to begin with, and that small change might bump you over the edge. For the cost of the prop, it's worth trying if you have a wattmeter, but you may find the only solution is More Power™, which would require a motor change. You can often do very well for high-speed models with a lower Kv running on more voltage to get the RPM back.
