I think there are a lot of other factors to consider.
We need more info. It is true that breaking a CF joiner at launch can be catastrophic. That is worth consideration. R, Target |
Latest blog entry: Stork 4 Pro X-tail from...
United States, MA, Waltham
Joined Dec 2001
If it was me, I might well cut my own joiner from 1/4" music wire. The reason to use ejector pins is when the diameter is larger than available music wire sizes. Up to 1/4", the yield strength (in psi) on music wire is very high. OTOH, you don't trust the joiner box. So in that case a titanium rod will allow you more warning because it bends a lot more. (I know this from personal experience with my Anthem.) But, as I recall, the yield strength is likely to be 140kpsi, which is a lot less than the music wire. If you can, it would probably be better to reinforce the joiner box somehow and keep the steel rod. I used to have 3 or 4 bent 3/8" titanium rods. (Of course, they were undersized for that wing.)
Weight is probably not going to be a major consideration unless you change the airfoil. Older, thicker airfoils need a certain amount of speed to work right. If you go too light, it will be too slow, the Reynolds number will be too low, and it won't fly well. At a large span you can afford a bit more loading anyway. Is it really less work to make the existing wing a d-tube and also make those other parts? If you started from scratch you could use a better airfoil. Either way, though, I'm sure you could end up with a nice flying glider. |
Latest blog entry: pics from Winthrop, MA indoor flying...
| Thread Tools | |
| Wanted Steel wing rod for Fusion | fruitguy | Aircraft - Sailplanes (FS/W) | 2 | Nov 15, 2010 06:54 PM |
| Question Rudder set up : Pull/Pull vs Carbon fiber rod | NUMB-LOCK | Giant Electric Planes | 4 | Nov 09, 2010 09:59 PM |
| Carbon Vs Steel rod | rscarawa | Sailplane Talk | 17 | Jun 30, 2005 02:22 AM |
