Old Dec 11, 2010, 04:11 AM
Rusty Old Fart is offline
Find More Posts by Rusty Old Fart
Zombie Apocalypse
Rusty Old Fart's Avatar
Newcastle, Australia
Joined Nov 2010
Build Log
Swifter build has begun
I couldn't help myself when I seen on R2Hobbies they Swifter Hydroplane Hulls for $28 small injuries to the hull but nothing that can't be patched back perfectly and followed a coat of Pearl.
Anyway I spent some time today using what I may learned from you in the past few weeks and put together what I think will be some decent running to achieve some rip roaring pace.
1. X 440 prop to start with and I still don't quite understand it but that's where i'll stat and hope you help me over the next few weeks.
2. The ESC will be Turnigy 180A or the Seaking 180A whichever is easiest to obtain. I'm sure this ESC is the best choice you all use them and recommend them
3. Leopard 4074 2000kv x 14.8v = 29600rpm. Pretty close to the 30,000RPM Target I have been reading about.
4. Casual Batteries with longer run time while sharing the waterways with the young bloke. A Parallel setup. (I already own these)
Turnigy 5000mAh 4S 40C 578grams 149mmx49mmx37mm. They are heavey suckers so performance will be impacted I understand that.
Sports Sprint run batteries Serial setup. Sharing the waterways with no-one
Turnigy 5000mAh 2S 40C $27.10 308grams 147mmx49mmx18mm
Turnigy 5800mAh 2S 25C $29.55 336grams 149mmx50mmx19mm
What difference do you think there will be between the 5000 40C and 5800 25C
Half the thickness, nearly half the weight. Surely to be a substantial performance increase, maybe these batteries may prompt a prop change as well, we will see.
List of changed equipment
1
New motor Leopard 3660 2050kv
2
New Batteries to add to the list. With weight in mind
2S 4500Mah 30C serial run
3 Prop Idea's
X642, X436, X438,X440
I have found lots of 1sqm sheets of 3K carbon weave 1K wave a CF tissue, super thin, FG 0.2mm to 2mm thickness, CF tubes and square tube, flat strips, buying up a fair bit to get the kitty restocked. The inside of this hull is getting a layer of CF. Scorp here comes the CF and aluminum BLING factor sorry I can't help it.... Battery pods from the carbon sheet and fixed with velcro so the the COG can be tweeked,
The misses has been saying Another package has turned up for you. A box with Castle Creation has arrived, Tubes of things. I'm sitting in this fg Hospital and can't my hands on it.....uuurrrrrr Look out next week when i get home Xmas will be here early.
If you think I've off on a bender somewhere let me know or if you have a better idea let me know I would love your help.
Rusty Old Fart is offline Find More Posts by Rusty Old Fart
Old Dec 11, 2010, 04:26 AM
F1 madness is offline
Find More Posts by F1 madness
F1 madness's Avatar
Staffs UK
Joined Feb 2010
Hey bud,the 4074 will be too big for that hull,id probably go with 1 of these on 3s setup
http://www.astecmodels.co.uk/catalog...oducts_id=1184
http://www.astecmodels.co.uk/catalog...oducts_id=1215
or if your dead set on 4s 2p
http://www.astecmodels.co.uk/catalog...oducts_id=1187
http://www.astecmodels.co.uk/catalog...oducts_id=1186
Just got to remember its only 25" long
F1 madness is offline Find More Posts by F1 madness
Old Dec 11, 2010, 04:30 AM
Flying Barry is offline
Find More Posts by Flying Barry
Australia, NSW, Sydney
Joined Jan 2007
Hey Rusty, before to you get to far advaced on the buying
You will have trouble fitting an 180A up the front in this hull all you need is a 120A max....heaps of power. I only run a 60A in mine and it goes like a rocket on 3s in parallel.
Barry
Flying Barry is offline Find More Posts by Flying Barry
Old Dec 11, 2010, 04:55 AM
Zombie Apocalypse
Joined Nov 2010
Ok I had a quick look and the motor 4074 is 23mm longer than the one in the build pictures from the website, I didn't think it would have been a problem, so a 3S build instead you think.
Baz as you say with yours the batteries are in the sponsons, I have a Tuenigy coming in for the Ocean cat build so I will wait to see if it fits in front of the motor under the raised front section. That curved cabin bit which is a waste of space could be remodded with some CF and create a nice space.
Or here I go already a complete rethink and go 3S. I finally thought I was clever and worked out a build, well Nearly. All good though
72x68x34mm
Old Dec 11, 2010, 05:05 AM
Joined Jan 2007
Rusty, the front curved bit is where the ESC goes up the front and the bat's go in the left/right sponsons if you are ever going to get the CG at 3/4 behind the rear of the sponsons.
PS: You will also need to add a spacer to the bottom of the rudder mount as the transom has a slight negative angle.
Barry
Old Dec 11, 2010, 05:07 AM
F1 madness's Avatar
Staffs UK
Joined Feb 2010
I would go 3s.
Heres my 24" F1 on 3s and 3600kv inrunner and 34mm prop.
(too high kv really but was fun)click on pic
Was having trouble with esc,but the 1st pass was about 3/4 trottle
Posted it just to give you a rough idea
Old Dec 11, 2010, 05:15 AM
Zombie Apocalypse
Joined Nov 2010
sorry for the rough scribble but i'm not on my PC hospital crap.
Old Dec 11, 2010, 05:19 AM
Joined Jan 2007
Daz, that was running sweet shame about the ESC.
Ok, signing out now as moving house will post soon when i have internet access again?????
Barry
Old Dec 11, 2010, 05:26 AM
Zombie Apocalypse
Joined Nov 2010
OK i found a Leopard 3660 2050kv in 4S puts me at 30340rpm, just a tad over the 30,000rpm magic figure. Just need to find a water jacket now to suit.
F1 that thing flies on a 34mm is that like a X434 1.4 pitch.
Old Dec 11, 2010, 05:31 AM
Joined Jan 2007
Rusty, can do but this will make it week in this area, not nessacery.
All i did was to make up a nice little wooden tray to velcro the ESC to up in front of the motor.
Out now or PM if you need more advice....
Barry
Old Dec 11, 2010, 05:34 AM
F1 madness's Avatar
Staffs UK
Joined Feb 2010
Barry
Was bud,but when i got a new esc 1st run,just hit the throttle to find out what it could really do,bam hit somthing in the water and punctured the under side of the hull,dont know what i hit but wrecked the boat,may have to build a new after watching that vid LOL
Cool will speak too you soon barry,good luck with the move
Astec sells the leopard jacket for them:
http://www.astecmodels.co.uk/catalog...oducts_id=1194
Yep 34mm,1.4p plastic prop spinning unloaded 39960 rpms but it stayed in 1 piece
Old Dec 11, 2010, 05:48 AM
Zombie Apocalypse
Joined Nov 2010
I'm willing to change
This has been fairly painless to change before I order the motor on monday.
Cooling jacket
Leopard 3660 2050kv
Old Dec 11, 2010, 05:55 AM
F1 madness's Avatar
Staffs UK
Joined Feb 2010
Cooling jacket
Leopard 3660 2050kv
Cool look forward to seeing it put together
Old Dec 11, 2010, 06:13 AM
Zombie Apocalypse
Joined Nov 2010
All I need to do is CF wrap this broken thing and get out of this hospital.
Old Dec 11, 2010, 06:42 AM
F1 madness's Avatar
Staffs UK
Joined Feb 2010
Get well soon bud and take it easy
Build Log The Official Raven 3M build thread has begun. Windependence Sailplane Talk 1560 Oct 24, 2014 11:58 PM
Build Log Blackburn Beverley Build Blog Begun mountainman2442 Scale Kit/Scratch Built 289 Jul 17, 2008 02:10 AM
It has begun..... Arbo Life, The Universe, and Politics 147 Sep 20, 2005 05:03 PM
Finally, my ALU Corona build has begun. uglyplane Electric Heli Talk 35 Jan 30, 2004 07:37 PM
