Australia, NSW, Bungendore
Joined Jan 2005
Details Drag on ........
I'll remember that Charlie
![]() I finished the wing-top dummy mounting hardware for the struts, added a less-than-satisfactory mirror (but it does reflect) and the blisters over the aileron horns. The aileron horn covers were pressed using a shaped wooden plug into a slot using a scrap of .010 styrene sheet. They are fixed in place using beaut little 'lag screws' from MicroMark. The horns are fixed in place with grub scews and may need final tweeking one day so the covers can be unscrewed just like the real thing ![]() The mirror is a bit of aluminised card with a painted surround. If I can find a better 'mirror' material some time, I may replace it. I still havent done the pilot's seat and control column - maybe next..... Pat |
Latest blog entry: A Big Move.....
Joined Jan 2005
A Nice Day Out......
I took a day off building and visited a local club's Scale Day. There are at least 6 clubs within a 50mile radius of home so plenty of activity to choose from! Probably the most impressive model in the air was a huge electric Amiot 163 from the Traplet plans and having three scratch-built French aircraft seen together was a rare photo opportunity - probably not to be repeated in our area.
The Potez won First prize in the Civilian scratch build section but due to rising winds, was the only model I flew. Bothe Morane Saulnier and the Rake Albatros DXI recieved a lot of interest - they were different ![]() Here are a few pictures - one rather poor shot shows the AI's cockpit with pilots seat and stick barely visible in the shadows. Only Carby intakes, foot step, seatbelts/pilot and a couple of filler caps to go......then a dreaded maiden ![]() Now all my ramblings can be transferred to the Fokker D.VII build thread. In the meantime, Peter wants his DXI article written. No rest yet! Pat |
Joined Jan 2005
Yes Larry - a spray of dull-coat would have made it look more realistic. The model had a sound system and looked magnificent in the air. So it should - it is a BIG wing!
Pat |
Joined Jan 2005
I was sent some photos of the AI at a flying day just before I'd 'finished' her (no rigging and aother sundries). Even though of low resolution, they looked quite nice. The AI wont fly for a while yet because I nicked the motor to fit in Peter Rake's new DVII design. I must order a new one
![]() Pat |
| Thread Tools | |
| Help! Need help on how to setup my plan on pdf | paul74 | Pusher Prop Jet Models | 5 | Nov 20, 2010 06:00 AM |
| Discussion Another FREE plan on Scale Soaring UK | VincentC | Scale Sailplanes | 1 | Sep 04, 2010 10:58 PM |
| Discussion FunBuild 2 (Martin MO-1) enlarged Peter Rake plan has flown | Newtron | Scale Electric Planes | 45 | Mar 18, 2009 10:51 PM |
| Contest Kit/Plan Fun Build-Rake Bristol Scout-and a big Thank You | Bkarr | Scale Electric Planes | 40 | Jun 19, 2008 10:50 AM |
| Peter Rake plan in FSM | Brian T | Scale Electric Planes | 8 | Jan 03, 2005 03:07 PM |
