Old Dec 26, 2010, 06:01 PM
pistaandrea is offline
Find More Posts by pistaandrea
Joined Mar 2005
These are the USD prices the kit could be sold for:
They are based on the servo-city gears prices and my time spent by the machine. I do not plan to sell the servos, only the wooden cut parts including all the gears and carbon fibre tube for the turner.
I will modify the tilt for the HS55 servo to make it lighter.
I will arrange for the sell only if there are at least 5 people interested.
Material, carbon fiber tube and gears -45
Cutting -65
Postage according to the destination. Should be no more than - 15
Servos would be about 58:
HS225 (180 turner) - 28
HS55 (tilt) - 10
GVS S125T (pan) - 20
The payment goes through Pay-pal. Those who are interested PM me.
pistaandrea is offline Find More Posts by pistaandrea
Old Dec 26, 2010, 06:13 PM
anestetico is online now
Find More Posts by anestetico
Brazil
Joined May 2009
I am interested for the pan e tilt kit, your isn't made of plastic? I don't plan to install on a easystar so don't need the fuselage part.
GWS sailing winch servo I use on the mentor does 360 but doesn't center fine.
Really nice work!
anestetico is online now Find More Posts by anestetico
Old Dec 27, 2010, 01:23 AM
Joined Mar 2005
Originally Posted by Arley
I'm interested in your pan n tilt. I'm in calif (93551). Let me know when your ready.
I got 5 people already. The kit consist of the tilt,pan,and 180 turner. Pan and tilt could be used for any plane with undercarriage. The turner is only for the easy star plane. Some of you requested only the pan and tilt unit. Please specify.
Be aware that the tilt servo must be modified for 360 rot. and the pot must be placed on the tilt axis. All will be ready in the kit, but the modification must be done by you.
If you do not need the turner, it will be 20 USD off.
The mount is to be used for the below the fuselage placement. It is able to look directly below. If you want to place it above, in to the cockpit there are better and cheaper mounts, If you still want mine, I will modify the tilt for you, so it suits better.
All is made of plywood, aluminium tube for the tilt pivot, carbon fibre tube for the turner.
CA glue will do the job.
Old Dec 27, 2010, 10:52 AM
alexedit is offline
Find More Posts by alexedit
alexedit's Avatar
United States, FL, Miami
Joined Dec 2008
ok where can I buy this?
alexedit is offline Find More Posts by alexedit
Old Dec 28, 2010, 01:27 AM
Joined Mar 2005
Those interested, send me a PM. Specify if you are interested in the whole kit adapted for the Easy Star plane including the turner. The Payment will be done via the Pay-Pal. Do I have to redesign the tilt for HS 55? That servo is small but not very resistant to RF intrusion.
Old Jan 03, 2011, 05:30 PM
Joined Mar 2005
Hi.
I have sent out some mounts for those who requested.
I made several more kits and packed them for others.These are after the modification. Now the pot is smaller and the tilt is widened to make it suitable for the upper and lower placement. Now it could be mounted to any plane below or on top of the aircraft.
During the improvements I made two units (without the rotator) to test my new ideas. They are to go out of the house. All working - ready to fly.
Servos GVS 360 rotation and turnigy TGY-90S metal gear, modified to work with the outside pot.
Price 150 USD for each.
Sending some more pictures.
Old Feb 10, 2011, 05:15 AM
nick.sargeant is offline
Find More Posts by nick.sargeant
Perth, Western Australia
Joined Dec 2005
Has there been any progress on this mount? I'd love to get my hands on one.
Cheers,
Nick
nick.sargeant is offline Find More Posts by nick.sargeant
Old Feb 10, 2011, 06:53 AM
QUIKSILVER is offline
Find More Posts by QUIKSILVER
QUIKSILVER's Avatar
UK
Joined Sep 2002
Originally Posted by pistaandrea View Post
The GWS servo is the same I have. It is big and heavy but it works nicely.
Even if there is a mix function active, the camera could move in the bay as a result of some kind of RF interference. FPV planes carry a lot of RF power on board.
Regarding my old design - The Carbon EYE - was made for a Surveillance UAV plane. Its production was difficould and expensive. I have sold some of them, but not many. Having a retractable camera is nice but people must not forget to retract. You would not believe how many of them returned the unit broken just because it was exposed when landing.
I started a thread about it some time ago:
http://www.rcgroups.com/forums/showthread.php?t=991942
Carbon Eye on a Dragon Eye plane
http://www.youtube.com/watch?v=htNc3...layer_embedded
http://www.youtube.com/user/Andrita3.../0/zE37JTTSvW8
Regarding the go pro mount - it should be as easy to build as possible. The only difficould task is to make the gears and mount them properly not to allow for any backlash. I used gears from an old printer. I also draw them and made them on a milling machine. Well not everyone can have a milling machine in the workshop though.
I thing the servo manufactures should start thinking about a 360 servo - like they did in China. That is where the GVS 360 comes from.
Pista, what milling cutters are you using? 2mm? they look alot stronger than my 1mm end mills that keep breaking!!
QUIKSILVER is offline Find More Posts by QUIKSILVER
Old Feb 10, 2011, 11:48 AM
MauiNate is offline
Find More Posts by MauiNate
United States, CA, Ventura
Joined Aug 2007
Can anybody tell me more about this? Ive never modified a servo before. thanks!
MauiNate is offline Find More Posts by MauiNate
Old Feb 11, 2011, 02:04 AM
PistaJ is offline
Find More Posts by PistaJ
Joined Oct 2009
The kit is already in the sale. I do not have a web shop and I do not distribute it to any FPV seller. The only way to get it is to contact me here or via my web.
I use 0,6 and 1 mm cutters.
If they break in your machine there could be somethink wrong with it.
Regarding the servo modification it could be done for you already in the kit.
PistaJ is offline Find More Posts by PistaJ
Old Apr 28, 2011, 05:11 PM
rob mueller is offline
Find More Posts by rob mueller
ok, maybe it is a toy
rob mueller's Avatar
Alberta, Canada
Joined Oct 2002
PM sent
rob mueller is offline Find More Posts by rob mueller
Old Jun 20, 2011, 06:47 AM
Hersh is offline
Find More Posts by Hersh
Plain City, OH
Joined May 2004
I want one.
PM sent
Hersh is offline Find More Posts by Hersh
Old Jul 19, 2011, 08:00 AM
PaulStuart is offline
Find More Posts by PaulStuart
Joined Jul 2011
purchase
Hi
I would like to purchase a pan tilt kit.
Are the available
Kind regards
Paul Stuart
Queensland
Australia
Hi.
PaulStuart is offline Find More Posts by PaulStuart
Old Jul 20, 2011, 12:28 AM
Joined Mar 2005
I already sold the two mounts
If you wish I can make a new one for you
Old Aug 19, 2011, 12:17 AM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
pm sent
Adidas4275 is offline Find More Posts by Adidas4275
Cool My quick and simple GoPro Hero HD pan/tilt mount... KeithLuneau FPV Talk 19 Nov 18, 2010 01:55 PM
Discussion Go Pro HD Hero camera for $260 Steph280 Hot Online Deals 2 Oct 27, 2010 07:13 PM
Yippee! Whacky home made Go Pro pan and tilt - Will it fly? Gree FPV Talk 9 Oct 24, 2010 04:03 AM
Discussion Go Pro Hero HD Camera on my Radian Ralph_D Aerial Photography 11 Oct 05, 2010 06:47 PM
Idea Compact 360 Pan tilt. austin.laws Thermal 8 May 19, 2009 08:44 AM
