Old Jun 28, 2001, 11:44 PM
atsiang is offline
Find More Posts by atsiang
San Jose, California, United States
Joined Feb 2001
What is the stuff they use to help accelerate CA glue curing?
Hi all,
Does anyone know what the chemical name of the accelerator for CA glue??
Al
atsiang is offline Find More Posts by atsiang
Old Jun 29, 2001, 08:44 AM
Megowcoupe is offline
Find More Posts by Megowcoupe
Balsa Flies Better!
Stamford, CT
Joined Oct 2000
Actually, I think it's a mixture. Essentially I'll bet it's some type of amine, but I'm not sure. If you're trying to come up with a cheaper source bear in mind that they may have done a fair amount of work to get the accelerator to work properly, thus you may have something of a project on your hands.
Sam Brauer, Ph.D
Norwalk, CT
Megowcoupe is offline Find More Posts by Megowcoupe
Old Jun 29, 2001, 08:47 AM
Bill Glover is online now
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
Anybody else noticed the small print on bottles of accelerator saying that use of it may (will?) give a weaker bond?
Bill Glover is online now Find More Posts by Bill Glover
Old Jun 29, 2001, 08:48 AM
leccyflyer is offline
Find More Posts by leccyflyer
Sloping off....
leccyflyer's Avatar
United Kingdom, Aberdeen
Joined Sep 2000
The stuff that I have here smells quite strongly of lanolin, but I believe I read on the net somewhere that you can use a super saturated solution of sodium bicarbonate to do the job - it might be worth a little experiment.
I don't use much CA myself due to a bad reaction and have only used the kicker once or twice.
leccyflyer is offline Find More Posts by leccyflyer
Old Jun 29, 2001, 09:05 AM
Steve McBride is offline
Find More Posts by Steve McBride
Steve McBride's Avatar
Agra, Oklahoma
Joined Feb 2000
Isopropyl Alcohol,
N,N-Dialkyltoluidine and
Hydroquinone
At least that is what is in the stuff I use.
Have fun!
Steve
Steve McBride is offline Find More Posts by Steve McBride
Old Jun 29, 2001, 09:07 AM
columbiarcdude is offline
Find More Posts by columbiarcdude
columbiarcdude's Avatar
St. Louis, Missouri
Joined Oct 2000
Back in the old days before kickers or accelerators for CA, we used Arm and Hammer baking soda. You can sprinkle it on a joint and then thin CA it ... sometimes we mixed it with water in a very strong mixture and sprayed it on parts to be joined. The dry method worked the best for me. I still use it sometimes to make a very strong light filleted joints. Be careful ... it really sets up FAST ... Try it ... you'll like it. Cheap too.
Tom
columbiarcdude is offline Find More Posts by columbiarcdude
Old Jun 29, 2001, 09:09 AM
CoClimber is offline
Find More Posts by CoClimber
Mountain Models Wannabe
CoClimber's Avatar
Ithaca, NY USA
Joined Mar 2001
Al,
I used to use that stuff all the time but I don't even know where my bottle is now. The time it takes to set up thick CA isn't too bad and as previously noted, using an accelerator will make the joint weaker. I find it makes the joint brittle.
How is the DuskStik coming along? I know you wanted to try a Speed 280 on it. I put an M100 from www.parkflyers.com on mine and it's a little rocket. Battery life is cut in half though.
Doug
www.duskstik.com
[This message has been edited by CoClimber (edited 06-29-2001).]
CoClimber is offline Find More Posts by CoClimber
Old Jun 29, 2001, 11:23 AM
atsiang is offline
Joined Feb 2001
Thanks to all for replying.
Hi Doug,
I finished the Duskstik but haven't had the
time to fly the plane. It either has been too windy or no time. I did install a 280 on it. I hope to fly it this weekend.
Al
Old Jun 29, 2001, 03:28 PM
Foxtrot is offline
Find More Posts by Foxtrot
Foxtrot's Avatar
Kodiak AK USA
Joined Jun 2000
Why would you want to accelerate CA. It cures in 30 seconds for the thick stuff and instant for thin. What gives? (Note: I'm not
arguing I just don't understand.)
Foxtrot is offline Find More Posts by Foxtrot
Old Jun 29, 2001, 03:45 PM
Hammer is offline
Find More Posts by Hammer
United States, NC, Harrisburg
Joined Mar 1999
Sometimes after the pieces are bonded together with thick CA,there is a small amount of "wet" CA on the surface.I sometimes mist accelerator onto these surfaces to keep them from sticking to my leg or something.
Hammer is offline Find More Posts by Hammer
Old Jun 29, 2001, 03:57 PM
J.Critchfield is offline
Find More Posts by J.Critchfield
J.Critchfield's Avatar
Mountain View, CA
Joined Sep 2000
I'll add to this. Accelerator sprayed on ply and light ply before glueing will help make a better bond.
J.Critchfield is offline Find More Posts by J.Critchfield
Old Jun 29, 2001, 03:58 PM
Agra, Oklahoma
Joined Feb 2000
If needed, you can add slow or medium CA 'fillets' to joints for a bit extra strength. As you know, slow or medium CA will not cure quickly and the accelerator helps things along. Yes it will make for a more brittle glue job, but better that than nothing.
I like to make a CA fillet when a butt joint is used in a high stress area.
Have fun!
Steve
Old Jun 29, 2001, 03:59 PM
LyndonC is offline
Find More Posts by LyndonC
Joined Jun 2001
My understanding of how CA works is that an alkaline substance will accelerate the glue and an acidic substance will slow and even dissolve the bonded glue. I have tried using Javex to debond and it does soften the cured CA.
As mentioned sodium bicarbonate acts as an accelerator and it is basic.
You can use anti-acid pills used for stomach indigestion to accelerate the glue. I found that the ready made accelerators work best though.
Cheers
Lyndon
LyndonC is offline Find More Posts by LyndonC
Old Jun 30, 2001, 12:51 AM
CoClimber's Avatar
Ithaca, NY USA
Joined Mar 2001
Please email me when you do. I'd love to know how the S280 works out. I expect it will need to fly a bit faster due to the increased weight.
Doug
doug@duskstik.com
Old Mar 04, 2014, 10:22 PM
dahale is offline
Find More Posts by dahale
Joined Mar 2014
acclearator for adhesives glue
I want to know ,the chemical that can be added to accelerate drying of water based glue adhesives email is dahaless@gmail.com
dahale is offline Find More Posts by dahale
CA Glue Bottles help! crvogt Scratchbuilt Indoor and Micro Models 1 Apr 06, 2003 10:57 AM
Need Help!! - Windows 98 Failing & giving me Error Messages, what do they mean? mrebman Life, The Universe, and Politics 24 Jun 08, 2002 04:18 PM
Foam Glue, what do you use? cathode Foamies (Kits) 11 Jun 06, 2002 10:27 AM
