Old Dec 10, 2010, 02:01 PM
wgregww is offline
Find More Posts by wgregww
Go Packers!
Lambertville, Mi
Joined Apr 2010
Need help on figuring size of chrager
How do I figure out what size charger I need? I want to charge 2 3S 2200mah batteries at the same time in say 30 min. Can someone explain how to figure this? Sorry Im just not good at this electrical stuff.
wgregww is offline Find More Posts by wgregww
Old Dec 10, 2010, 02:31 PM
tjinguy is offline
Find More Posts by tjinguy
TJin(Guy + Tech)
tjinguy's Avatar
United States, NM, Socorro
Joined Jun 2008
I recommend you do some reading.
https://sites.google.com/site/tjingu...arging-how-tos
tjinguy is offline Find More Posts by tjinguy
Old Jan 01, 2011, 06:04 PM
9XTremist is offline
Find More Posts by 9XTremist
San Bernacesspool
9XTremist's Avatar
United States, CA, San Bernardino
Joined Feb 2010
finally
my hats' off to you tjinguy. it's refreshing to see someone steered in the right direction without a lot of chest beating and overly technical answers that some poor bright eyed shmuck won't understand anyway. i wish every category here had a first page of pertinent info that you had to read before venturing inside that area. it would make me feel better about asking questions. don't get me wrong, this is the best site going, it just gets tiresome reading through miles of stuff and not quite finding what you need. the 2 search features are great but not perfect due to pilot induced oscillation. it's nice finding a link with all that related info in one spot.
uh oh, was i ranting or what?
excuse me i've got a link to read
9XTremist is offline Find More Posts by 9XTremist
Old Jan 01, 2011, 11:16 PM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
"1C" charge rate will charge a battery in approximately one hour.
The 1C rate is equal to the capacity in mAh divide by 1000. Hence for a 2200mAh battery it would be 2200/1000 = 2.2A
To charge in half that time you double the rate, in the example: 2 x 2.2 = 4.4A
To charge two 3S 2200 batteries at the same time you can connect them in series to make a 6S 2200 or in parallel to make a 3S 4400. Parallel charging is safer, easier and often faster.
Assuming you parallel the packs, the 1C rate becomes 4400/1000 = 4.4A.
To charge in 30min you have to charge at about 2C = 2 x 4.4 = 8.8A
Charging a 3S lipo at 8.8A requires approx 3 x 4.2 x 8.8 = 110W
So to charge two 3S 2200 lipo packs in parallel at 2C you need a lipo charger rated for at least: 3S, 8.8A, 110W.
In today's market there are many, many 6S, 5A/50W chargers but they won't do the job. There are also plenty of 6S, 10A/200W chargers which would certainly be suitable.
Don't forget that once you select a charger you need to ensure you have a suitable power supply. Since chargers are typically around 80% efficient, you need 25% more DC power input than the full rated output. Hence a 200W charger needs a 250W power supply to deliver its full output. Also note that high power chargers usually cannot deliver their full rated output from a 12V supply, needing 15V, 18V, 24V or some even 28V.
A good combination is the iCharger P350 (15V/23A, 350W) power supply and either the 106B+ (6S, 10A/250W) or better, the 206B (6S, 20A/300W).
kgfly is offline Find More Posts by kgfly
Old Jan 02, 2011, 01:32 AM
Meebo is offline
Find More Posts by Meebo
Gone Insane .... Back Soon!!
Meebo's Avatar
Joined Dec 2010
AWESOME !!!!!!!!! reply kgfly.
very informative and you even suggested potential chargers, excellent excellent reply.
Meebo is offline Find More Posts by Meebo
Old Jan 02, 2011, 03:55 PM
kgfly is offline
Joined May 2006
Thanks Meebo,
If you want an Aussie vendor for iCharges I can recommend Aiden at arkrc.com.au
Otherwise both progressiverc.com and epbuddy.com are highly regarded US vendors that ship to Oz and provide great backup.
Old Jan 02, 2011, 06:41 PM
wgregww is offline
Go Packers!
Lambertville, Mi
Joined Apr 2010
I can say I bought the P350 and 206b and love them both. Excellent customer service at Progressive as well.
Old Jun 21, 2012, 08:07 AM
c0p0ut is offline
Find More Posts by c0p0ut
United States, IL, Chicago
Joined May 2012
Awesome reference guide, even if it was started a while ago.
I was wondering if you can help me figure out the math in the above equation.
3 = S rating?
4.2= ?
8.8= The above listed Amps result
I am trying to figure this out for a 3300 mAh 3S1P 11.1v 25c lipo battery, where I would need to charge two at the same time, and also checking for a charge rate of 1C vs 2C.
c0p0ut is offline Find More Posts by c0p0ut
Old Jun 21, 2012, 08:29 AM
jkettu is offline
Find More Posts by jkettu
Joensuu, Finland
Joined Mar 2002
4.2 = volts needed to fully charge one LiPo cell. Your other guesses are correct.
For your specific example:
1C: 3.3A x 3 x 4.2V = 41.6W per battery, or 83.2W for two of them
2C: Twice that, of course, ie. 166.4W total.
Of course it won't hurt anything if your charger/psu is capable of supplying more. They will be operating at lesser stress level and you just might need to do bigger packs in the future.
jkettu is offline Find More Posts by jkettu
Old Jun 21, 2012, 08:34 AM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
The ProgressiveRC calc seriously needs to be a sticky somewhere:
http://www.progressiverc.com/chargingdemand
Easiest way to do it, no math required for the lazy people!
grimbeaver is offline Find More Posts by grimbeaver
Old Jun 21, 2012, 10:23 AM
fast truck is offline
Find More Posts by fast truck
Joined Jul 2011
Good link ,,,,,I'm the lazy guy
fast truck is offline Find More Posts by fast truck
Old Jun 22, 2012, 02:16 AM
c0p0ut is offline
Joined May 2012
You all are fantastic! Thank you for clearing this up.
I was originally going to get a quad charger, then realized I could do with a duo charger, but then figured a decent iCharger would do the trick for me just starting out (still haven't purchased my first plane or anything else yet, but have been hitting the simulators and researching for several weeks). ProgressiveRC seems to have their act together on the iChargers and I will be looking to purchase from them.
Great support in the forums, I appreciate it!
Old Sep 04, 2012, 12:45 AM
williamjames is offline
Find More Posts by williamjames
United States, FL, Miami
Joined Jun 2011
Originally Posted by tjinguy View Post
AWESOME AWESOME AWESOME SITE! Thanks a million sir!
williamjames is offline Find More Posts by williamjames
Old Sep 04, 2012, 07:40 AM
The Tug is offline
Find More Posts by The Tug
Barbados
Joined Jan 2011
Just remember that you cannot charge 2cell batteries and 3 cell batteries at the same time on a para board you will need a dual output charger or two chargers in order to do it similtaneously,the batteries would be different voltages therefore incompatible to charge in paralell format, if using a single charger you will have to do two charging cycles.I have not purchased from Progressive but like you have only heard good things,EP Buddy i have and all i can say is he's also a very very good vendor.
The Tug is offline Find More Posts by The Tug
Help! Need help on how to setup my plan on pdf paul74 Pusher Prop Jet Models 5 Nov 20, 2010 06:00 AM
Alert Need help figuring out engine not miving rustyboy64 Nitro and Glow Power Cars 1 Oct 09, 2004 07:34 PM
need help figuring out what number to get on my brushless jeff262 Power Systems 2 Nov 22, 2003 06:22 AM
need elp on figuring out brushless motors...if they are worth it? jeff262 Power Systems 7 Nov 20, 2003 08:03 PM
Need help figuring out why RX has short range ControlFreak Radios 5 Oct 30, 2002 12:52 AM
