Old Dec 10, 2010, 11:06 AM
ants0 is offline
Find More Posts by ants0
United States, NJ, Bridgewater
Joined Feb 2009
Question about discharged lipo
hey guys i crashed my rc car the other day after about 7mins of running on a 4000mah lipo 30c 7.4v battery. I am wondering how i should go about charging my battery when i receive my parts today.Should i run the battery till it dies or use my discharge option on my charger?
Battery: http://www.hobbypartz.com/83p-4000mah-2s1p-74-30c.html
charger: http://www.hobbypartz.com/thac6smbachw.html
ants0 is offline Find More Posts by ants0
Old Dec 10, 2010, 11:24 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Why waste cycles by discharging it? Either top up and use whats left.
freechip is offline Find More Posts by freechip
Old Dec 10, 2010, 01:00 PM
ants0 is offline
Joined Feb 2009
I just ran it with the throttle trim up (stationary)for about 10mins and then charged it.
Old Dec 10, 2010, 01:07 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Never run a lipo "till it dies"
Over discharge will damage it.
You should aim for a maximum 75% to 80% of the stated capacity on recharge. Nothing wrong with using less of the available capacity.
There is no need to discharge it fully every time you use it. Better to leave it at about 1/2 charge between uses.
I think the charger you have has a "storage" setting that will bring the battery either up or down to the correct voltage.
The discharge setting is probably too low if it is 3.0 volts/cell. Don't use it!
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Dec 10, 2010, 02:01 PM
ants0 is offline
Joined Feb 2009
Thanks for the info, will keep in mind
Anthony
Discussion Question about flight performance after GY401 upgrade. kauaicuda Electric Heli Talk 14 Nov 01, 2010 10:00 PM
Discussion Question about tail on Night Vapor KYlawyer Scratchbuilt Indoor and Micro Models 2 Oct 29, 2010 08:28 PM
Help! Tx Battery Discharged Williwaw Batteries and Chargers 7 Oct 19, 2010 06:40 PM
Question Question on discharged 2cell Graupner LiPo kusunokimasahige Batteries and Chargers 2 Jun 08, 2009 08:26 AM
over discharged lipo question ? eagles_407 Batteries and Chargers 1 Jul 14, 2005 10:14 PM
