Old Dec 04, 2011, 06:46 AM
Grips is offline
Find More Posts by Grips
Eat-Sleep-Work-Fly-Repeat
Grips's Avatar
Canada, NL, Division No. 9
Joined Mar 2011
whoa.. no kidding about how the lower the mhz the larger the antenna.. Has anyone put one of these 900mhz antennas on a plane? Any issues with durability from regular flying?
Grips is offline Find More Posts by Grips
Old Dec 04, 2011, 07:10 AM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
United States, TX, Houston
lots of people have, great antenna.
As far as durability, most people just bend them back after a big crash. They tend to stand up well, depending on where you put them. Even a slightly out of shape CL still works great, and at 900mhz it's alot easier to "eyeball it".
That picture does make it look larger than it is The shape of the thing misleads you about it's size.
gundamnitpete is offline Find More Posts by gundamnitpete
Old Dec 04, 2011, 06:45 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by RaptorAP View Post
My new portable ground station, works good!!
That's what I use
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Dec 04, 2011, 06:47 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
The antenna will hold up fine if you use .035-.045" welding wire. Making it at 900 MHz is a real pain. It is not easy trying to get all the lobes to stay put. This is why I no longer make them. It's takes me entirely too long.
-Alex
Old Dec 05, 2011, 03:09 PM
pc_pilot is offline
Find More Posts by pc_pilot
USA, NY, Yonkers
Joined Aug 2002
I use a 910mhz cloverleaf on the top of the stabilizer on my Skywalker and it does not affect the flight in any way.
pc_pilot
pc_pilot is offline Find More Posts by pc_pilot
Old Dec 06, 2011, 12:52 AM
smarm is offline
Find More Posts by smarm
Joined Oct 2011
I've got a 900Mhz SPW that I'm planning on mounting on a quad. Big antenna on a small quad, big problem right?
2 questions;
A)will a gopro within 10cm affect it too much?
B) As I'm still waiting for a SMA-F adaptor, I'm keen to play around with it. I was planning on running a short distance (<300m) with CP to linear. I should expect about 3db of loss is that correct? Is there any other reason I shouldn't be doing this?
Thanks!
smarm is offline Find More Posts by smarm
Old Dec 06, 2011, 03:49 AM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
2 questions;
Thanks!
A) -> possible. GoPros are notorioiusly know for their IME radiation. Pack it in silverfoil if needed. If I'm not mistaken, there are sides of the GoPro which are radiating heavier than others, so maybe placing it differently helps. By all means make a serious range test!
B) Nope, nothing wrong with trying. You loose the 3dB, that's it.
Markus
markus123456 is offline Find More Posts by markus123456
Old Dec 06, 2011, 04:10 AM
Shikra is offline
Find More Posts by Shikra
SILURIA / UK
Shikra's Avatar
United Kingdom
Joined Jun 2009
Alex, I read on one of the posts on Hugo's thread I think that you have to remove resistor from the airwave rx module inside the sharks for any of the Closed Loop antennas. Because of DC bias used
Is that true? Does it make much difference?
I ask, because I only tested my antennas on the sharks - and I very carefully made several including 3,4 and 8 lobe variations of SPW,Turbine and clover. Didn't really notice any improvement over omni with 2.4.
Originally Posted by IBCrazy View Post
That's what I use
-Alex
Shikra is offline Find More Posts by Shikra
Old Dec 06, 2011, 05:56 AM
RaptorAP is offline
Find More Posts by RaptorAP
Gainesville, FL
Joined Nov 2005
Im using the skew on my FS Dominators and it works fine, must be the older FS models.
I noticed less dropouts/multipathing over the stock dipole omni.
RaptorAP is offline Find More Posts by RaptorAP
Old Dec 06, 2011, 11:58 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
It's only an issue with the FatShark Aviators.
-Alex
Old Dec 08, 2011, 08:31 PM
QiW is offline
QiW
Find More Posts by QiW
QiW
south east asia
Joined Mar 2009
sorry but i read earlier about lawmate receivers not doing good with spw or cl.
i could not find info on that and solving the lawmate vrx issue... or is it still an issue ?
i have recently acquired a lawmate vrx since i heard about how good it can be vs generic chinese vrx.
thanks
QiW is offline Find More Posts by QiW
Old Dec 08, 2011, 11:23 PM
TheNiceGuy is offline
Find More Posts by TheNiceGuy
Expat
Japan
Joined Apr 2010
thanks
That was an isolated special problem. There is no problem with LMRX and these antenna.
TheNiceGuy is offline Find More Posts by TheNiceGuy
Old Dec 10, 2011, 09:02 AM
QiW is offline
QiW
QiW
south east asia
Joined Mar 2009
thanks...
Old Dec 28, 2011, 02:41 PM
Chairwolf is offline
Find More Posts by Chairwolf
I think it'll work this time!!
Chairwolf's Avatar
399 feet above Roanoke, VA
Joined Jan 2007
My first SPW Antenna
Well, here it is, my first attempt at an SPW antenna for my RX. It's 910 mhz. Works so far on the bench, so I went ahead and gooped it up with hot glue.
This antenna was made from a Rubber Ducky antenna from HK. I had to do this because the connectors on the HK VRX are not SMA connectors; so I disassembled the dipole part of the RD and used the coax that was inside. I kept the joint on the connector and hot glued the top end. Then I mounted the clover-leaf end inside a GLAD container.
I'm going to try a ground test today and see how it does with my cloverleaf VTX antenna.
Stand by!
Bob
Chairwolf is offline Find More Posts by Chairwolf
Old Dec 28, 2011, 02:48 PM
Registered FPVer :)
Joined Aug 2006
Stand by!
Bob
Bob,
Nice work! The drag of that GLAD container will be enormous though....
Markus
Old Dec 28, 2011, 02:56 PM
Chairwolf's Avatar
Joined Jan 2007
I don't think my receiver will even notice!
Old Dec 30, 2011, 12:41 AM
volto is offline
Find More Posts by volto
Navigator
volto's Avatar
USA, CO, Durango
Joined Sep 2010
It will if the wind picks up
volto is offline Find More Posts by volto
Old Dec 30, 2011, 06:50 AM
RaptorAP is offline
Gainesville, FL
Joined Nov 2005
Very nice, Bob! Nice work!
Old Dec 30, 2011, 08:07 AM
Lauri1000 is offline
Find More Posts by Lauri1000
Joined Feb 2011
Made antennas
Yesterday I made my first 5.8 Ghz circular polarized antennas. Cloverleaf turned out nicely but Skew-Planar Wheel was a bit messy. I put too much epoxy on Skew-Planar Wheel. Now I need to test these antennas to see how they perform. Used RG58 coaxial cable.
Lauri1000 is offline Find More Posts by Lauri1000
Old Dec 30, 2011, 08:21 AM
Registered FPVer :)
Joined Aug 2006
Originally Posted by Lauri1000 View Post
Yesterday I made my first circular polarized antennas. Cloverleaf turned out nicely but Skew-Planar Wheel was a bit messy. I put too much epoxy on Skew-Planar Wheel. Now I need to test these antennas to see how they perform.
Looking at the fourth picture from the right makes me wonder what may remains in those what it looks 2.4Ghz whip antennas? Usually such antennas are so called pot antennas where there is a metal tube forming one part of a dipole and the center wire the second pole. Now, since your antennas are what seems to be at the far end of the original antenna, I truly wonder if you took the tube out?
Markus
Old Dec 30, 2011, 08:23 AM
Registered FPVer :)
Joined Aug 2006
Ok, I recon that this is eventually just RG58 cable?
Old Dec 30, 2011, 08:32 AM
Joined Feb 2011
It's just RG58 cable, nothing more
Old Dec 30, 2011, 09:06 AM
Chairwolf's Avatar
Joined Jan 2007
Hopefully not! Here's a shot of my brand-new BMGS. (That's Belly-Mounted Ground Station ) I wear the GS with a strap around my neck, right above my belly. My RC Transmitter is strapped below it TO the GS. I can fly with my hands in the "normal" position, and hold my RC TX up above the GS if I need to look at my RC Transmitter (or use it to block the sun).
Flight tested this system yesterday, and it works like a champ!
The SPW and Clover Leaf antennas are performing EXTREMELY WELL, at least in the eyes of this FPV Noob!
Thanks Alex, and everyone else for your help and support!
Bob
aka
Chairwolf
Old Dec 30, 2011, 09:07 AM
Chairwolf's Avatar
Joined Jan 2007
Thanks! I feel like I'm bringing a cake to the field every time I put that thing in the car! ha ha
Old Dec 30, 2011, 09:14 AM
Chairwolf's Avatar
Joined Jan 2007
The shape looks good! Nice work. (I can really say that, because mine are the result of about 4 feet of wire going into the trash can first!!! )
Bob
edit - I just noticed that you mentioned using epoxy. I was thinking - I broke my SPW on the bench right after I bench tested it, and had to re-solder the top (signal) connector. If you use hot glue, and the antenna breaks later, you can melt the hot glue off and fix the antenna. It would be difficult to do (maybe even impossible) with epoxy. So you may want to give hot glue a try for your next one!
No criticism, just food for thought if it might be of some help.
Great work!
Bob
Old Dec 30, 2011, 11:32 AM
Joined Feb 2011
I would use hot glue if i had any
Old Dec 30, 2011, 11:38 AM
Nobert is offline
Find More Posts by Nobert
Nobert's Avatar
Tucson Avra Valley, Arizona, United States
Joined Jul 2002
Alex or Hugo
Based on the last couple of posts, will epoxy or hot glue detune the antenna--- especially on 5.8?
Neal
Nobert is offline Find More Posts by Nobert
Old Dec 30, 2011, 02:55 PM
Registered FPVer :)
Joined Aug 2006
Originally Posted by Nobert View Post
Alex or Hugo
Neal
I'm Neiter Alex nor Hugo, but what makes you think the antenna was tuned in the first place?
If you change the velocity factor of the surrounding medium of an antenna you will change the resonant frequency, and in almost all cases lower the efficiency of the antenna. So strictly speaking the answer is yes. By what degree is another question.
Have you bought a fine tuned antenna that is optimized for a given freuqency? If so you can be concerned. If not why would you botter? If you build an antenna on 5.8Ghz to measure, chances are you are ~100Mhz or even more off anyways. So, applying the hot glue or epoxy does change it, but if you are lucky it could be to the better, maybe to the worse. Nobody will be able to tell you unless you measure your antenna out with apropriate equipement.
Markus
Old Dec 30, 2011, 10:15 PM
Hugeone is offline
Find More Posts by Hugeone
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
Markus is absolutely right.
I found that hot glue affect tuning more than epoxy which affect more than CA.
-Hugo
Hugeone is offline Find More Posts by Hugeone
Old Jan 01, 2012, 06:59 AM
Expat
Japan
Joined Apr 2010
Can anyone tell me the effect of lengthening the gap between the in/out solder pints on the antenna (that is, where the lobes connect to the SMA center shaft)? I made a 2.4 SPW/CL combo, and worried about a short, made the gap about 8mm on the SPW. What effect does this have as opposed to a 1mm gap?
Old Jan 01, 2012, 08:29 AM
Chairwolf's Avatar
Joined Jan 2007
I'm no expert, but the posts I've seen say that the smaller the gap, the better. You could insulate the joints with, say a little piece of electrical tape or something to keep them from touching each other.
Bob
Old Jan 01, 2012, 10:19 AM
Registered FPVer :)
Joined Aug 2006
Not 100% sure I understood you right, but if the center conductor piece is just longer up until it meets the lobes, that would increase the resonant frequency slighty and at the same time lower the efficiency of the antenna. However, that's a generalisation. Depending on how your lobes are repositioned because of this it also could have the oposite effect. What's clear thoug is that the efficiency will drop because the shape is not ideal.
That does not mean though that the antenna is unuseable. Just that you don't get the optimum possible. For a first attempt it's ok, so fly your antenna (after makeing some range tests) and see for yourself how good it is.
Markus
Old Jan 02, 2012, 10:46 AM
TexasAggie is offline
Find More Posts by TexasAggie
Gig 'Em!
TexasAggie's Avatar
United States, TX, College Station
Joined Nov 2010
My first SPW attempt turned out pretty nicely. I'll put up pictures in a little while. One question: In the below video, the angles that are supposed to be about 17 degrees turned out to be about 40 degrees in mine. Is this okay or should I redo it?
The Skew-Planar Wheel (SPW) circular polarized omni antenna by IBCrazy (1 min 11 sec)
TexasAggie is offline Find More Posts by TexasAggie
Old Jan 02, 2012, 10:49 AM
Chairwolf's Avatar
Joined Jan 2007
That sounds like either the length of your arcs is way too long, or your ground legs are not at 90 degrees to each other. I am a rank noob at this, but with 40 degrees of overlap, something must be wrong somewhere.
Can you give us a good top-down pic?
Old Jan 02, 2012, 10:55 AM
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
I did it with 4 separate leaves, each of which had the same geometry as the cloverleaf that I have already completed (according to http://rcexplorer.se/page14/CPantennas/SPW/SPW.html)
Old Jan 02, 2012, 11:36 AM
Chairwolf's Avatar
Joined Jan 2007
This is 910mhz, right? The only thing I can think of is that Alex's measurements for the cloverleaf antenna on the long piece of wire was 26.5" and the SPW shows 26.0" which might explain why your SPW has a bigger overlap. I would also check your measurements on the legs; they should be 84mm each.
I'm just guessing here, but checking those measurements is where I'd start.
Then again, if the antenna works well, maybe you can just go with it!
Bob
Old Jan 02, 2012, 11:37 AM
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
1280 MHz. I'll just do some experiments with it and see its performance.
Old Jan 02, 2012, 11:38 AM
Chairwolf's Avatar
Joined Jan 2007
1280 MHz.
ok, then my numbers don't apply. (oops) But if you look at the lengths on the 2 different RCGroups threads, they may be slightly shorter on the SPW antenna than they are on the Cloverleaf.
Old Jan 02, 2012, 02:14 PM
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
My SPW didn't perform as well as my cloverleaf with another cloverleaf on the Tx so I'll take that one apart and try again.
Old Jan 02, 2012, 02:27 PM
Chairwolf's Avatar
Joined Jan 2007
I just checked the lengths on Alex's posts -
for 1280mhz:
Cloverleaf:
Long wire: 18.9" or 479.5mm for the Cloverleaf on 1280mhz.
Short wire: 9.44" or 240mm for the Cloverleaf on 1280mhz.
Quarter Wave: 2.36" or 60mm for the Cloverleaf on 1280mhz.
Skew Planar Wheel:
Long wire: 18.49" or 469.8mm
Short wire (not listed, but 1/2 would be 9.245") or 234.82mm
Quarter Wave: 2.31" or 60mm
I don't know if this was the cause of the problem, but I hope it might help!
Bob
Old Jan 02, 2012, 02:33 PM
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
The wire length he lists for 1280 (18.49"/469.8mm) and the quarter wavelength (2.31"/60mm) do not work out. He says the 60mm should be an eighth of the wire length. I'll try 235mm for each leaf (I was using 240, which the CL dimension) this time and see how that ends up.
Old Jan 02, 2012, 02:43 PM
Chairwolf's Avatar
Joined Jan 2007
Sounds good! I hope your trash can has less wire in it than mine!!
Old Jan 02, 2012, 02:46 PM
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
Well I bought a 2lb spool of welding wire, so it has the potential to be stuffed...
Old Jan 02, 2012, 02:56 PM
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
Here's where the discrepancy exists: his quarter-wave metric calculations are screwy. 75168/1280 = 58.7 NOT 60. The lengths in his photos also don't agree with his computations.
Old Jan 02, 2012, 03:05 PM
Chairwolf's Avatar
Joined Jan 2007
Don't forget to add a little for the hooks and the tail on the ground side.
Old Jan 02, 2012, 03:07 PM
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
I'm leaving the hooks off of this one, and the tails don't matter since they're attached when the center conductor is shielded.
Old Jan 02, 2012, 06:29 PM
Registered FPVer :)
Joined Aug 2006
40 degrees is a lot. Try it out. If they perform good enough for what you are after - who cares! If not, you found one point to improfe.
It seems like the relation of the arc length compared to the two legs is not ok then. Usually the arc should be about half the wafelength, the legs about a quarter. Note though that the correction factor to apply differs between the SPW and the CL antenna.
HTH
Markus
Old Jan 03, 2012, 08:39 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
TexasAggie - You might find the little hooks help a lot. They won't harm anything at 1.3GHz. I make them as long as the feedpoint gap so the overall lobe lenght is consistent.
The lobes should be .5% longer than 1 full wavelength depending on the wire thickness you use. Wire thickness will change resonant wavelength, so the little details will change. Generally the thicker the wire, the higher the resistance (I know this sounds backwards but we're talking RF, not DC). My calculations were done with .035" wire. if you use thinner wire (say .030 or .025) you will need the lobes to be slightly longer than my calculations.
-Alex
Old Jan 03, 2012, 09:19 AM
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
I've got .030 welding wire. So do I need to add the length of the hook to the lobe length, or get the lobes correct and then just bend the last few mm into the hook? Also, how important is that 105 angle? Without another dimension, I find that it can be physically anywhere in a fairly large range. Seems 115 gives a nice-looking lobe. That dashed line on the left is tangent to the arc at the corner.
Edit: I'm going to be doing the trick in your YouTube video with the legs, so I'll make 4 independent lobes.
Old Jan 03, 2012, 09:28 AM
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
Since you're here, Alex, can you take a quick look at my FPV test flight from yesterday and give any troubleshooting tips you can think of? 1280 MHz. Tx is a generic 400 mW from RMRC. Rx is Lawmate unmodified. Both antennas were cloverleafs. The transmitter antenna was slightly better-made than the receiver antenna. I highly doubt the problem is due to the Tx turning off in flight, since I replaced all my wiring.
www.youtube.com/watch?v=l7lb99DZL4I
Old Jan 03, 2012, 11:50 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Texas Aggie - I bend my hooks after I strip the cable. The length of the hooks = feed gap length. The reason is that the feed gap counts as part of your lobe length. Therefore by bending the hooks in the end you remove that length from the lobe itself but it gets added back in the soldering stage due to the feed gap. If you had no feed gap at all you would need to add a little wire for your hooks.
The arc isn't too critical. Just be sure it doesn't touch the adjacent lobe.
When I look at your video, your problem appears to be external interference. Perhaps a pulsed transmission? I can't tell. Your video is rock solid and then suddenly loses the frame sync. This would indicate an outside source.
-Alex
Old Jan 03, 2012, 11:56 AM
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
Thanks for the tips. I really appreciate your help. I'm kind of surprised at video interference since that park is basically in the middle of a forest with no built-up areas for several miles.
Also, when you say "slightly longer" for the .03 wire, can you quantify?
Old Jan 03, 2012, 12:44 PM
Nobert is offline
Nobert's Avatar
Joined Jul 2002
TA
Here in Tucson the public services all use the 1280 band. They have a lot more power and can interfere with FPV setups.
Hope this helps.
Neal
Old Jan 03, 2012, 12:50 PM
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
How did you find this out?
Old Jan 03, 2012, 03:46 PM
Nobert is offline
Nobert's Avatar
Joined Jul 2002
I have friends in Police, Fire and EMT.
Neal
Old Jan 03, 2012, 04:52 PM
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
Well, here's #2 for 1280 MHz. How's it look? I ended up getting the lobes to be positioned such that I didn't need the hooks to solder the middle.
Edit: I used 107 degrees for the lobe angle. The overall length of each lobe was 245mm and I bent at 60mm from each end.
Old Jan 03, 2012, 05:10 PM
Registered FPVer :)
Joined Aug 2006
Looks great. If you were precise with the measures, I'm sure it will perform nicely.
Markus
Old Jan 03, 2012, 05:17 PM
IFLYOS is offline
Find More Posts by IFLYOS
14s 180mah should be enough...
IFLYOS's Avatar
United States, NC, Pfafftown
Joined Feb 2001
TA
Hope this helps.
Neal
Neal, I am sorry, but this isn't possible. In the US, Amateur radio operators have exclusive use of 1240 Mhz to 1300 Mhz.
Now, it is possible there is a repeater in the 1.2Ghz band for Amateur use*, and that is causing the interference you refer to, but again, 1240-1300Mhz is allocated by the FCC for exclusive Amateur use. We do share some of our allocations with other groups, but not this one.
see http://www.ntia.doc.gov/files/ntia/p...3-allochrt.pdf for the breakdown of allocations in the US
Tim
AG4RZ
I just looked, and there is an Amateur repeater located at 9200 ft atop Mt Lemmon neat Tucson, Arizona - This is a D-Star machine. It is on 1298.25...
IFLYOS is offline Find More Posts by IFLYOS
Old Jan 04, 2012, 08:09 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Darn good if you ask me. Now fly it
-Alex
Old Jan 04, 2012, 09:04 AM
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
-Alex
Thanks. First I have to hot glue it a bit and then make another cloverleaf since I stepped on my best one yesterday.
Old Jan 09, 2012, 07:37 AM
chemnut842 is offline
Find More Posts by chemnut842
United States, MD, North East
Joined Apr 2011
Ok so I built the SPW for the first time and it looks alright but performs awful. I recorded a LOS flight and upon reviewing the vid, there is no way anybody could fly fpv with this.
There are slight problems with my antenna. After reading I think the problem is my feed gap. I measured mine to be 9.5mm and I did not incorporate any hooks into the center joint.
Both Tx and Rx antennas are RHCP (RHCP = tractor prop, LHCP = pusher prop?) and the Tx antenna is a CL. I am on 1280 MHz.
should I bend hooks to be ~10mm or should I just shorten the feed gap or both?
I have a 5-turn helical that I just set flat on the ground and that works fine for flying around LOS or ~ 300-700 feet without pointing it - I have not flown far yet but at least I know my other components are working.
chemnut842 is offline Find More Posts by chemnut842
Old Jan 09, 2012, 10:19 AM
asaloca is offline
Find More Posts by asaloca
asaloca's Avatar
Delray Beach
Joined Aug 2004
Hi.
Congrats for IbCrazy ant his valious contribuiton here and for the amazing jeweller work some of you are sowing here for us !!
Can somebody tell me a supplier ...Home Depot or were you guys in states are buying the " Copper coated steel wire " ....serched the net and noyhing ..
Tks
FRED
asaloca is offline Find More Posts by asaloca
Old Jan 09, 2012, 10:31 AM
Devonboy is offline
Find More Posts by Devonboy
SW England
Joined Aug 2009
2 kinds of plated wire:
Gold plated 'memory wire' - found in ladies DIY jewelery stores.
Copper plated 'MIG welding wire' - found in lots of places that sell welding equipment.
HTH
Nigel.
Devonboy is offline Find More Posts by Devonboy
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
I got a 2lb spool of welding wire at Ace. They also had it at Lowe's.
Old Jan 09, 2012, 10:51 AM
Chairwolf's Avatar
Joined Jan 2007
Originally Posted by asaloca View Post
Hi.
Tks
FRED
Harbor Freight has it for cheap, too. And Home Depot.
Old Jan 09, 2012, 12:39 PM
Joined Apr 2011
I found it at radio shack marketed as antenna ground wire. It is copper clad steel wire and had a cost of about $1/foot or something like that.
Old Jan 09, 2012, 01:36 PM
Chairwolf's Avatar
Joined Jan 2007
$1 A FOOT??? You can get 10 miles of it for $11.47 at Home Depot, or $8.50 at Harbor Freight!
Old Jan 10, 2012, 03:03 PM
Zen09 is offline
Find More Posts by Zen09
Zen09's Avatar
Germany, HB, Bremen
Joined Jun 2010
A pusher prop behaves the same as a tractor one.
RHCP is the conventional clockwise screw thread type.
Zen09 is offline Find More Posts by Zen09
Old Jan 11, 2012, 02:53 PM
k0mputer is offline
Find More Posts by k0mputer
Joined Jan 2011
I have 5.8 system on order and came across this:
http://www.readymaderc.com/store/ind...roducts_id=596
Do I need 2 antennas, one for Tx, one for Rx or just for Tx is fine? Thanks in advance for your help.
That will do 1000+ feet with ease.
-Alex
k0mputer is offline Find More Posts by k0mputer
Old Jan 11, 2012, 03:25 PM
Registered FPVer :)
Joined Aug 2006
You need a pair. A cloverleaf on the transmitter and skew planar wheel on the receiver usually works best.
Markus
Old Jan 11, 2012, 04:17 PM
k0mputer is offline
Joined Jan 2011
Markus
Hey there, cool thanks. Where can I get the skew planar wheel for 5.8 though? I googled it, no sellers found.
Old Jan 11, 2012, 04:42 PM
Registered FPVer :)
Joined Aug 2006
Alex sells them:
http://videoaerialsystems.com/
So does Hugo
http://www.truerc.net/canada/
I make them upon request, but I currently have a too big backlog to help you out unless you like to wait.
Markus
Old Jan 11, 2012, 04:47 PM
k0mputer is offline
Joined Jan 2011
Alex sells them:
So does Hugo
Markus
I've seen that site http://videoaerialsystems.com/ but no option to add product to cart.
For http://www.truerc.net/canada/, they had the wind mill for 5.8. Is that the same as the skew planar wheel?
Old Jan 11, 2012, 05:18 PM
Registered FPVer :)
Joined Aug 2006
The windmill is not the same, but they work the same. In a sense they are interchangeable (Hugo forgive me)!
I've seen on the webpage that they are "on vacation", maybe you have to wait for some days more, but again, Hugo's antennas work equally well.
Markus
Old Jan 12, 2012, 09:03 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I will second the work of Hugo (www.truerc.net/canada). His work is exceptional which is why he and I design together. All of our products are compatible. The True Wire windmill/fan combination will do the same as my BluBeam set and both are compatible with eachother. You can get my BluBeams from here: http://www.readymaderc.com/store/ind...roducts_id=550 I know he's out of stock, but I am sending him a shipemnt this afternoon so he'll be back in stock in no time
-Alex
Old Jan 12, 2012, 09:37 AM
k0mputer is offline
Joined Jan 2011
Thanks for all the good information. So for a 5.8, I can get the cloverleaf for the TX and make the SKP for now, which is my first time, so I could mess it up. Should I just get the Bluebeams Alex mentioned?
-Alex
Old Jan 12, 2012, 10:16 AM
Zen09 is offline
Zen09's Avatar
Germany, HB, Bremen
Joined Jun 2010
Finished my first SPW, for 1180MHz. I've made it from 1mm steel wire.
Now I have to test it with the CL against stock antennas.
I'll keep it in a foam box (raw foam melt and cut to fit the antenna) to protect during transport. I think I'll keep it during running as well, the foam shouldn't affect it much would it.
Old Jan 12, 2012, 01:55 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
^ Wow! That is some nice work there. You will really like your new antenna system.
-Alex
Old Jan 15, 2012, 08:58 AM
Vertige is offline
Find More Posts by Vertige
France
France, PACA, Antibes
Joined Jan 2012
Hi everybody, I’m new to the forum, I do practice FPV with a Multirotor MK, in France, I have been reading your post here on antennas from A to Z, and I have found it fascinating.
I did create, thanks to yours informations, my Pinwheel and Cloverleaf antennas and they do work unbelievable (only itch is: to be careful the way you land not to make a pancake out of it)…
My question: how important is the length of the feed point, should it change with frequency, does it change impedance, does it matter at all?
Second question: should the length of the lobes of the Cloverleaf (for a pair of matching antennas) be longer than those of the Pinwheel?? (I have found contradictory opinions on the matter)
Vertige is offline Find More Posts by Vertige
Old Jan 15, 2012, 02:03 PM
Registered FPVer :)
Joined Aug 2006
Originally Posted by Vertige View Post
Hi everybody, Iím new to the forum, I do practice FPV with a Multirotor MK, in France, I have been reading your post here on antennas from A to Z, and I have found it fascinating.
I did create, thanks to yours informations, my Pinwheel and Cloverleaf antennas and they do work unbelievable (only itch is: to be careful the way you land not to make a pancake out of it)Ö
Second question: should the length of the lobes of the Cloverleaf (for a pairs of matching antennas) be longer than those of the Pinwheel?? (I have found contradictory opinions on the matter)
Mike,
Yes, keep the feedpoint as short as possible and yes, the CL lobes should be about 2 - 3% longer than the lengt of the SPW.
Markus
Old Jan 15, 2012, 02:59 PM
Vertige is offline
France
Joined Jan 2012
Mike,
Markus
Thanks Markus for the info.
Old Jan 20, 2012, 10:34 PM
thehaw24 is offline
Find More Posts by thehaw24
thehaw24's Avatar
United States, CA, Hesperia
Joined Dec 2011
Does anyone know where i can purchase the Cable to build this antenna? Home depot,radio shack, Im not trying to order online.
thehaw24 is offline Find More Posts by thehaw24
Old Jan 20, 2012, 10:41 PM
k0mputer is offline
Joined Jan 2011
Home Depot
Old Jan 21, 2012, 01:06 PM
thehaw24 is offline
thehaw24's Avatar
Joined Dec 2011
Home Depot
What is it called, Im looking for the cable not the copper coated wire..
Old Jan 21, 2012, 09:30 PM
rubenhak is offline
Find More Posts by rubenhak
Joined May 2009
Hi Guys, I'm very new to FPV. Sorry if this question was already asked 1000s of times and also answered that much I just cant find the answer.
I've got Fat Shark Predator RTF FPV Headset System 5.8GHz. It comes with 100mW transmitter and 3dBi antenna. If anybody use it, how far is the operation range of this system?
How much is Skew-planar wheel antenna capable to extend the range?
Ruben
rubenhak is offline Find More Posts by rubenhak
Old Jan 22, 2012, 12:09 AM
volto is offline
Navigator
volto's Avatar
USA, CO, Durango
Joined Sep 2010
It's RG316 coaxial, but any 50 ohm coaxial will do. Radio shack is probably the only one likely to have it, I get mine on ebay with the SMA connectors already crimped on.
Old Jan 22, 2012, 12:22 AM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Radio Shack will probably have the SMA connectors, but likely not the RG316 wire. You may find it at a local ham radio store?
Vantasstic is offline Find More Posts by Vantasstic
Old Jan 22, 2012, 01:48 PM
Chairwolf's Avatar
Joined Jan 2007
Here you go...
item.mobileweb.ebay.com/viewitem?itemId=150590703162&index=21&nav=SEARCH&n id=22318907212
Bob
Old Jan 22, 2012, 10:38 PM
thehaw24 is offline
thehaw24's Avatar
Joined Dec 2011
Thanks for the info guys, I ended up buying everything i needed from radio shack, I got the sma connectors and the cable is a RG58,Here is a picture.
And video with the antennas, Im verry happy with them now i can go anywhere i want without problems..
Witespy quad FPV with clover leaf antennas (3 min 34 sec)
Old Feb 04, 2012, 09:15 PM
Eastcoast78 is offline
Find More Posts by Eastcoast78
Dixie Normious
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
got my cables form eBay
spent last night making them
Skew Planer Wheel and Cloverleaf Build (1 min 42 sec)
Hopefully they work good.
Eastcoast78 is offline Find More Posts by Eastcoast78
Old Feb 07, 2012, 03:40 AM
dkulcar2 is offline
Find More Posts by dkulcar2
Slovenija, Murska Sobota
Joined Jun 2011
a little bit of my creativity....
building Cloverleaf and Skew-Planar antennas (16 min 3 sec)
dkulcar2 is offline Find More Posts by dkulcar2
Old Feb 09, 2012, 09:14 PM
The Tellurian is offline
Find More Posts by The Tellurian
St Catharines Canada
Joined May 2002
Alex, Markus, Hugo
I'm interested in building a 2.4g SPW for my Frsky Rx but would like to use the existing coax because of the ufl/ipx connectors on them. The other coaxs mentioned are very heavy and I'm afraid that moving the antenna around could disconnect it without my noticing. The diameter is 1.13 mm [OD insulation] and I can't find a name or label for the stuff. So the question is; what effect would this smaller diameter coax have on measurements, lengths etc? I have .031 brass rod for this use.
Richard
The Tellurian is offline Find More Posts by The Tellurian
Old Feb 10, 2012, 01:59 AM
Registered FPVer :)
Joined Aug 2006
Originally Posted by The Tellurian View Post
Alex, Markus, Hugo
Richard
Richard,
You can use this cable as it's also 50 ohms. The difference to the bigger ones is that it has a much higher damping factor, alas make sure to only have it as short as possible. Good luck with soldering it to the antenna lobes!
Markus
Old Feb 10, 2012, 10:45 AM
Joined May 2002
Richard,
Markus
Thanks Markus
Yes I've been mulling over how to do that, must make a jig of some sort. I have some brass tubing that just a hair larger than the outer diameter of the cable and will try soldering to that [lot of heat] then solder that to the shield [gentle heat]. I plan to solder only the top and have the tube go down over the outer insulation. Is this good or no?
A second question regarding that is if this brass tube is extended down over the outer insulation about 20mm [28mm maybe better?] similar to the balun on a linear dipole will it adversely affect the antenna? The idea is to use it as tension relief.
Last resort is to use a ufl/ipx to sma adapter cable Frsky others but I've not found one yet.
Richard
Old Feb 11, 2012, 04:15 AM
Registered FPVer :)
Joined Aug 2006
Thanks Markus
Richard
Richard,
ufl/ipx adaptors can be found on ebay.
The idea with the tubing is not a good one as in fact would form a balun which you don't want with CL and SPW antennas. You could make a very small washer though. That's what I actually use on my antennas. You could cut off about one milimeter of the mesh and route that through the washer, then bend the mesh out and solder it onto the washer. This gives you a platform that is cabable of dissipiating some of the heat onto which you can solder the GND connections of the lobes. The HF influence with this "horizontal" little ring is acording to my experience negletable.
HTH
Markus
Old Feb 11, 2012, 07:51 PM
Joined May 2002
Thanks for the reply Markus
The tube idea started to look like more of a pain the more I looked at it so thats good to know, I like the washer idea. Copper washers are available here if a small enough one can be found. There was also someone who made a Y or X out of copper that I could do otherwise. Been playing with it today making jigs etc. The real pain is the feed wire which is microscopic in gauge.
Richard
Old Feb 12, 2012, 09:26 PM
subsonic is online now
Find More Posts by subsonic
If it's to be, it's up to me.
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
So whatís the best way to mount a 980mHz SPW antenna for a receiver? I like to do FPV from inside my car Ė comfy seats and am wondering what the requirements are for a simple solution. Do I need to have the antenna up on a pole, or can I have it on my ground station box on the carís roof or hood?
Cheers, Michael.
subsonic is online now Find More Posts by subsonic
Old Feb 13, 2012, 07:24 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Cheers, Michael.
I'd recommend up on a stand about 2-3 feet above the car's roof. This will minimize reflections from the car.
-Alex
Old Feb 13, 2012, 11:39 AM
Joined May 2002
Richard,
. The HF influence with this "horizontal" little ring is acording to my experience negletable.Markus
Would that also be true at the other end? The wire on the active side is micro size as in 3 or 4 strands of 46 gauge or something. Hooking the ends as Alex does just overwhelms this little wire and any tension on it from the elements can snap it off at the exit from the shielding. I'm thinking that if I put hooks on facing down and out, bring them into the washer from the top, solder as such then that could be squeezed down to the center wire and soldered, this could work.
Richard
PS. would like to avoid buying separate u.fl to SMA adapters cables
Old Feb 13, 2012, 12:23 PM
Chairwolf's Avatar
Joined Jan 2007
HTH
Markus
Markus,
I've been thinking about doing this on my next antenna build. I could probably make a tiny washer out of a piece of copper or brass, using a drill press, by just drilling the proper size hole, trimming the O.D. to the rough shape, and then mounting the piece in the drill chuck on a screw and sanding or filing it round.
But I'm wondering if anyone knows of a source of pre-made small washers of the size we'd need to use on RG316 cable?
Bob
Discussion Left/Right circular polarized antenna ? SpookiePower FPV Talk 53 Feb 21, 2015 07:02 PM
Mini-HowTo DIY Ground Plane omni directional RX antenna IBCrazy FPV Talk 60 Nov 19, 2012 06:11 AM
Discussion 900 mhz circular polarized antenna? g00bd0g FPV Talk 9 Aug 21, 2012 09:54 AM
Discussion 18dbi Circular Polarized Patch ? Coyote64 FPV Talk 3 Nov 10, 2010 04:59 PM
Question Circular polarized antenna question Sov4life FPV Talk 8 Mar 05, 2010 05:00 PM
