Old Feb 06, 2013, 07:52 PM
Honest Abe is offline
Find More Posts by Honest Abe
Joined Feb 2012
Ultimate Discharger
Many thanks to all that have contributed to this project. Again thanks to redbird300 at Heli freak for getting me started on this awesome project.
This is what I came up with combining all our knowledge, The perfect discharger.
The Cell-log 8 operates the trip circuit through the power of the discharge batteries and shuts off.
Of course you can set your own specific cut off voltage as you please.
This unit uses amp settings instead of battery cell count for selecting the discharge rate. Totally your choice of settings, mine is set
at 6 - 14 amps discharge for 4s, and 4 - 9 amps for 6s packs. Amps selectable with switches, and led's show switch position, up to 250 watts for me.
My original schematic shows the trip circuit with load resisters.
Cost is around $50 , most parts in my garage from computers and years of saving.
Honest Abe is offline Find More Posts by Honest Abe
Old Feb 07, 2013, 02:34 AM
spog is online now
Find More Posts by spog
Joined Mar 2006
That's a very nice discharger Honest Abe. Well done.
spog is online now Find More Posts by spog
Old Mar 29, 2013, 11:57 PM
spog is online now
Joined Mar 2006
I finally got around to upgrading my discharger from 15 to 20 amps. This is my finished ghetto cheapo compact 250 watt 3S discharger, completely built with parts I had. The current is minimum 7.5 amps, up to 20 amps in 2.5 amp increments. Every two pins of the connector adds another lm317.
Yes, I'm too cheap to buy a box and a switch. Note that the positive lead is well insulated up to the fuse. Do this at your own risk!
Old Mar 30, 2013, 12:01 AM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
I like it! But are you sure the clothes peg has passed the electrical safety requirements tests?
jj604 is online now Find More Posts by jj604
Old Mar 30, 2013, 07:50 AM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
If you zoom in and look closely at the clothes pin you can see the UL and CSA logos.
Ohmic is offline Find More Posts by Ohmic
Old Mar 31, 2013, 08:46 PM
jakestew is offline
Find More Posts by jakestew
United States, ID
Joined Sep 2011
Now you just need to invent a plane that charges the batteries and you'll have the complete system!
jakestew is offline Find More Posts by jakestew
Old Mar 31, 2013, 09:14 PM
spog is online now
Joined Mar 2006
I didn't have a switch so I made one. That DIY switch has survived two years now and will probably last for many more.
By the way, the reason I can get 250 watts out of that fairly small heatsink is due to the high rpm and high static pressure fan. It's about all it can take though, my best guess is the heatsink reaches about 80 degrees C which is still not hot enough for the LM317's to cut back current on overtemperature. It takes a fully charged 3S 2200mah pack to storage voltage in about 3.5 minutes.
Old Jun 06, 2013, 07:30 PM
Ohmic is offline
USA
Joined Jan 2002
Sprog, Is it fair to say that 8 LM317T's is the max for a CPU cooler such as the one you're using?
Old Jun 07, 2013, 03:48 AM
spog is online now
Joined Mar 2006
Ohmic,
I may have improperly estimated the temperature of my heatsink in my previous post. I can hold my hand to it indefinitely which means it's probably not at 80 deg C. I'd say my heatsink could accept another two LM317's. It's not a big heatsink but a very powerful fan. The Pentium 4 heatsink others have used is bigger than mine, I'd say they could probably take 10 LM317's with the stock fan. Maybe one of those users could comment on how hot their heatsink gets.I also noticed that most have been getting about 2.2 amps per LM317 at 3S voltage, while I get 2.5 amps. I think this is due to who manufactured the LM317, mine are made by Fairchild.
Old Jun 07, 2013, 03:09 PM
Ohmic is offline
USA
Joined Jan 2002
Thanks Sprog. I'll go for Fairchild's LM317T then.
Old Jun 07, 2013, 04:55 PM
spog is online now
Joined Mar 2006
The Pentium 4 heatsink may be able to take 12 or even 14 devices, so you may want to space them tightly on the heatsink when you drill and tap. I am impressed by how much power these cpu heatsinks can dissipate.
Old Jun 07, 2013, 05:45 PM
Ohmic is offline
USA
Joined Jan 2002
Maybe I'll try a few more then. Not like it will be expensive to retrofit or even start over.
I picked up the fan below.
From the ad:
The copper base and high-density aluminum fins optimize heat dissipation
Plus a 92mm, 2200RPM cooling fan delivers an air flow of up to 48.4 CFM for exceptional cooling performance
$8.49 delivered to my door.
http://www.amazon.com/Rosewill-RCX-Z...ill+cpu+cooler
Old Jun 07, 2013, 07:13 PM
spog is online now
Joined Mar 2006
Wow, super cheap heatsink with a nice thick base for tapping. That should work well. A bonus of not needing an isolation kit on the TO220 cases is that you can use 6-32 bolts instead of 4-40, since there is no shoulder washer. This makes it much more difficult to strip the threads in the aluminum. Please post some pics of your discharger.
Old Jun 07, 2013, 07:56 PM
Ohmic is offline
USA
Joined Jan 2002
The thick base is exactly why I choose this model. Some of the other units I looked at had a really thin base.
Old Jun 24, 2013, 07:42 PM
Joined Feb 2012
discharger
Wrong stuff sorry
Discussion High discharge vs low vs number of cycles viflyer Batteries and Chargers 5 Sep 29, 2010 02:54 PM
Discussion Use of Cheap Lipos at Low C discharge for EP Skateboard E-Challenged Batteries and Chargers 3 Sep 22, 2010 09:01 PM
For Sale CHEAP! 2 & 3 cell 1200mAh high discharge(HD) LiPo battery Sale shschon Aircraft - Electric - Batteries & Chargers (FS/W) 5 Sep 29, 2006 03:16 PM
homebuilding 'cheap' high-torque/high-power brushless e-motors Ron van Sommeren Racing Boats - Electric 1 Jul 01, 2003 02:07 AM
Homebuilding 'cheap' high-torque/high-power brushless e-motors Ron van Sommeren Electric Sailplanes 0 Jun 30, 2003 11:21 AM
