Old Dec 09, 2010, 03:37 AM
Flying Barry is offline
Find More Posts by Flying Barry
Australia, NSW, Sydney
Joined Jan 2007
Question
Amsterdam Tug treating the timber work inside and outside the hull
Hi Guy's
I would like to ask everybody here for advice in regards to treating the timber work inside and outside the hull. You will notice in one of the pictures that i have started removing the inside planked timber liner and floatation foam to reveal the timber work inside of the hull. There you will see that some of the hull timber work has turned black i don't think this is good thing at all and could be a moisture fungus of some kind. Can anyone tell me the best way to treat this problem? Just would be great to see her back in the water again and not on the shelf collector dust
Barry
Flying Barry is offline Find More Posts by Flying Barry
Old Dec 09, 2010, 11:03 AM
Kmot is online now
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
#1, do not breathe the dust. It probably contains mold spores which could be harmful to your health. So wear a suitable dust mask.
Black mold is the worst of the molds. Bleach is not the answer either. I went through this a few years ago with an eBay purchase of a supposedly NIB engine that turned out had been in a basement flood and the box was one big piece of black mold and even the engine casting got contaminated. It is still sealed in a plastic zip lock bag where it will stay.
http://www.toxic-black-mold-info.com/moldclean.htm
Kmot is online now Find More Posts by Kmot
Old Dec 09, 2010, 11:42 AM
Joined Jan 2007
Wow....I didn’t think it could be as bad as that but i could tell it was not good that’s why i asked the question here thank god i did, thanks Kmot for the heads up.
Barry
Old Dec 09, 2010, 03:39 PM
Olscuzbut is offline
Find More Posts by Olscuzbut
Kamloops BC Can.
Hi Barry,
If any dampness or moisture remains in the hull after removing all the floatation foam and rotting wood, if you can locate silica crystal, usually sold in a can, pour into the hull for a day or two, it will totally dry out the bilges.. Will also help to get rid of the mould, as it needs moisture to survive. The crystals will turn pink (from Blue) as they absorb the moisture. After pink, they can be cooked on a hot plate or toaster oven to drive out the moisture turning blue again and ready for re use.
Norm
Olscuzbut is offline Find More Posts by Olscuzbut
Old Dec 10, 2010, 02:58 PM
Joined Jan 2007
Hi Norm,
The Amsterdam has not been in the water for about a year now, last summer. The timber itself looks pretty dry but i will give the silica crystal a go if i can find some.
Barry
Old Dec 10, 2010, 10:09 PM
1967250s is offline
Find More Posts by 1967250s
1967250s's Avatar
United States, VA, Alexandria
Joined Sep 2008
Nice tug> We hope to see it on the water soon! You might have to replace some wood there. A better way to dry out the hull might be to get a low watt bulb on a stand and set it in the hull, then treat it with a stop rot formula( not sure what you might have in Oz). Good luck.
1967250s is offline Find More Posts by 1967250s
Old Dec 11, 2010, 06:24 AM
more coffee is offline
Find More Posts by more coffee
Cheif Bottlewasher
more coffee's Avatar
Canada, NS, Sydney Mines
Joined Sep 2005
Go to your local Hardware store Paint department..
You may be able to find a mold killer there..
In homes ..pulverised dry ice can be blasted on it to kill it ..
Remove all the blackness..while its still very damp or wet ..never dry..
more coffee is offline Find More Posts by more coffee
Cool For all the "AMSTERDAM" and Tug Tow fans. tallships232 Scale Boats 125 Sep 17, 2015 02:05 AM
Sold Artesania Latina Amsterdam Tug NIB mgroves Boats (FS/W) 5 Oct 18, 2010 10:02 AM
Sold Artesania Latina Amsterdam Tug kit 48chebbie Boats (FS/W) 3 Sep 16, 2010 10:29 PM
