This thread is privately moderated by Whiskers, who may elect to delete unwanted replies.
Old Dec 09, 2010, 02:38 AM
Whiskers is online now
Find More Posts by Whiskers
Build straight - Fly twisty
Whiskers's Avatar
Australia, QLD, Little Mountain
Joined Feb 2010
Dec 2010 Fleet
These are the planes I have ready to fly at this point of time... a couple more are under construction.
Whiskers is online now Find More Posts by Whiskers
Old Dec 09, 2010, 05:03 PM
springer is online now
Find More Posts by springer
treefinder
springer's Avatar
SE MI
Nice looking squadron, a great mix of genres! Some serious slopers, too. Were they used at your former flying site?
springer is online now Find More Posts by springer
Old Dec 09, 2010, 05:38 PM
Whiskers's Avatar
Joined Feb 2010
The former flying site was near a mountain that is covered in trees and houses and therefore useless.
The best site is about a 20 min drive away but it is 'owned' by a club of which I am not a member. Another very good slope is in that same area but needs the wind to be from the North. This is my favorite.
The red sloper started life as a light RTF powered RET brushed motor thing, and it evolved into a weighty aileron equipped, film covered slope missile.
The other one is a quickie using a wing I was given. It goes well too.
Old Dec 17, 2010, 02:15 AM
demondriver is online now
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
Whiskers I'm liking those gliders of yours my good man! very nice!
demondriver is online now Find More Posts by demondriver
Latest blog entry: Foam Safe Spray paint!
Old Dec 17, 2010, 07:41 AM
Whiskers's Avatar
Joined Feb 2010
Thanks demon. Gliders sure are the way to get long flight times, a stiff neck, a sunburned face and eye strain... but I love 'em.
Old Dec 17, 2010, 10:44 AM
Up-Out-&-Gone
Joined Mar 2007
Whiskers. . . I found a possible solution for the stiff neck, try flying the gliders from a beach chair!
Old Dec 17, 2010, 06:56 PM
Whiskers's Avatar
Joined Feb 2010
LOL. But I'm old and might go to sleep...
Old Jan 20, 2011, 09:25 PM
kirk0703 is offline
Find More Posts by kirk0703
United States, MS, Hattiesburg
Joined Jan 2011
the red and white plane directly behind the blue one on the right..thats the model i want my project to be..if i can get on like it thats were i can mold the parts to get my own..and the bigest question about it is the design, is it more of the motor flying it or is there important aero dynamics in its design??
kirk0703 is offline Find More Posts by kirk0703
Old Jan 21, 2011, 07:04 AM
Whiskers's Avatar
Joined Feb 2010
The red and white plane that looks a bit like a Cessna is called the Cessnot because all my friends say it flies in a very 'Not Like A Cessna' way.
The plane is a very spectacular performer. It can jump off the grass runway in about its own length and climb vertically, very fast, to any height, limited only by visibility.
It is extremely aerobatic. with a great roll rate, and has neutral stability and has no self-righting tenancies, it just keeps going in whatever direction it is pointed.
Powered by a TP 2409-12 swinging an APC style 8X4 prop, it has almost 2 to 1 power to weight ratio and the thick symmetrical section wing gives great lift and gentle stall.
It's a fun plane, but only for an experienced pilot.
Kirk, what you need to do is get a flight sim on your computer and learn to fly on that while you build a BluBaby or Oshkosh Special and if you can master the building and flying of that, then you can start thinking of the next step.
But get into it. You have a year, but time goes fast. Right now you know so little, you don't know how little you know. (we all start like that)
Start now.
Old Jan 22, 2011, 12:53 PM
kirk0703 is offline
Joined Jan 2011
i downloaded FMS took me a while to get it working ...it will be a while before i can actually use it . im gonna try to use a xbox controller.. thanx for the info
Old Jan 22, 2011, 02:25 PM
Whiskers's Avatar
Joined Feb 2010
Kirk, when you buy your radio make sure you can also use it with FMS.
My Grandson got good with FMS and when it came to flying a model... No problem, he could fly.
Flying an RC plane is one of those things that is hard at the start and easy when you can do it.
Mind you, doing something perfectly is never easy.
Old Feb 28, 2011, 04:59 PM
moscow580 is offline
Find More Posts by moscow580
Is it suppose to do that?
moscow580's Avatar
USA, CT, Waterbury
Joined Sep 2006
Thermals
Hi Whiskers:
I see that you like sailplanes. I was wondering; I read articles about soaring and they talk about thermals, but do not explain how to catch them. Although I enjoy powered planes (electric) I love to power down and see if I can get the plane to soar, what am I looking for in the flight pattern that denotes a thermal?
Sean
moscow580 is offline Find More Posts by moscow580
Old Feb 28, 2011, 10:19 PM
Whiskers's Avatar
Joined Feb 2010
Hi Sean,
Mainly what I do is to trim the glider for the best glide and fly it as accurately as I can and to observe the way it travels through the air.
If one wing gets lifted I assume the lift is on that side and I turn towards the high wing. If there is lift there the glider will rise and the trick is to circle in the rising column of air.
Sometimes the tail gets booted up and you need to come around to the lift that has bubbled up behind the glider. At other times you'll just fly into lift and see the glider start to rise rise, so circle and try to center the plane in the lift by turning towards the wing that wants to rise.
The thing is, the plane is sinking relative to the air at all times. It the air is rising faster than the glider is sinking then the glider will rise. Therefore the lower the sink rate the better the plane will thermal.
With a powered plane that's not an ideal glider you can have on just a sniff of power so that it sinks very slowly and then fly it pretty much like a glider.
Discussion Annual Tualatin,Oregon Christmas tree lighting Umi_Ryuzuki Dock Talk 66 Dec 08, 2013 11:09 AM
Fly-In DFW Area 114th Toy Drive Flyin Dec 4, 2010 gwh Electric Flight Events 51 Dec 06, 2010 12:09 AM
Question Anybody flying Dec 20-24, 2010? dougbo Albuquerque Area Electric Flyers 0 Oct 29, 2010 03:53 PM
